Question about JVC AV-32D305 32" TV
Dead set Need a diagram ! Advise or point me in a
Dead set Need a diagram ! Advise or point me in a direction? Thanks Ben
    Problem Solver:
  • 17 Answers
Have u tried in raon??
Posted on Oct 12, 2010
How do you reset flywheel timing
I am assuming you removed the distributor? If so identify #1 cylinder in the firing order. It must be at top dead center (TDC) on the compression stroke. The timing marks should be lined up dead on at center. Then, you install the distributor with the rotor pointing directly at #1 cylinder. It is possible to be a gear notch off in either direction. If it is dead on then the engine will start. From there you will need to set the ignition timing with a timing light to correct advance by rotation of the distributor. May be 6 - 8 degrees BTDC? Consult manual for correct advance degrees.
Apr 01, 2014 | Cars & Trucks
I need the timming specs in my 1966 buick riviera its got a 425 nailhead single 4.
The spark plug type is 44S and the gap is .032. The ignition points should be set at a 30 degree dwell angle or a .016 point gap. The ignition timing should be set at 2-1/2 to 3 degrees before top dead center, and the engine compression should be 170 psi. Let me know if you require a firing order diagram or any further assistance.
Aug 24, 2010 | Buick Riviera Cars & Trucks
I need a diagram of the engine timing marks for a 1995 S10 Blazer. Can anyone provide?
Hello Friend:
Yes i can tell you how to set your Timing Marks.
Your Top Gear the Cam Shaft Sprocket you want the timing Mark you'll want it to be Pointing Down .it won't be completly straight Down but Very close to it.
You'll want your Lower Sprocket (Crank Shaft) Point Upward .Until both Cam And Crank Shaft Marks Ar Directly in Line with the Other.
As Long s you Have those 2-Marks Meeting Straight Across from each Other,You will be Set t Top Dead Center.
Meaning the your number 1- Piston Should be up and on the Compression Stroke, Not on the Power Stroke but Compression.
Either Way Sir if you got em Lined up like I was talking About you'll be Fine.
This will get your Timing Gears Lined up Properly,.
Thank You Sir for Using Fixya Please let me know the Quality of my Solution by Voting for me.
Thanks Again From d_hubbs
Aug 17, 2010 | Chevrolet Blazer Cars & Trucks
How do I set timing marks -2001 kia Rio. my timing broke and I'm replacing it and need to know how to set my timing marks need a diagram,please-- THANKS YOU
Click on the following free, direct Link. It has all the Timing Belt Diagrams you will need, complete with Instructional and Directional Diagrams to set your Timing.
Let me know if this helped or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2001/make/kia/model/rio/2001_kia_rio_timing_belt_diagram_marks.htm
Mar 26, 2010 | 2001 Kia Rio
Spark plug wires diagram for 91 gmc sierra
ok number 1 piston should be a top dead centre & mabe on the top of the cap is a mark or number
if not then there should be a mark on the lip of the dizzy!
if not then just choose one near the front & set the points at that point on the point of sparking! [ready to open points] make sure you have spark or you may have left ou the insulator on the points locating pin!!!
then its a matter of the firing order!
i hope this helps
cheers Rob
Aug 15, 2009 | GMC Sierra 1500 Cars & Trucks
Need the spark plug cable order for2000honda accord lx 4cylinder
The firing order is; 1-3-4-2 and the rotor moves in a counterclockwise direction. Turn the crank shaft and set the engine at TDC (top dead centre). This ill set the rotor arm pointing at No1 cylinder. From this point you can replace the HT leads in the above order.
Nov 23, 2008 | 2000 Honda Accord
Timing Belt
I want to know how to set point
Oct 08, 2008 | 1996 Dodge Stratus
Circuit diagram
For just a short advise you may buy that kind of circuit in the computer shop ... Just reply me if my advise is helpful or not?
It's ok???
Jul 02, 2008 | Intel D845GVSR Motherboard
JVC AV-32D305 32" TV Logo
41 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
