Question about Sony Ericsson K320i Cellular Phone
The phone cannot be turned on/ flashing red light
    Sergeant:
  • 172 Answers
Replace battery
Posted on Oct 12, 2010
Why does my red light flash on my z998 but wont turn on
try pulling the battery out,Just leave it out a few seconds (count of 30). And unplug power(charger) cord from your phone. Then put the battery back in and press the power button.
Feb 08, 2015 | AT&T GoPhone Z998 4G No-Contract Cell...
Will not turn on
Before sending your phone in for a flash2.gif or attempting to do it yourself (wotanserver), I would suggest the following. Take out the battery and leave it out overnight. Then put it back in the following day and try turning the phone on. If this didn't help, then flashing is required. You can try flashing with SEUS (Sony Ericsson2.gif Update Service) which is free (wotanserver requires credits=money). Good luck!
Dec 15, 2007 | Sony Ericsson K800i Cellular Phone
My blackberry z10 wont turn but red light flashes
I'm not an expert on phones, but it sounds to me like that is the low battery light that is flashing, so I must ask, have you charged it recently? if not, try that and then after a few hours try turning it back on.
I hate to sound stupid, but a lot of phones will flash a red light if the battery is too low for it to turn on. so it is worth mentioning.
Feb 20, 2014 | Research In Motion BlackBerry Z10 Unlocked...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
RED LIGHT FLASHING NOTHING ELSE WORKS
Red light flash slowly but bright and nothing more, can't turn it on, won't light up. What must I do?
Jul 25, 2009 | RIM Blackberry 8110 Cellular Phone
Red led light is flashing while charging and it won't turn on
I just called Verizon Wireless who said that the phone may need to be charged completely for a few hours. Try taking the battery out and putting it back on as well.
May 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
How do i disconnect my HBH PV703 Headset from a damaged phone and connect it to another Phone
Step 1 - To reset your Bluetooth headset:
  1. Press and hold down the volume keys "+" and "-" on your headset at the same time, until your hear a beep and the light flashes red and green alternately.
  2. Press and hold down the volume keys on your headset until it is turned off. The headset is now reset as it was when purchased.
Step 2 - To pair the headset with your phone:
  1. Make sure the headset is turned off.
  2. Turn on the Bluetooth function and Bluetooth visibility in your phone (This makes the phone visible to other Bluetooth devices).
  3. Place the phone within 20 cm (8 inches) from the headset.
  4. Press and hold down the call handling key on the headset until it beeps, shows a steady green light and then flashes red and green alternately. If the indicator light only flashes red or green, simultaneously press and hold down both volume keys until the headset beeps and flashes red and green alternately.
  5. If your phone supports auto pairing, press "Yes" when you are asked to add the headset to the phone. If not, check your phone User Guide on how to pair the Bluetooth device. If required, the headset passcode is 0000.
  6. The headset beeps and flashes green when successfully paired.
Jan 21, 2009 | Audio Players & Recorders
My phone will not show it charging and will not turn on, red light flashing
i cant charge my phone using a charger
when i put the head phones in the same port, my phone does not pick up the signal
BUT when i connect my phone to the pc using a usb cable, it charges fine and i can transfer data
WHAT IS WRONG WITH MY PHONE????
Apr 19, 2008 | Cell Phones
Mine started acting wierd and it was flashing on and off. someone told me to press:*and # together with the power button.
Oct 19, 2007 | Cell Phones
Sony Ericsson K320i Cellular Phone Logo
41 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
