Question about Zephyr Typhoon AK2100 Kitchen Hood
Zephyr typhoon AK2100 Kitchen Range Hood
This is a 6 speed Range hood. all 6 speeds were working before, but now all of a sudden, only TOP speed (number 6) works, FAN does not work at any other speed (1 to 5). Halogen lights are working at all speeds.
any suggestions will be welcome.
  • swapnil21 Jun 01, 2008
    Thanks for the solution. i will try and see if i can get part from Zephyr and fix it (Zephyr has 10 years parts warranty)
  • Anonymous Mar 24, 2014
    Fan runs with a "push"
  • 22 Answers
Just in case ... the control board is in the front of the hood behind the speed & light power buttons. It IS a bit of a PITA to get it out: Pull down the underside cover (5 screws on the perimeter hold it).
Use the provided suction cup to pull down to remove it. When you do there should be enough wire to the lamps to rest the whole cover on your stove, otherwise dosconnect the inline wire connectors. the hard part for me is getting that board out / back in. there is a 3/4" Buss fuse onboard that seems to pop on my hood every few months.
Posted on Dec 20, 2014
Where can i find the control board of ZEPHYR AK21XXAX model to replace
Posted on Nov 24, 2009
    Genius:
  • 1,224 Answers
Its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Posted on Jun 01, 2008
My Zephyr Typhoon Range Hood (AK2100) neither light nor fan work i can not find fuse box
There shouldn't be a fuse box on the range hood.
You'll have to check your main house circuitbreaker or fuse box.
Jul 22, 2016 | Zephyr Kitchen Ranges
Medium Fan Speed not working
Switch is probably faulty, or wire / connection to switch. If switch and wiring test ok trace wire from that button back to wherever it goes and look there for fault.
May 12, 2014 | Faber TEND30SS300 Decorative Collection...
Why won`t the fan of my venmar range hood turn off?
Sounds like you may need to replace the fan switch. The fact that it wont turn off and that it only works on low speed supports that switch is broken.
Apr 24, 2014 | Venmar Kitchen Ranges
Fan and lights blew off
check the fuse. (see post about control board.)
excerpt: ... the control board is in the front of the hood behind the speed & light power buttons. There is a 3/4" Buss fuse onboard that seems to pop on my hood every few months.
Mar 06, 2014 | Zephyr Typhoon AK2100 Kitchen Hood
KWCU405SSS fan motor high speed only
Agreed! It totally works. Our fan and lights were stuck on high. Flipped the hood circuit breaker off for 30 seconds then back on again and all controls are working normally again. Thanks!
Jan 15, 2013 | KitchenAid Architect® II KWCU405SSS...
Zephyr typhoon ak2136 stopped working
I have the same problem with my unit. Have contacted Zephyr support and hope they have answers.
Jan 04, 2012 | Zephyr Typhoon AK2136 Kitchen Hood
What controls the speed of a range hood fan? , only when i push the hi button or the low speed button, the hi speed button only works. its a old model built in 1960 , can't find the model number ...
You will need to check inside the button contacts to identify if the control of current is by a series resistor or by the coil winding.
Since the high speed is working it is possible that the series resistor coil is open.So check for loss of contact continuity in the switch, if not you can use the present model of electronic fan controllers to give you a variable fan control. This can be connected to the main hi speed connection.
Tip: Identify the wattage and buy the regulator according to the specs.(42 inch type)
Dec 18, 2010 | Kitchen Ranges
Zephyr Typhoon AK2100 Kitchen Hood Logo
2,000 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
