Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
When I enter the Regression Equation into the "y=" calculated from the Statistics that I input, it inputs half the equation into the power. Like X^(n 3) instead of X^(n) 3 which is what it is meant to be.
  • Texas Instru... Master
  • 7,993 Answers
The regression equation can be copied automatically in a Yx variable. You need not enter it manually(?).
Example: Suppose you are performing a quadratic regression on data stored in L1 and L2.
  1. From the [Stat][
Posted on Oct 16, 2010
  • k24674 Oct 16, 2010
    Sorry the site chopped my answer.
    1. From [STAT][>CALC] menu select [5:QuadReg]. 2 Command echoes on main screen as QuadReg. 3 Specify the lists to be used (if not default) for example [2nd][1] (L1) [, comma] [2nd][2] (L2) . Do not press [ENTER] Yet. 4. Specify the Yx variable you will use to store the regression equation. Press [VARS] key [>Y-Vars][1:Funcrion][1:Y1] ENTER].
    Before you press the ENTER button the screen should display QuadReg L1, L2, Y1
Ti 84 plus silver edition will not fit a linear model to plotted points. when I use the function vars>stat>EQ>RegEQ it transmits incomplete data in to Y=.
Your data must be in two lists L1 (for x-values), and L2 (for y-values). This is the default setting. Open the STAT utility, go to the regression models. Select your model then press ENTER. The command echoes on the main screen. For example let the regression be something called LinReg.
On the main screen you see LinReg
Complete the command line as follows
LinReg L1, L2, Y1, ENTER
You see the statistics including the regression equation.
If you go to Y= Editor you will see that Y1 contains the regression equation.
If you have already drawn the scatter plot for your data, pressing GRAPH will superpose the scatter plot and the regression curve., and you will be able to judge the goodness of the fit.
Sep 28, 2013 | Texas Instruments TI-84 Plus Silver...
I have a TI-84 plus calculator. I enter data into a table (L1 & L2) and go through the steps to get an equation for the data. Next, I should be able to press VARS, move to Y-VARS, select FUNCTION,...
Your assumption
--Next, I should be able to press VARS, move to Y-VARS, select FUNCTION, then select Y-1 and automatically enter the equation into Y-1.-
is not correct.
When you press [STAT[>][CALC][4:LinReg(ax+b)] or any other regression model,the command echoes on the main screen. If you press [ENTER] at this point, the calculator uses by default lists L1 and L2 and displays the resulting equation without copying it in a Y-variable.
If you want to have the equation copied on a Y-function, you should modify the command as follows
LineReg(ax+b) [SHIFT][1: L1] [,] SHIFT[2:L2] [,] [VARS][>:Y-Vars] [1:Function][1:Y-1][ENTER].
Here, [>] stands for RightArrow. For any other regression model, use the appropriate command.
At this point, the command line should look like the following:
LinReg(ax+b) L1, L2, Y1
Press [ENTER] to calculate you get the same screen as when you do not save the equation in Y1, but if you go to the Y= editor or press GRAPH, you will see the regression line superposed on the scatter plot.
Jul 13, 2011 | Texas Instruments TI-84 Plus Calculator
I knowi can find a linear equation if i have: two points {for example A(0,0) and B(1,1) the equation is y=x} or one point {for example C(0,2)} and a slope {for example m=2) the equaton is y=2x+2 can my...
The general answer is no. However the calculator can be used to find the slope and the y-intercept. You write the formula for the rate of change (a) and use the calculator to calculate it. Then you use the formula to find the y-intercept.
If you have 2 points, you can use the 2 -var statistics program to find a linear regression.
Jul 05, 2011 | Casio FX-115ES Scientific Calculator
Solve for x: x/3-1/5=4/3
Press [math] [0] to put the calculator into equation solver. Then you input your equation in 0 = format. So, the equation x/3 - 1/5 = 4/3 would be input as 0 = x/3 - 1/5 - 4/3 . Then press [enter] .
Apr 05, 2011 | Texas Instruments TI-84 Plus Calculator
In my precal class we are studying trigonometry graphing. On my calculator I made 3 lists L1, L2, and L3 when I go to graph and regulate the equation it only regulates the equation for both L1 and L2....
I do not know what you mean by regulate, but if you want to perform a regression analysis using data from L1 and L3, all you have to do is to specify the lists to be used.
