Question about RCA Lyra RD2763 MP3 Player
FILE SYSTEM ERROR MESSAGE
Hi i had the file system corrupt message too, did your make a spinning sound too? I really liked this player :( i took your advice and when i opened it up it looks like the part with the pins wasn't attached to anything , was it supposed to be glued do you think or did it work with pressure from the battery holding it againt the other part. Any advice would be great :) ThaNKS!
  • 8,596 Answers
Glue = bad
Put the player back together and do this:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Jul 06, 2008
File system error: FAT is corrupted
Your hard disk on your media player is corrupted which also does happen on a normal PC/Laptop. To fix it, use windows explorer -> right click on your mouse againt the media player drive -> select properties -> select 'Tools' tab -> select Error checking / Check now -> Tick on 'automatically fix file system errors and recommended also 'scan for and attempt recovery of bad sectors' -> Start.
At this point, you may also need to restart your PC/LAPTOP and then be patient as 120GB is a fairly large drive to repair! Once the FAT has been repaired, depending on the corruptions, you may need to replace some songs, video, photos or other files.
ps. the other 'drastic' option is of course to reformat the whole Media driver drive !!!
Dec 18, 2009 | Archos 5 MP3 Player
File error 65535
Sounds like you have some corrupt windows files. I think you may also have a black logon screen and problems running programs as an administrator.
To solve this issue, first, boot your computer in Safe Mode. Do this by pressing F8 before the Windows Logo shows up during boot-up. Then, run Command Prompt as an Administrator (found under Start Menu > All Programs > Accessories - right click and select Run as administrator). Then all you have to do is type this:
sfc /scannow
(Space in between sfc and the /)
Then press Enter and the computer will fix itself. This is called the System File Checker Tool and it checks all Windows files for any corrupt or missing ones.
Hope this helps...
Good Luck!!
Mar 18, 2009 | Microsoft Windows 2000 Server
Error message
Whenever this happens on a GPX mp3 player it means you have to take it back. The hardrive is either corrupt or the files you might have downloaded on it are not compatible with the player. Try "mp3' and "wma" files and see if it works. I had this same problem so I took mine back for another mp3 player. Hopefully you still have your recipt so you can take yours back. Sorry if this wasant really helpful to you. I hope you can get a refund.
Mar 17, 2009 | GPX MW3836 MP3 Player
My Mp3 Player Is Messed Up !!!
It sounds like your databasse have been corrupted..what you will need to do is to format the device using your windows media player..once your format it transfer the songs back t your device..
that should solve the problem..
I hope that helps
Please rate accordingly
Thank you
Computerrep
Dec 18, 2008 | Audio Players & Recorders
Oli mp3 player
hi!
in your case, there might a system file on your mp3 player that was corrupted, you really have to backup your file, copy all your files from your player to the pc and format your player.
Oct 29, 2008 | iLO (2 GB) MP3 Player
ONLY THING IM RCA H115A
I had the same problem and I tried many things to fix it. Mine started working again when I took an old speaker and turned it face down, then put the mp3 player face up on the magnet (face of MP3 away from magnet). I checked back a few days later and it was working with all (or maybe most I haven't really checked) of the files intact. I thought it might wipe out all of my files but figured that if I could get it to work again it would be worth it. This might be extreme but I tried running it out of battery which didn't work and pushing different buttons in different sequences which didn't work either. I tried pressing buttons simultaneously and for extended periods looking for some sort of reinitialization process but nothing worked....it just kept coming up with the corrupted message. I think it got corrupted when I removed it from my PC without doing the "SAFELY REMOVE HARDWARE" process on my PC. I won't be doing that again. I am really glad I didn't throw the thing away!
Dave
Aug 24, 2008 | Audio Players & Recorders
Transferring music from pc to mass storage device.
You said that you checkd the properties of all the 150 tracks right.
150 tracks is 560 MB.
The error message you are getting informs that there is nothing wrong with the player or something.
This eror rfers that the source file cannot be located by the system to transfer or the source file is corrupted.
Try the other source file.
Try transferring the other newly downloaded file.
Hope it helps.
Good Luck.
Live, Love, Laugh.
May 13, 2008 | Audio Players & Recorders
..file system corrupted...
if you specify "corrupted" then i may be able to help what exactly happened?
Mar 01, 2008 | RCA Lyra RD2765 MP3 Player
Computer wont start up
looks like your hard drive is malfunction. The funny sound. does it sound like someone is scratching with her nails on metal?
Dec 08, 2007 | Computers & Internet
File Sytem Corrupted!
The dreaded "File System Corrupted" error is one that comes time and time again. Did you drop the player or hit it by accident? If so, then the pin connecting the battery to the micro hard drive has probably been disconnected. You can removed the back of the player with a screwdriver, but you risk tearing off the S/N sticker. If you decided to do it anyway, remove the back of the player and then simply fit the multi-pin connector back into the hard drive. Replace the back and screw it in, and then turn it on to see if it works. I did this with my old RD2762A, and it worked like a charm. Hope this helps!
Sep 27, 2006 | RCA Lyra RD2763 MP3 Player
RCA Lyra RD2763 MP3 Player Logo
44 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
