Question about LG KU990 Viewty
My lg rd 2340 battery low probelom - LG KU990 Viewty
My 2003 Mercury mountaineer low beams won't come on
Visual Inspection Chart Mechanical Electrical
  • Headlamp switch
  • Multifunction switch
Pinpoint Test B: The Low Beams Are Inoperative
Normal Operation
The headlamp switch sends power through circuit 13 (RD/BK)/15 (RD/YE) to the daytime running lamps relay, then to BJB fuses 42 (10A) (RH headlamp) and 43 (10A) (LH headlamp) through circuit 13 (RD/BK). After passing through the fuses, voltage is then carried through circuits 161 (DG/OG) (RH headlamp) and 160 (DB/WH) (LH headlamp) to the low beam headlamps. Circuit 1205 (BK) is the ground circuit for the headlamps.
Possible Causes
  • Circuit 13 (RD/BK)/15 (RD/YE) open
  • Circuit 697 (BN) open
  • Circuit 196 (DB/OG) open
  • Circuit 1205 (BK) open
  • Circuit 632 (GY/OG) open
  • Circuit 12 (LG/BK) open
  • Daytime running lamps relay
PINPOINT TEST B: THE LOW BEAMS ARE INOPERATIVE Test Step Result / Action to Take B1 CHECK CIRCUIT 196 (DB/OG) FOR VOLTAGE
  • Key in OFF position.
  • Disconnect: Headlamp Switch C205a.
  • Place the headlamp switch in the headlamps ON position.
  • Place the multifunction switch in the low beam position.
  • Measure the voltage between the headlamp switch C205a-8, circuit 196 (DB/OG), harness side and ground.
  • Is the voltage greater than 10 volts?
Yes
GO to B2 .
No
REPAIR the circuit. TEST the system for normal operation. B2 CHECK THE HEADLAMP SWITCH
  • Carry out the headlamp switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Is the headlamp switch ok?
Yes
GO to B3 .
No
INSTALL a new headlamp switch. REFER to Headlamp Switch in this section. TEST system for normal operation. B3 CHECK CIRCUIT 13 (RD/BK)/15 (RD/YE) FOR AN OPEN
  • Disconnect: Multifunction Switch C202c.
  • Measure the resistance between headlamp switch C205a-9, circuit 13 (RD/BK) and the DRL relay:
    • (early build) pin 3, circuit 15 (RD/YE)
    • (late build) pin 5, circuit 15 (RD/YE)
  • Is the resistance less than 5 ohms?
Yes
CARRY OUT the multifunction switch component test. If the switch tests OK, INSTALL a new multifunction switch. REFER to Section 211-00 . TEST the system for normal operation.
No
  • Battery junction box (BJB) fuse(s):
    • 16 (15A)
    • 22 (20A)
    • 42 (10A)
    • 43 (10A)
    • 46 (20A)
  • High beam relay
  • Circuitry
Sep 10, 2015 | Mercury Cars & Trucks
LG RD450 Battery
google is your friend, http://www.ebay.com/itm/Laptop-Battery-For-LG-R450-HASEE-A350-A450-HP500-HP640-HP660-A32-H24-L062066-/180941735898
Oct 27, 2013 | Computers & Internet
HOW TO DOWNLOAD CONTACTS NO FROM Lg Rd 3640 to pc
i want lg rd -3510 pc sync what to do
Jul 19, 2012 | Cell Phones
SIR I HAVE LG RD-351F02 WITH RELIANCE IWANT TO
no sorry but u can not use gsm card in cdma phone
Jul 04, 2010 | LG RD2030
Forgot Lock code of LG RD 3500
Go to the costumer care and ask them for code ... they'll ask Ur authentication and willprovide you the pin.
Sep 22, 2009 | LG RD2030
Please gives me LG RD 8000 USB cable software
sir, I am k singh form ludhiana. I have LG RD 8000 mobile phone. but i cannot connect my mobile to pc. i have no mobile sync software to connect my mobile to PC. Can u give me software to connect my LG RD 8000 mobile to pc.
tks
Jun 08, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Need software for lg rd 6100
I need software for this lg rd 6100 to transfer my photos.
cdma handset with vga camera.
i have data cable.
May 10, 2009 | Cell Phones
To recover LG RD 3000 mobile unlock code
I WANE UNLOCK CODE FOR LG RD 3000
May 04, 2009 | LG Cell Phones
Low beams only work sometimes
Remove the plastic trim from around steering column so you can access the wires to the multi-function switch(turn signal switch).The RD/YE wire is the feed from the headlamp switch for low beams,it then leaves the multi-function switch on the RD/BK wire and feeds fuses no. 10 and 4 in the under dash fuse panel and from there to the headlamps right side is the DB/LG and left side is the WH/LG. Get you a 12V test light and make sure you have voltage in these places. I suspect that the multi-function switch itself has gone bad since you stated that they would work at times when you activated the turn signals.
Feb 02, 2009 | 2003 Ford Mustang
LG KU990 Viewty Logo
101 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