For example if you have to perform QuadReg on L1,L3,
  1. Press [STAT] button,
  2. then Right Arrow to select CALC(ulate)
  3. then [5:QuadReg]
  4. The command QuadReg echoes on main screen as QuadReg .
  5. At this point press [SHIFT][1] to select (L1), then [COMMA], then [SHIFT][3] to select (L3) , and finally [ENTER].
  6. The result will be displayed after regression is performed.
  7. If you want to save the regression equation in Y1 so as to graph it over the scatter plot you enter QuadReg L1, L3, Y1 [ENTER]
Feb 04, 2011 | Texas Instruments TI-83 Plus Calculator
How to input cos x=0.75?
I assume that if you want to input the equation it is with the intent to solve it. If that be the case then what follows will help you input and solve any equation (linear, quadratic, trig, etc.)
Make sure the calculator angle unit is the same as your problem requires (degree, radian, grad). Here are some screen capture to help you. Change the equation to yours. 21c8779.jpg4b6c1ea.jpg
To enter the equation in screen above, use the right arrow.
You have to enter an initial guess on line X=, a default value may be supplied by calculator: It depends on last value stored in X. Once a value is entered press the F6 key to SOLV
Press F1: Rept if you want to solve another equation.
Nov 13, 2010 | Casio FX-9860G Graphic Calculator
I am trying to drive a prediction equation. but the book gives directions to aTI-84 and I have a TI-89. I have these steps "STAT, EDIT, L1, L2,STAT, CALC,LinReg(ax+b), ENTER" I have no clue how to make...
I assume you know how to enter data in your calculator. The keystrokes in the following pertain to TI92/92Plus/ Voyage 200 PLT. The main differences with the TI89/Ti89 Titanium is that the function keys F6,F7,F8 are not accessed directly but by the key sequences [2nd][F1], [2nd][F2], and [2nd][F3] respectively
1. CLEAN THE SLATE (so to speak) and ENTER DATA
In Home folder run F6: NewProb to reset the configuration.
Press Apps, and select 6: data/Matrix editor. Select a new data set
Give it a name: here testing.
Press OK/ENTER, The data entry screen opens, enter your values.
When you finish press F2.PlotSetUp.
2. Statistical plot setup and scatter plot drawing
b142867.jpg.
Press F1:define to configure Plot1. Choose Scatter, then choose a mark for the data point. I select 5:Dot. and press [ENTER
Select the data column X=c1, Y=c2
Press ENTER to save configuration. Press [CTRL] [GRAPH] On my TI92 the CTRL key is the [Diamond] key. On the following graph I changed the mark to a cross to see the data point better. I also played with the window dimension. You can also do that with ZoomStat. The graph remind me of a parabola (I know I chose the exact values)
3. STATISTICAL CALC. AND REGRESSION ANALYSES.
Now we have to find the equation that fits these data best.
You press APPS 6:Data/ Matrix editor but you select current to return to your data set. You are taken to the data entry editor (Figure 3 above). In that screen Press F5:Calc to edit the type of statistics you want
On first line select the type of regression model : Linear Regression, QuadReg quadratic regression (or anything else available) X is from column1, Y is from column 2. Store RegEQ The regression equation in say Y1(x)
Press ENTER to save to get the Regression Equation. Here it is
As you can see I cheated: a perfect parabola. R^2 =1.
And here the best fit represented on same graph as the statistical data
Usually you have to try different regression models, until you find the one that fits best the experimental data.
Jul 26, 2010 | Texas Instruments TI-89 Calculator
TI-83 Texas calculator, exponential regression. How to input data in calculator? I have D list (time/days list of 1,2,3,4,5,6,7) and N list (6,10,13,27,42,65,120)- how do I input into calculator and draw a...
Read this post. It answers all your questions and shows you HOW to do find your equation of best fit, correlation coefficients, etc.
Before doing statistics, you have to prepare the calculator by clearing old data that may generate errors.
A. TO CLEAR OLD DATA
  1. Press [2nd][+] (MEM) to open the memory management screen.
  2. Press [4:ClrAllLists]
  3. The command echoes on main screen, press [ENTER] to run it.
  4. Calculator displays Done.
B. RUN the SETUP EDITOR Command
  1. Press [STAT][5:SetUpEditor] [ENTER] ; calculator displays Done.
C. TURN DIAGNOSTICSON option (optional)
To obtain the correlation coefficient in a statistical analysis on the TI8xPlus family of calculators you must activate the DiagnosticsOn option. To access the command
  1. You press [2nd] [0] (CATALOG)
  2. While the list of commands is displayed, press [X^-1] (D)
  3. Cursor jumps to first command that starts with D, dayOfWk(
  4. Press the DownArrow 9 times to reach DiagnosticsOn
  5. Select it and press [ENTER]
  6. Command echoes on main calculator screen with blinking cursor
  7. Press [ENTER] to set the option
  8. Calculator displays Done.
From now on, if a correlation coefficient has meaning for a regression model, it will be calculated along with the other statistical results. If it has no meaning to the model it will not be calculated.
