Question about iRiver X20 MP3 Player
My iriver start loading then says build library then just freezes whats the problem
Was it just after you had put stuff on it?
Posted on Nov 01, 2010
  • warpholak Feb 08, 2011
    I have the same problem, and yes... it appeared after I transferred some music on the device... Any idea what's wrong
I added to much music and it crashed
I use a microsd to load files that i havent tried on the device before, to test safely. If it crashes then i can simply remove the microsd and clear it. If the "bad" or incorrecly encoded files are loaded onto the internal memory of the device then you will be unable to clear or bypass the "building library" stage and the device is bricked. Take it back to where you bought it and get it replaced if this happens, that's what I had to do when I bricked it.
Maybe we all need to write to iriver and request much improved firmware that allows wiping of the internal memory BEFORE the build library stage as well as the option to disable or an improvement of the "build library" functionality. A simple solution would be to set a flag in a config file whenever files are added to the device and it doesnt do a build library unless the config flag says new files are present and that it is required.
Jul 10, 2010 | Nokia 5310 Cellular Phone
Iriver won't let me upload from CDs and transfer....
go to my computer and open the C drive /create a new folder my music (rename it) ...ok now plug up iriver to pc...again go to start/my computer/ see the iriver drive open it...now you should see all the files on the iriver also...place both window side by side (or top & bottom) and click & drag (or copy & paste) from both iriver and pc...now you can save and copy from either one..........
May 30, 2009 | iRiver H10 MP3 Player
My IRiver MP4 is stuck on "Build Library"
ive searched for hours, i couldnt find a solution..
but i will buy it off you for $30
..i like pulling things apart.. lol
anyway, if your interested, ill pay for postage too, contact me
deano_90@hotmail.com
Apr 26, 2009 | iRiver X20 MP3 Player
Iriver x20 - freezes and wont show as a connected device to pc
When you connect the PMP to the computer does it say your new device is ready for use or something else like 'the device has malfunctioned'?
I have the same issue that frequently the computer won't see the PMP. Keep trying it sometimes works. If not then its likely that the harddisk is dead or dying.
Apr 22, 2008 | iRiver PMP-120 Digital Media Player
Frozen iriver screen
this problem seems to be common
it can happen if you dont safely remove the iriver from the computer
i havent found a fix for this problem anywhere
but ill purchace your iriver if you cant find a fix..
my contact is deano_90@hotmail.com
Jan 05, 2008 | iRiver Clix Digital Media Player
Iriver E10 Reseting Options
can i suggest you try rockox http://build.rockbox.org/ this will give you more than the regular ole iriver software.
but if you really want to start fresh back up the e10 iriver software, format you e10, re-install iriver software, add your media back (i've done this with my kids ipods also..and it works like new)
good luck............feel free to rate if helpful
Jan 03, 2008 | iRiver E10 Digital Media Player
Frozen iriver x20
If your player freezes on "Building Library" (usually a result of putting certain type of .m3u playlists or too big images in id3 tag):
1. Turn the player off - you may need to take the battery out to do this.
2. Hold the menu button in.
3. Still holding the menu button in, press the power button.
4. Keep holding both buttons in until you get a dialogue asking if you want to format internal memory ... say yes.
5. Your internal memory will be formatted and you will now be able to start your X20.
Try to figure out what file is causing X20 to freeze - i've found that pretty much any .m3u file will make it freeze on building library ... only about 2-3 out of about 100 i've tried have worked.
Oct 20, 2007 | iRiver X20 MP3 Player
I've had 2 crashed iriver X20
Hi. I just had solved my Build Library problem. Use my solution on your own risk.
The solution is the following:
1. open up a player (find 8 screws, not 6, 2 of them are on the left side of the player under the round stickers)
2. jently take off a circut board. (you need to access its bottom)
3. Find a memory chip. It is labeled like "samsung k9hbg08u1m"
4. find chip's key meaning start of pin numbering (small circle on the corner). There are 48pins. 24 on the left side (1-24) and 20 on the right (48-25) see chip's manual http://catalog.gaw.ru/index.php?page=document&id=11348 page 4
5. On the right side find pins 32-29 (find them as the second 4 pins from the chip's circle key opposite corner)
6. Connect them together with some metalic wire (don't touch two middle pins on the right side of chip, it is chip's power supply).
7. Holding those pins together connect USB cable to player's socket.
8. After a while player will show error on its screen, get metallic wire out of pins, and then the player will be available as flash storage on the PC.
9. Format flash storage with quick format.
10. Disconnect and assemble the player back.
11. Connect to PC and upload new music.
12. Feedback to fzymarev()yandex.ru
Oct 12, 2007 | iRiver X20 MP3 Player
iRiver X20 MP3 Player Logo
300 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
