Question about Philips Magnavox 27MS343S 27" TV
Hello its me again!!!! model# is FP5251 G105
Im sorry how do i find this Hahahaha tv is open in front and back how do i get to it to solder it from front or back not sure where it is do i need to unscrew something more do i go from the front of tv to get to it or from the back????
  • Philips Master
  • 8,617 Answers
From the back is the best way to get to it.
Posted on Jun 01, 2008
My Samsung Smart TV was shot by a 50 Fps airsoft gun and how do I fix it without paying much
I'm sorry... hahahaha,,, does the kid still have the airsoft gun...??? Same thing happened to my neighbor,,, I think they ended up getting a new one..(TV..not kid).... $$$$$$ ..again,,sorry,,,
Aug 08, 2017 | Sport & Outdoor - Others
We were watching tv and after about 2 hours everything shut down and will not turn on again. There is no sound, and no picture, and no lights turning on in the front. I do see lights on in the back so I...
hello am rico, first you need to open the back of the tv and check the boards for cold solder in the power supply. if you need more help, feel free to call me at 602-810-7149.
Jan 07, 2011 | Hitachi 53UWX10B 53" Rear Projection...
The light on front of my alba tv is flashing and i dont have a clue what to do
All you could do is to open the back cover of the television and check for dry soldering and bulged capacitor... power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will in solving the problem. Take care.....
Nov 02, 2010 | Televison & Video
PT50LC14 Color problem with color too much yellow and green no white or blues can not correct is this the lamp again im on why does it seem that I end up replacing the lamp every year (on number 3 now)....
ok,,your problem is not on the lamp itself.,the problem is on your screen controller.the controller is connected on the plyback you can adjust the screen intensity of the red,green,blue cathode..on your screen adjustment.
May 17, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Tv turns off and on again by itself--safe way to repair at home?
Hello
The regulator is not involved in this problem if the regulator is the defect you cant turn on the tv, but the issue is theturns off without warning, and often turns back on again the switch is also a suspect for this problem, you know in this case we do not look for a one bad parts, maybe the Solder is cold solder, or maybe the tact switch, or some bad capacitor or change value resistor. ill re commend you to look for a qualified electronic technician to clearly diagnose for this problem...
Note.. as i read in this complaint the regulator is good and not to replace..
Angel
Thanks...
Aug 02, 2009 | Televison & Video
Hello again!!!! model# is FP5251 G105
There should be three circuit boards on that model a small board on the right then a larger board in the middle and another large board on the left the vertical IC will be located on the middle board it will be attached to a aluminum heat sink.
Jun 01, 2008 | Philips Magnavox 51MP392H Rear Projection...
Hello thanks the model # is FP5251 G105
Thats the PTV711 chassis phillips magnavox. I would suspect the vertical output IC needs to be resolderd. Its located on a aluminum heatsink and should have vertical stamped on the board near where the IC is located. Often when the vertical drops out it causes the CRTs not to light as a safety feature to protect the tubes. let me know if you need more assistance.
Jun 01, 2008 | Televison & Video
Problem with my Toshiba 32
Sorry, probable bad CRT.....check voltages on CRT board
connected and dis-connected.............Let me know.....T.
Dec 04, 2007 | Toshiba 32AF43 32" TV
Philips Magnovox FP5251 G104 (1995 model)...
if you can remove the screen you probably need to clean the mirror. if that is the case, don't use windex use a very mild solution of dish liquid (3-4 drops to the quart) then you will have to wash it several times with that. any harsher solution will remove the mirror surface. use a very soft , lint free cloth but not terry material. your bath room mirror has the "silver on the back side this one if it glass has the "silver on the front. if it is mylar don't press hard or it will streach and distort the pix. good luck
Aug 03, 2007 | Philips Magnavox 27MS343S 27" TV
RCA F32649 32# TV Troubleshooting Forum
this is an old case and Im sure you have a new TV by now. The problem is the tuner. The grounds are cold and need to be re-heated. The tuner is the little box your cable plugs into. Open the back and you will see where it is soldered to the main board. Heat them back up with a little solder should be three points. while you are in there look around and see if you find more. if that doesnt work then you may have to take the case of the tuner off and look inside for more cold solder joints
Nov 25, 2006 | RCA F32649 32" TV
Philips Magnavox 27MS343S 27" TV Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