D. ENTER THE DATA
Press [STAT][1:Edit]
Type in your D (X ) values in L1 and the N (Y) values in L2 (see picture 1). Sorry the picture does not have YOUR values.
TO OBTAIN THE STATISTICAL RESULTS (optional)
  1. After you finish entering the data, press [2nd][Quit] to exit StatEditor.
  2. Press [STAT] and highlight Menu (CALC)
  3. In the list select [2:2-Var Stats]
  4. Command echoes on main screen.
  5. Press [ENTER] to calculate the stats
Here is what you get (THESE~ARE NOT YOUR RESULTS). Your results will be different.
Notice the down arrow next to n=7. That means the results screen has more values. Press the down arrow to display.
You notice that the n=7 line now has an arrow pointing Up. Notice the Down Arrow on the bottom line (more data is coming). Here is the rest of the statistical results.
There is no arrow at the bottom of the picture. End of statistical results.
The screen captures with 2-Var Stats summarize all the satistics.
However there is no correlation coefficient, no line of best fit, etc. To obtain that you have to perform a regression analysis.
E. PERFORM A REGRESSION ANALYSIS
To perform a regression analysis, you must try several regression models and then find the one that mimicks the raw data best. In this particular case, you have already decided to do a linear regression, and that is good for me. I do not have the time to take you through all of them. In this step you must select the exponential regression model.
  1. Press [STAT] , highlight [CALC]
  2. In the list of regression models select [0:ExpReg]
  3. The command ExpReg echoes on main calculator screen.
  4. If you press [ENTER] you will get you equation but you will not be able to draw the curve on top of your data to verify the goodness (no it is not a swear word) of the fit. So you must save the equation as a function in Y1 variable.
  5. While ExpReg command is still in command line, press the [VARS] key.
  6. Highlight the [Y-VARS] menu and select [1:Function], then press [ENTER].
  7. In the Y function variable list select [1:Y1]
  8. At the command line, you have ExpReg Y1.
  9. Press [ENTER] to save the equation of best fit in Y1.
Here are your results. (These are your actual results)
You also have r and its square. You need to read your theory to know which of the two correlation coefficients you have been asked to obtain.
Since you saved the equation in the Y1 function you can draw it. You just have to press GRAPH and it will be drawn. But that will not tell how good the fit is, until you see the function drawn on top of the raw data.
DRAWING THE SCATTER PLOT AND BEST FIT CURVE ON SAME SCREEN
Regardless of the curve of best fit, you can draw a scatter plot as follows.
  1. Press [2nd][Y=] (STATPLOT)
  2. Select [1:Plot1...Off] and press ENTER to open plot1 configuration screen
  3. Use arrow to highlight On and press ENTER
  4. Use the down arrow to move cursor to the line Type.
  5. Select the first icon for a scatter plot. NOTE: To navigate the 6 statistical stat plots on the line Type, use the right or left arrow (to backtrack), but not the Up or down arrows.
Here is the configuration screen
Here plot1 is active (ON), it is scatter plot (first icon) the Xlist is L1 by default but you can change it to some other list. Notice the highlighted A cursor on XLIST line. It means that the [ALPHA] keyboard is active.
On the line Mark you can choose the appearnce of the raw data point.
And here are your two graphs: the raw data scatter plot and the line of best fit on the same screen. On the picture the ZoomStat option was used.
Now, it is up to you to accept this model or to try another model.
Mar 14, 2010 | Texas Instruments TI-83 Plus Calculator
Find the equation of the line that best fits on a ti 89 calculator
b142867.jpg.
Press ENTER to save configuration. Press [CTRL] [GRAPH] On my TI92 the CTRL key is the [Diamond] key. On the following graph I changed the mark to a cross to see the data point better. I also played with the window dimension. You can also do that with ZoomStat. Th graph remind me of a parabola (I know I chose the exact values)
On first line select QuadReg quadratic regression, X is from column1, Y is from column 2. Store RegEQ The regression equation in say Y1(x)
Press ENTER to save to get the Regression Equatio. Here it is
And here the best fit represented on same graph as the satistical data
As you can see I have gone a long way out of my way to show you all the steps.
I hope it helps you and others who wonder how to do regressions on a TI89. If someone does not understand these explanations, the blame does not rest with me.
Oct 21, 2009 | Texas Instruments TI-89 Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
410 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
