Question about Yamaha RX-V657 Receiver
I have a Yamaha RX-V657, I connected only two speakers (Pioneer CS-J625) in A (Front) and selected A Speakers. There is no sound. I did the same but connecting the same two speakers to B, selected B and again there is no sound. What can I do? I need your help please.
  • carlos_co476 Oct 15, 2010
    I'd checked everything with the equalizer and there is still no sound. Also I noted that the display is turning off when the turner is on.
  • 2,973 Answers
Carlos, Is there some setting in the equalizer? To me it seems that the equalizer has not been set properly. Some bottons pressed wrong on the amp coukd be another reason. Dont you have a bookle on it?
Posted on Oct 12, 2010
Yamaha Receiver RX-V371 broken speaker wiring connection on the back, what are different solutions?
That unit give you the option for a second set of speakers ?
If so , connect to Output 2 ( or B) on the speakers connections and select Spkr 2 ( or B) from the front panel
Dec 16, 2014 | Yamaha Audio Players & Recorders
My problem is conect bose 901v to reciver yahama rx-v657
If you cruise around fixya solutions you will find a number of MY postings for many different receivers.
The difficulty you face is that the RX-V657 lacks the necessary Pre-Outs to feed the Bose 901 Active Equalizer which would feed the necessary dedicated amplifier you will need to route Front Channel programming to the 901's and ONLY the 901's without affecting anything else that flows through the RX.
I have 901's in my multichannel rig alongside 301's and a subwoofer. I know what I'm talking about.
Aug 25, 2011 | Bose 901 VI Main / Stereo Speaker
Yamaha rx-365 reciever not showing all speakers
I,m not familiar with the Yamaha but most receivers are set up the same way. In your setup menu are the speakers marked on in the display?. Your DVR needs to be transmitting in 5.1 to start with. If this is the case then make sure you select the correct audio function on the receiver.
Mar 04, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Front speakers no sound!
Most likely you have pressed the speaker AB switch, try pressing it again and see if it works.
Mar 11, 2009 | Yamaha RX-V663 Receiver
Front speaker output is not working
Firstly ensure that the 'mute' has not been accidently engaged.
Have you tried connecting other speakers to the same output and cables? If the sound now works, the problem is with the speakers (providing all amplifier settings are correct and wiring is correct). It would be highly unusual to have a problem with both speakers or two sets of cables. Alternatively connect the problem cables and speakers to an alternative source. If they work on an alternative, you are looking at an amp issue.
Aug 29, 2008 | Yamaha RX-V890 Receiver
No zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Jun 29, 2008 | Yamaha RX-V995 Receiver
How to run outdoor speakers from my in house receiver
If you have a button for A and/or B speakers on the front of your unit, then use the A (or B) speaker connections for the inside speakers and B (or A) speaker connections for the outside speakers. Then of course you just select either A or B depending on where you want the sound to come out. If you select A and B then it will come out at both locations. If you don't have A/B speaker selection available on the unit, then you will need a speaker select switch (from Radio Shack) or else wire up a four pole double throw toggle switch to do the job.
Jun 03, 2008 | Yamaha RX-V2090 Receiver
Cannot figure all of the setup instructions
is your problem setting up? connecting the speakers and sources or you have made the speaker connections but to make it sound is your problem... pleased let me know.
Mar 31, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V657 Zone 2
Suggestion by clarkent22
I called and spoke with Yamaha support staff (Chuck) who was very helpful. I was able to get my issue resolved hopefully this works for you too.
Couple of solutions:
1) Go into the Menu setting (Manual SetUp/Speaker Set) and make sure that you do not have Presence Speakers or Suround Back Speakers
2) Also in the Menu settings (Manual SetUp/Options/Multi Zone Settings) make sure that your Zone 2 Amplifier is set to "Int" (assuming you are not using external amp
3) Zone 2 can only accept an analog signal (not digital)... so there are two steps to this one. First, make sure that you either run only analog, or if you run digital and analog then you need to select "Analog Input" on the front of the unit. If yours was working earlier, my guess is that your input settings got switched to digital (or auto) You need to have analog set up for each specific external source (DVD, Cable/DTS, etc)....
4) This model receiver will only let you control Zone 2 with the remote control. You can power it on the receiver unit. But to select your source you have to press the Amp button, then the ** button. Then you control Zone 2 and you can toggle sources and adjust volume. (Check your owners manual for programing remote for zone 2.. think I pressed the "code" button and then 2999.)
Hope this helps... it worked for me If not call Yamaha they were very helpful.
Oct 13, 2007 | Yamaha RX-V657 Receiver
The receiver shuts down when zone 2 is turned on
Disconnect the speakers on Zone 2 and try to turn on the receiver again. If the receiver works, there is a shorted speaker wire, pinched wire, or a blown speaker on zone 2. Good Luck
Jul 01, 2007 | Yamaha RX-V657 Receiver
Yamaha RX-V657 Receiver Logo
118 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
