Question about Pc America Restaurant Pro Express
The screen says we can close due to open table, but all checks are closed
    Sergeant:
  • Pc America Expert
  • 310 Answers
In your setup, you can tell system to ignore open invoices and process end-of-day report. But double check that you don't have an invoice on hold.
B Mattern
sysadmin@ccybernet.com
Posted on Oct 12, 2010
I have a lanier 7328/7320. It reads side door open on screen. Only the door is closed. Any suggestions
How are you? This is a problem with front door switch.
Remedy
  • Place the machine on a level table and make sure all the four stands are landing freely on this table.
  • Check that the front door notch that closes the door switch is not broken and if it is replace that particular door or modify the notch.
  • Make sure the upper half of copier is well locked with the lower bottom part.
If all the above is correct, and still reads open, replace the door switch.
Good luck.
Nov 15, 2010 | Lanier Office Equipment & Supplies
Screen goes black when opened fully, reappears when closing it
The problem you seem to have is the thin wires that carry the picture to the LCD screen may be broken or making and breaking, you certainly wont be able to repair yourself, get it to a good camera shop for first aid.
Jun 11, 2010 | JVC GR-D850 Mini DV Camcorder
Restaurant Pro Express - Will not let me do "End of Day". A Message pops up that says: "There is still 1 table currently open. Please close these tables before running End Of Day Function." I never set...
Just uncheck the option to have the End of Day check whether there are open tables.
Go to Manager/Options -> Setup -> Setup Screen -> System Access -> Time Clock -> and check "Ignore Time Clock"
Jun 09, 2010 | Pc America Restaurant Pro Express
When you to start the microwave the screen tell you the door open even though the door is close.
you need to adjust the door travel adjustment on this micro-switch,if its open and registering open the control board will not let the unit start due to R.F. radiation safety concerns,you should adjust the door and after it starts to operate,have the R.F. leakage at the door checked to make sure your safe and till so don't stand too close till its certified so
Apr 26, 2010 | Whirlpool GH5176XPS Microwave Oven
Disc table does not open or close - stuck open
Hello the unit is out of timing now, it will have to be taken apart and retimed. You have skipped some gear tracks and the unit will not close until the Tray is realigned. Try hitting the eject button so the tray comes all the way out then pull on it gently to see if it realigns it self. When it trys to go back in it is hitting the clamper because the tray has not reached home and the clamper that gasps the disk is closing before it has a chance to return home.
Nov 30, 2009 | Pioneer BDP-95FD Blu-Ray Player
On our rpe system there are some tables that will not closeout and are showing active for several days the same item(s) ring up at different prices
Sounds like two different problems. The tables not closing out are probably one of two things. The invoice got put on hold or the cashier trying to close the table didn't open the table or doesn't have correct permissions to close table. Worse case scenario is a corrupt entry in database.
Different prices on same item could be someone playing with the special pricing on the item or if you have time based menus setup, they are actually pointing to different items that display the same.
I program rpe menus remotely and could give you a hand. Contact me at sysadmin@ccybernet.com or call 814-226-9612.
Oct 07, 2009 | Pc America Restaurant Pro Express
Count the number of open and closed order status per owner
My suggestion is to use a Pivot Table.  Follow these instructions:
Click on column A1 - then in the menu bar click DATA > Pivot Table and Pivot Chart Report.
Click NEXT on step 1 of pivot table wizard.
For step two you will want to highlight all of the data on your sheet.  then click next.
Choose NEW WORKSHEET for step 3 of the pivot table wizard and click finish.
Once the Pivot Table sheet opens, drag the STATUS field into the top left corner of the pivot table view, where "drop column fields" and "drop row fields" meet.  Next drop another instance of the STATUS field into the "drop row fields here" column.  And lastly drop the OWNER field into the "drop column fields here" section.  You should now be viewing a report showing you exactly what you were looking for.
Regards,
Joe
May 07, 2009 | Microsoft Excel for PC
SAMSUNG SGH-U600
Probably due to the flex cable that connects the screen to the main board failing.
My phone was fine when closed, but went bonkers as soon as I slid it open. I replaced the cable and now all is back to normal.
Nick
Oct 01, 2008 | Samsung SGH-U600
Computers & Internet Logo
112 people viewed this question
Top Pc America Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
sunil dixit
pravintechno
Level 1 Expert
Are you a Pc America Computer and Internet Expert? Answer questions, earn points and help others
