Question about Fujitsu Plasmavision P42HHA10 42 in. Television
Does philips P42HHS10AS plasmavision have a switch on the lower corner?
How to playback videos on fb on small or large screen
Usually, in the lower right corner there are 2 arrows pointing upper left and lower right. If you click that, the video should go smaller.
YouTube videos have a 4 cornered frame in the lower right corner that switches between full screen and regular.
Feb 16, 2015 | Toshiba Satellite Computers & Internet
A red light is on at the lower-right corner, with a shape of the heads. does it mean it is time to relace the heads? how does the machine know?
It's menas that you change new replacement heads. That philips arcitec 1060 electric shaver replacement heads is Norelco RQ10 shaving heads.
Jul 30, 2011 | Philips arcitec 1060 Electric Shaver
42 Fujitsu PDS4221W-H, no power
A user manual is available from this link:-
http://safemanuals.com/user-guide-instructions-owner-manual/FUJITSU/PLASMAVISION%20PDS4221-_E
Check for a hidden power switch under the lower left or right under corner of the screen, ensure it is ON (- not sure if this switch is fitted to your model, but it does exist on other Fujitsu models).
Fujitsu no longer support or manufacture plasma screen TVs - therefore no parts are available from them. [Fujitsu only serviced to board replacement level - very expensive].
The Fujitsu models (generally, after 4 or more years use) suffer from cracked solder joints on circuit boards (due thermal cycling stress).
See Fixya tips:-
"Fujitsu Plasma 42" random shutdown - continuous flashing red led".
Oct 28, 2009 | Fujitsu Plasmavision 42" TV
Help
try this code 062596 then push Menu button or to switch from comercal to consumer try this code 024995 check line line 10to see witch mode your in.
Sep 02, 2008 | Philips 27PT6441 27" TV
No power no red or green light
Check the hidden master power switch is 'on' - located under the lower left hand corner of the screen.
Aug 20, 2008 | Fujitsu Plasmavision P42HHA10 42 in....
FUJITSU PLASMA P42VHA30WS
Double check the hidden power switch on the lower left corner- in is on.
Nov 12, 2007 | Fujitsu Plasmavision 42" TV
Fujitsu Plasmavision P42HHA10 42 in. Television Logo
15 people viewed this question
Top Fujitsu Televison & Video Experts
Tony
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
