Question about Ryobi Garden
Hi I have just purchased the RYOBI Doorman HDC11SP and would like to know if it is suitable for my door BEFORE I take it out of the packaging. If it won't work I'll return it unopened. Please explain "Stop Side mounting". I have a bathroom door off the hallway which opens INTO the bathroom. Does this mean the unit is mounted on the side of the door that faces the hallway ? Does this door closer pull the door closed ? I would prefer it to be on the other side of the bathroom door and therefore push the door closed. Thanks for your advice.\ Allan
catriver
  • 878 Answers
SOURCE: Door closer problem ....door pops open
PJ, as long as you don't have any shelves preventing the door from closing, it probably is the cam that sits on the bottom of the refrigerator door. In order to change it out you will have to remove the entire refer side door. Lay it down and replace the cams on the bottom. I don't have a model number here so I can't give you a part number. You will have to remove the top hinge and the door will lift up and off. Then replace the cams, you will be able to see how they go on when you take the door off. Before anything check to see that the door is aligned ok. You have some adjustmet on the top hinge. You also have some adjustment by raising and lowering the front wheels. You can also try lubing the cam that is on there now....Catriver.
Posted on Oct 10, 2007
  • 6 Answers
SOURCE: Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Posted on Dec 07, 2008
  • 4 Answers
SOURCE: remotes quit working for garage door
I had the same problem with my Craftsman opener but different model. However to fix this I simply followed the instructions that came with the opener and reprogramed the remote to the opener. The instructions are in your owners manual and are pretty straight forward.. John
Posted on Dec 11, 2008
  • 3197 Answers
SOURCE: Sear garage door wall mount contol light keeps blinking
One of the buttons has a lock icon. Hold that button in for 3 seconds.
Posted on May 17, 2009
  • 3197 Answers
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
Posted on Jun 01, 2009
How to Choose a Vacuum Packaging Machine?
When purchasing vacuum packaging machine, due to there are too much alternative models, people always become confused that how to choose a suitable vacuum packing equipment? Following analysis is conductive to your choice.
1.To determine the nature of products.
Different vacuum packaging machines are suitable for different products, some products with special properties, such as fluid, powder, granular and lump objects, etc., should not only satisfy the vacuum packaging function, but also asked to achieve better effects of vacuum packaging.
2. To select the appropriate vacuum packaging machine models.
Thinking about the function, vacuum packaging machine has many types, including ordinary ones, rolling ones, continuous stretch film ones and small vacuum packaging machine, etc, according to different production, people can select vacuum packaging equipment that fit themselves.
Different functions: Automatic stretch film packaging machine, single or double chamber vacuum packaging machine, automatic vacuum packaging machine, skin packaging machine, cassette vacuum packaging machine, rolling vacuum packaging machine, air switch installed packaging machine.
Different materials: all stainless steel, semi-stainless steel, ordinary steel, plastic spraying.
Different vacuum pumps: domestic special pump, imported vacuum pump, special vacuum pump. Imported pumps are more expensive, domestic pumps are relatively cheap, customers can choose them according to the practical situation.
3. Whether the power supply of workshop is suitable for vacuum packaging machine.
Some vacuum packaging machines apply to 380V power and some are suitable for the 220V power. If the power is too far away from the vacuum packaging machine, longer wires is required, and this situation may cause inadequate voltage, affecting production. Therefore, people should buy vacuum packaging machine according to the power of their factory.
4. Evaluate quality and after-sale service, etc. of vacuum packaging machine and choose cost effective vacuum packing factory, since this will reduce a lot of trouble for use.
5. Before purchasing a vacuum packaging machine, purchaser should consult with manufacturer on parts supply problems, to avoid delay in production caused by the malfunction of vacuum packaging equipment.
Dec 21, 2016 | Vacuums
My battery charger just does not work anymore! I have the two batteries and charger that were purchased as a package with my drill. I bought many other pieces to add to my Ryobi family.
Receipt will do nothing for you if it is out of warranty. Normal warranty is for three years.
Write to the company regarding your situation - see if your unit has a serial number that can give indication of age of unit. Perhaps they will replace the charger for you.
Make sure that the charger cord/connections are good and that unit is receiving power from wall.
Sep 17, 2016 | Ryobi Two 18V Lithium-Ion Batteries +...
Sport trac 2003 will not start solenoid
Check your coil pack for any cracks in the plastic mold especially on the bottom u will need to remove it to inspect it there was a bunch of bad coils that were made for about 6 months that failed within a week or two of purchase if it\'s bad but an OEM Ford coil pack. Don\'t buy standard doorman and all that stuff built in Mexico. They don\'t care about quality control.
Dec 14, 2013 | 2003 Ford Explorer Sport Trac Door Lock...
Will my wireless bell push work with another manufacturers door chimes?
Doubtful they are compatible. If they are set by dip switches and you set them the same bot doesn't work-not compatible.
Jul 17, 2012 | Home Security
Does anyone know where I can get the 9 tooth chain sprocket (not the one on the unit) for a Doorman 455?
If you are looking for the sprocket that goes on the door end of the T-rail you can call any Chamberlain or Liftmaster dealer in the yellow pages. They might even sell you a used one off an old opener they have changed out.
Oct 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Air conditioner compressor locked up and broke Serpintine belt. How can I reroute a belt to avoid the compressor? Will I need to remove the compressor?
Hi Friend:
To avoid the Expense of Replacement of A/C Compressor, DOORMAN Company Has a By-PASS PULLEY that you can Use To eliminate the Compressor Completely.
Just call some of your Local Auto Parts Stores and Be sure to Tell them that =DOORMAN is the Co. That makes this By Pass Pulley.
I'm Sure you'll find it.
Please let me know How my Solution has Helped you By Voting for Me and a Testamony.Thanks for using FixYa
Aug 17, 2010 | 1994 Ford Taurus
Automatic Doorman model 455 learn button location?
The button should be on the back of the motor unit. You may have to remove a light lens to find it.
Aug 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
Dell monitor model 1907fpt not recognized in Ubuntu OS and defaults to 899x600. Am not able to find suitable fix on line. Please advise. thanx!
I had a similar problem with my monitor.. I installed the nVidia graphics package from the Package Manager and then upped the resolution .
You'll have to make sure you know if your graphics card is nvidia or ati, though..
Hope this helps
Chris (ziraffa)
Jan 07, 2009 | Dell E173FPb 17" TFT LCD Monitor
Lost instructions & templates.
you can fined it here cheers peter ,,http://www.ferret.com.au/c/Locks-Galore/Ryobi-door-closer-range-available-from-Locks-Galore-n665613
Sep 23, 2008 | Ryobi Multi-Volt Battery Charger
Garden Logo
158 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
