Question about Garden
Stihl whipper snipper wont start.. everything checks out ok furl spark plug etc
I have a Sthil and the wiper snipper it starts but when I increase the power it seen to either stall or flood plesae help
Posted on Nov 04, 2010
My stihl whipper snipper loses power and cuts out when i try to rev and apply throttle.
With 2 strokes I always start with 'AIR' 'FUEL' 'SPARK' from the sounds of it the choke might be stuck on (choking the motor ha ha) also check the air filter, You have fuel and its moving through but the fuel filter might be slightly clogged. As its starting and going on low your spark unit is ok but you might need a new spark plug.
Dec 21, 2015 | Stihl Garden
My still fs36 whipper snipper runs but wont rev out
The strimmer has a small engine and therefore very small fuel passages that are very easily blocked unless a near-surgical cleanliness is observed when fueling and the air cleaner maintenance is up to date and carefully carried out.
In my experience such fuel-related problems are most likely. It is worth checking the spark plug first considering how much easier that would be. In the case of a blackened condition begin by checking the air cleaner for fouling and the cold start for correct operation.
Jul 17, 2015 | whipper snipper Garden
I have a stihl 2 stroke petrol whipper snipper. It seems to have over heated at the reel end. I have smoke and grease spewing out at that end (metal neck at the reel end) have I fried it?
Sounds like you have a straight shaft trimmer version that have got bad bearing(s) that needs replacing. It probably will take the whole gearbox as a replacement item.
Jan 20, 2015 | whipper snipper stihl fs 38
Sthil fs 38 grass trimmer will not start
does it have spark, compression and fuel.? more info please
Jul 08, 2014 | whipper snipper stihl fs 38
Stihl whipper snipper fuel oil ratio
all Stihl products are 50:1 fuel mixture
Mar 30, 2013 | whipper snipper stihl fs 38
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
My fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jun 28, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Garden Logo
809 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
