Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover steam cleaner F5912-900 not sucking up water
Everything else seems to be working just fine and I've checked to see if evertyhing is attached but it's still not sucking up any water into the recovery tank.
  • Anonymous Jun 07, 2008
    water is not being sucked up
  • fastcatz007 Sep 11, 2008
    I have the same problem. There is no suction to be felt from the bottom.  Everything is on properly and was cleaned, just no suction.  Now I am left with a tankful of water on my carpet.
    President:
  • 1,673 Answers
Check to make sure that the lid locked down all of the way around. If yours has a foam filter on the inside of the recovery tank lid, make sure it has at least a 1/4 in. gap from the top. There is a filter, from the bottom, has a red casing, remove it and clean it. Also make sure that the removeable duct in front of the recovery tank is in place.
Posted on Jun 01, 2008
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
My steam cleaner wont pick up water i have checked everything and its fine but still isnt sucking up water
Well Sexy mama ..are there any on~board screens that require clearing? Pet hair clogging up vac wand end? Is there vacuum power for attachment hose? Also, check that the wand /attachment switch is to vacuum and not set for attachments. Good luck !
Apr 30, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
Bissell is not sucking up the water
Chech ut his link and this might help to solve your solutions. Hope this helps you.http://www.bissell.com/Search/FAQ.asp?FAQCategory_id=&FAQCriteria=water+wont+****&FAQSubCategory_id=&SearchMode=&SortMode=&btnSubmit.x=23&btnSubmit.y=9&FAQ_id=612
Aug 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Hoover Steam Vac leaks like a sieve
I have the same problem with my hoover steam vac, different model but same problem. So I have had it for 2 years and never used the attachments because the thing leaked out the bottom when i tried. So today I tried to find a solution online and found nothing. So I started toying with the thing and found a solution for my model and I hope it will work for everyone else. I don't have a stair attachment so this goes for the upholstery cleaning attachment. I noticed right where my upholstery attachment connects to get soap, there is a second hole that is covered by a white rubber seal when the cover for the connection area is closed. I put a plastic bag, or anything to seal it, into this hole to make a tight seal. Tried the machine and worked like a champ. So Would be nice if hoover supplied a plug for that, but oh well worked for me hope it works for others with a hoover steam vac.
Jan 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Agility steam cleaner
Sounds like you have a broken water line, or it just came off. You would have to remove the top housing to get to the water lines. Or at the bottom of where the solution tank sits on, is the reservior asm. there are lines going there also. Bottom of the tank, the valve is stuck open. The trigger on the handle is stuck pushing down on the reservior asm.
Jan 29, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
One thing to check is the filter on the inside of the dirty water tank. It must have a 1/4 in. gap from the top to the top of the filter. Also make sure that the lid to the dirty water tank is on and sealing all the way around the tank.
Jan 09, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
409 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
