Question about Philips Magnavox 27MS343S 27" TV
Where is the flyback located ????
Help where is it!!!!
  • Philips Master
  • 8,617 Answers
You may have to call in a repair tech to look at the set if you cant find the IC from my description as You will need to pull the chassis in order to actually be able to solder the vertical IC.
Posted on Jun 01, 2008
Flyback transformer
Throw the set in recycling and buy a new set, its not worth repair, the part would be close to 100 bucks if it was available
Dec 18, 2017 | Zenith C36V23 36" TV
Show picture of flyback transformer and out put transistor
Heres a picture of the flyback. The trans HOT is located just ahead and to the right of the flyback its attached to an aluminum heat sink,slinteriors_16.jpgslinteriors_17.jpg
Jul 24, 2011 | RCA P61960 61" Rear Projection Television
MY HDTV 52IN RCA HAS BOWED PICTURE. I CANT FIGURE HOW TO FIX IT
heres where they are located but you have to resolder the flyback and vertical IC also.
Look at the flyback ( with the Large red wire) Just to the right of the flyback you will see three small brown Fuses the cehter one is FL231 DL231 is just to the right of FL231 and Cl230 is just below and alittle to the right of DL231
Jun 14, 2009 | RCA HD52W59 HDTV Projection Television
Replaced flyback
often the old flyback will cause CP150 and CP120 to dome on top when the old flyback goes out. Check the tops of those two capacitors for doming. They are located on the same board as the flyback.
Dec 27, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W26
you can get a replacement flyback at the following link, with fre online tech support to help you install the part. You need flyback 259296 Heres the link.
http://servicemanuals.vstore.ca/
Jul 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flyback transformer.
I can not seem to cross those numbers to any source I have. there is a good possiblity that the part is no longer available. after all the set is 20+ years old and manufacturers do not keep making parts for them forever. sears had other companies make their tvs early sets were made by zenith then they were RCA.
May 02, 2008 | Televison & Video
Hernandez030763@yahoo.es
The flyback for JVC C-13910 is listed below. Do you have the location number for the IC Regulator?
JVC C-13910 Flyback T1522
Apr 22, 2008 | JVC C-13910 13" TV
Toshiba vertical problem 36 inch
I dont realy know about this model but in many other model is a 1 oms resistror and is located around the flyback becouse the b+ for vertical output is taken from the flyback secondary voltage if these help you ....good luck and rate me
Jan 13, 2008 | Toshiba CZ36T31 36" TV
Flyback transformer on television
Single white line across screen mean a vertical colapse. So you will need the vertical output and maybe a cap around 100uf@50v.
Sep 13, 2007 | RCA E13320 13" TV
Philips Magnavox 27MS343S 27" TV Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
