Question about York Yankees Bedding MLB Comforter
We have a X301 diamond cross trainer, it switches on but there is no resistance, brake is not working, is their any way we can fix this?without taking to a shop if possible.
Need a repair to crosstrainer
Sounds like the pulley (bearing) in the back is loose or broken
Apr 27, 2014 | Tunturi C80 Elliptical Cross Trainer
Lifefitness cross trainer has little resistance please help?
follow this step and fix it. God bless youVersion:1.0 StartHTML:0000000168 EndHTML:0000001997 StartFragment:0000000515 EndFragment:0000001980
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridgeicon1.png magnet. If not, the magnets have de-magnetized and need to be replaced.Test with the magnet from a refrigerator, If the magnet attract and repulse, is o.k If not replace the magnet.
Jan 10, 2013 | Tunturi Exercise & Fitness
I need a manual for a dynamix cross trainer
http://www.allproducts.com/sports/diamond/Product-2007919144422.html
Jan 09, 2013 | Exercise & Fitness
My goldsgym gs450 cross trainer does not work on any program function. The resistance remains the same. Can it be fixed?
see the instruction and proceed according. God bless you
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
Dec 17, 2012 | Exercise & Fitness
How to increase resistance on Blackburn Tech Fluid Trainer? I know it is supposed to increase with rpm's, but I am not a strong rider and I just rode 90 minutes in my biggest gear with only moderate...
Fluid trainers work by providing resistance that increases as your effort increases, much like riding on the road. There is not a switch or lever to increase the resistance with this specific trainer. So in short you have to put in a bigger effort to get more resistance. Putting in more effort and increasing your Cadence (rpm's) will provide a harder resistance and will decrease your duration attainable. This is OK. One of the benefits of using a trainer is that you can get more accomplished in less time.
Mar 25, 2011 | Cycling
Reebok cross trainer repairs
sorry bro but this surely is a manufacturing defect and i am sure that this problem is due to wrong angular alignment but u can try oil or grease to smooth it out other than that u cant do much as these things have a complex mechanism and design and so require really complex solutions which can cost like nearly another cross trainer sorry
Jun 29, 2009 | Exercise & Fitness
Instruction manual for olympus cross trainer
I cannot get the timer to work on the olympus sport ascent cross trainer.
Jun 28, 2009 | Exercise & Fitness
E1 Error Message on Reebok Cross Trainer
i too have this problem am under the impression there is a problem with the resistance but am waiting on areply from reebok technical support
Mar 27, 2009 | Reebok Exercise & Fitness
York Yankees Bedding MLB Comforter Logo
44 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
Brandon Berry
Brandon Berry
Shehu Pro
Shehu Pro
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
