Question about Pioneer DVR-320S DVD Recorder
Need replacement remote for DVR-320-s help...
ML 320 Remote Control doesn't function
Have you tried replacing the battery in it?
Jan 16, 2015 | 2001 Mercedes-Benz ML 320
I have a toshiba ct 90159 - I need the code for a coby dvr model dvd 627
u should be able to
turn the dvr on
press and hold the setup until the light stays on (remote)
hit the dvr botton on the remote the light should blind once
hold the remote towards the dvr keep hitting the on and off button on the remote until the dvr turns off can take up to 300 times once the dvr turns off press the select button and that should fixya up
Mar 31, 2012 | Toshiba CT-90159 Remote Control
My dvr freezes. i have picture and sound but unable to change the channel or anything dealing with the dvr. i have to manually push the system info button on the box then select done with the remote. ...
Believe it or not, this could be a simple battery problem in your remote. When my battery is low in my remote, some buttons will work and some not. I'd try replacing the batteries in the remote first. If that doesn't work, I would guess that you need a new remote. Sounds like your DVR works fine manually, so chances are that's not the problem.
Hope this helps.
May 14, 2011 | DISH Network DVR-625 DTV Receiver /...
The model number for the remote is Sansui DVR 810
Try this website 1-800-Remotes Factory Original.Use ur DVR box as the serial number.They have everythings link to TV- VCR-DVD,and more all remotes.
Oct 22, 2009 | Televison & Video
I need trhe codes for direct tv for my jumbo remote its a dvr box
Here are the Innovage Jumbo Remote codes for Direct TV satellite boxes:
200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217.
If none of these control all of your DVR functions, try adding these DVR codes from other manufacturers:
146, 147, 148, 184
These codes work for Tivo, Replay TV and dvr models made by Panasonic, Philips, RCA, and Sony.
Hope that helps.
Oct 03, 2009 | Innovage Jumbo Remote Control
Archos 604(Gen 4), Remote(Archos DVR Station Gen 5) Work or not?
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR Station, I believe it will for at least the basic player controls on your 604 (except for the alpha keyoard entry because the Gen 4 players did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604 directly (without a dvr dock), the answer is no, you must have a DVR Station for the remote to work on any Archos player.
Hope this helps.
Jun 21, 2009 | Archos 605 WiFi Digital Media Player
Code for a Gateway ADC-320 needed
Hi chris_vau888
You could try these codes :- 1100, 1104, 1185, 1221. If none of those work you could try the philips code lookup finder at :- http://www.urc.philips.com/ You will need the remote model number, either from the front of the remote or in the battery compartment.
Hope this helps,
Mark.
Mar 29, 2009 | Gateway ADC-320 DVD Player
Genesis mx-900
I have the same remote and need to reprogram the remote too.
Genesis X900 has anyone had any luck finding out how to reprogram this remote yet?
May 04, 2008 | Universal Remote Control DIRECTV Universal...
New dvr receiver, remote will not recognize
If you're using the default controls that came with the preset settings for the dvr dish network you selected you need to go in and edit them.
From what I remember, the 520 can go in and learn buttons from other remotes. So you need to go in and look for the setting that allows you to put the controller that came with the dish network up to the 520 and teach it the channel up and down feature.
Basically, it picks up the signal from the remote that came with the dvr and copies it making it the exact same as the original remote that came with the dvr.
Hope this helps!
Dec 13, 2007 | Logitech Harmony 520 LCD Remote Control
Pioneer DVR-320S DVD Recorder Logo
144 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
