Question about Sony KP-61HS30 TV
My remote control will not work despite putting in new batteries. If Lkeft for a few hours it will work a couple of times before not working again.
    Scholar:
  • 143 Answers
Maybe time for a new remote. But first, try some different batteries and make sure there is clear path from the remote to the unit. If you have a universal remote, program it for the TV first and try it. If it works, your other remote should be replaced or use the Universal remote to control the TV.
Posted on Oct 12, 2010
I have a Liftmaster 3265-267, remotes do not work. Tried new batteries in remotes and still no work. When I get close to overhead unit and depress remote, I do hear a couple clicking noises
If the door works from the wall switch, but not from the remote, I'd suspect the battery. (s)
Since you have NEW batteries that only leaves 2 things that can be wrong. Check the program numbers for the remote and the door control board. They need to match.
If you check that and the remote still doesn't work, it could be the receiver built into the circuit board of the opener. Hopefully it's not that since it would need to be replaced.
Make sure the batteries aren't old one that were in a drawer somewhere, that despite being "new" are dead....or weak.
Feb 07, 2011 | liftmaster Chamberlain Garage Door Opener...
Skytech model no. sky-3001 changed batteries in remote and the transciever now i get nothing you can manually get fireplace to turn on using the transciever but when you switch it to remote and try to use...
You have to get the remote and transceiver to talk to each other. Remove all the batteries and wait a couple of minutes
before replaceing them. Place the transceiver in the REMOTE
position, press and hold down the LEARN button, and then
press the MODE button on the remote control. A change in the
beep tone will be heard and you have MARRIED the two devices. Should solve the problem.
Dec 18, 2010 | Skytech 3301 Thermostatic Gas Fireplace &...
I replaced the batteries but the remote does not
Ur Lithium battery fully take in the charges,u recharges?Let the rmote sit without battery about couples hours.Put battery back in again,should work.
Apr 22, 2010 | Logitech Harmony 550 Remote Control
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Dec 23, 2008 | Sony RM-ASP001 Remote Control
I purchased a 7000 BTU portable airconditioner by commercial cool for Haier. I set it up without an issue and was able to turn it on and utilize the remote control to go through all the settings. A...
There may be a master reset switch or combination of buttons to press. The Manufacturer may be able to walk you through this process. Otherwise I would simply exchange it. It sounds like it has a manufacturing problem.
Jun 16, 2008 | Heating & Cooling
Universal remote-rcr3273
Pop the batteries out and use brand new batteries then try the code again. Sometimes its good to let the remote sit for a few hours with no batteries after locking up the codes.
Apr 30, 2008 | Televison & Video
Sony KP-61HS30 TV Logo
94 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
