Question about Philips Magnavox 27MS343S 27" TV
Ok from the back of the tv!!
Ok im looking at the back of the tv its open and i see 4 red wires where do i go from there!! do you have a phone # so i can talk to you in person please!!! help me!!!
  • Philips Master
  • 8,617 Answers
I am at work where I do online tech support for servicemanuals.vstore.ca customers so I dont have access to a remote but if you look on the board that has the 4 large red wires
Look for a black IC with 9 pins it will have the numbers TDA36540 stamped on it and the board location will be 7555
Posted on Jun 01, 2008
Im a girl, & i need help hooking up my ps3 to my flatscreen
ok it should all go into your tv ok? and there should be a row of yellow white red or any order (ON THE FRONT). you should look on the back of your tv or side for alot rows of inputs and each row should be for an different input on your tv like input 1 2 3 4 5 6? you follow? so just match the colors up on the back or side of your tv or front do not hook it up to your cable box..........Ahh i see the cable box is using the yellow one well maybe unplug that while your playing or there would prolly be other (RED WHITE YELLOW) on the back of your tv like i said or on the side
Aug 16, 2009 | Sony Playstation 3 (PS3) Console
RED LAMP LIGHT CAME ON AND TV TURNED OFF
since you changed the ballast and the power supply the first thing i would do is recheck the plug connections on bothe boards. the wires on the power supply have a funny routing and sometimes can get cut or pinched. the small connector on the ballast will get loose pin connections and not make contact.if those look ok, leave the back covers off, put the air filter door on. nnow while you are listening over by the ballast, turn on the set, and check for a small arcing sound.if you here one that means the ballast is firing. look to see if you pushed the lamp wires out of the lamp housing.
post back what you find and we can go farther
Jan 07, 2009 | Televison & Video
RCA surround sound system probs
power supply problem.can you open the circuit board.
Jan 06, 2009 | RCA RT2380 Home Theatre System System
Rca 52'' projection tv model p52937
Go to menu ,now to setup when in set up do you see convergence? If convergence is missing in menu it is a open fuse,only it does not look like fuse ,They look more like small square capaitors brown, they will be right next to flyback transfomer FL231 (3) of them in a roll it will be the middle one,you can take needle nose plyers and pull top up on fuses.
Dec 17, 2008 | RCA D52W19 52" Rear Projection Television
External speaker hook-up
Ok, after A LOT of internet research I could not find any solution. So I decided to do a "chop suey" connection.
Went to Radio Shack and bought ...
Insulated Grip 2-1/4"Alligator Clips w/screw terminals 10 (five red & five black)
(A smaller alligator clip can be used if you have a soldering iron to connect the wires.)
30-Ft. 18-Gauge Clear 2-Conductor Speaker Wire
It cost about $15 for everything. Be sure to have electrical tape as well.
Stripped speaker wires to fit through each alligator clip and twisted it around the screw terminals of clip. Tapped screw terminal to cover wiring. Do this for 2 black and 2 red clips.
To install l laid the TV on its back and insterted each alligator clip to firmly fit on each terminal. Because the clips are large it will be a tight next to each other. Be sure to test one line and speaker first before completed the second line and speaker.
GOOD LUCK!
Nov 18, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Junk tv
My ilo 27" tv did the same thing (red light on front but would not turn on) and after much frustration looking around on the net I finaly cracked it open. After removing enough screws to remove the back the first thing I saw was the main power board. This board has quite a few capacitors on it and I found 4 of these that had bulging tops. 3 were 1000uf/16volt and 1 was 470uf/16volt. I disconnected all wire connectors from this board and replaced them with parts from radio shack PN 272-1032 and 272-1030. The voltage rating of these are different but ok if larger than the original part. It fired right up when I put it all put back together
Apr 02, 2008 | iLO V27DMBX Television
Phillips 50p8341 Projection tv no picture
Looks like the blue crt is bad and may have killed the main power board that has the high voltage supply.
A new crt is almost $400 and my distributer shows the power supply as no longer available, but may be able to get it somewhere else. Plus you need the service manual to realign and converge everything (hope you didn't mess this up too bad). Really need to find a good rear projection tech to do all this, but may not be worth it.
Jan 02, 2008 | Philips 50P8341 50" Rear Projection...
MY tV will not power and red light keeps blinking
i had the same problem with my tv i got a sodering gun its the board like the power supply open the tv and look on the board and look for ic801 on the bottom of the tv board then look in box line it has numbers from 1-7 get a sodering gun then soder number 4 i tryd it it worked on the board but be care full it will mess up quick if your not i had the same problem with this tv the soder on the board probly came off on no.4 but after your done and you have to pick the tv up becareful and do it slow because number 4 might come off again then you have to do it again and if that aint it just look on the bottom of the board and make shore nothing is loose and use the sodering gun to put back on that should be it ok then
Dec 19, 2007 | Panasonic CT-32SL14 32" TV
4a fuse blown
1)pull chassis.remove power PCB==the one with large heatsink w/convergence IC's on it 2)Observe four regulators also on same heatsink Remove solder from all reg. pins-clean PCB 3)Resolder 4)solder any/all bad connects 5)replace 4 amp fuse 6)reassemble & test
Oct 05, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Philips Magnavox 27MS343S 27" TV Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
