Question about Canon EOS Rebel K2 35mm SLR Camera
Studio lighting what kind of lights work good, other then professional lighting.  flood light? spotlight? fluorescent light? if so what watts
    Problem Solver:
  • 13 Answers
All of the lights refered to have color issues ie: the pictures will look washed out using flood or spotlights, and green or blue using flourescents. While you can filter out the colors, and do a white balance to correct for lumenosity differences, these corrections will adversely affect everything else in the pictures. With the digital revolution in full swing, much pro quality lighting and cameras are now available on sites like E-bay at great prices(my $2,000.00 Bronica ETRS now sells for $250.00), so look for some used pro lighting units and avoid the headaches that using household of industrial style lighting units will cause. Get a B&H catalogue, and then look for these items on E-Bay.
Posted on Jun 11, 2008
How do I change the bulb in a 2m series spotlight?
replace bulb with 12 volt, H3 100 watt only
See the pdf of the manual I uploaded.
Sep 16, 2014 | Stanley Sl2m09 Rechargeable Spotlight...
Tip
Fluorescent lights, particularly older Compact Fluorescent Lamps, emit copious...
So, your remote isn't working? Is it the TV or is the remote? If these questions apply to you, then read on!
Nearly all TV remotes use Infrared (IR) light to transmit your requested operation from your hand to the TV, like magic. We depend on them for our viewing pleasure! Sometimes, when our trusty remote stops functioning, we grab a fresh set of batteries and POW!!!... nothin'...
You can quickly check your remote to see if it is functioning using only 1 item... a digital camera. It doesn't need to be fancy or expensive... heck, you can use the camera in your second best friend... your cell phone!
Simply fire up your digital camera and aim your remote at it. While looking and the transmitter of the remote through with the camera LCD display (not the view finder), press a button. Did you see the transmitter light up? If so, the remote is functioning!
You can't see infrared light, but your digital camera can... pretty cool!!!
Take a look at the video to see this test in action. (click the video a few times if it does not start.)
on Jun 11, 2010 | Televison & Video
Fixture not working after bulb change
"CFLs" Compact Fluorescent Bulbs (with built in ballast) must be labeled as dimmable to be used on a dimmer circuit.
Traditional fluorescent fixtures must have a dimmable ballast installed inside and can be used with standard fluorescent lamps.
Fluorescent lamps must be sized to match the ballast. CFL's are matched at the factory, but others are not. Older fluorescent lamp fixtures have a ballast inside. A type rating is to operate (2) 48 inch / 40 watt lamps. Newer fluorescent lamps are rated for 32 watts, and these will not work - or will have a greatly reduced life.
If you installed CFL's, the first thing I would do is install regular incandescent lamps and see if it works as expected. If not, something else is wrong - otherwise - make sure you've got the right lamps in the fixture.
Mar 17, 2014 | Electrical Supplies
Flood lights in back yard not working
Which kind of flood lights? Long time lighting during whole night or security lighting sensitive to people walking across.
If it is for long time lighting, you should select the fixture lighting source as compact fluorescent, led or small wattage HID lamps, this kind of fixture you do not have priority requirement for instant on, the following fixture is just for reference.
http://www.bulbspro.com/vista-10040-35w-hps-wall-fixture-w-photoelectric-eye-bronze.html
For security purpose, you need the flood light right away reach full brightness, normally you take following fixture with halogen bulbs.
http://www.bulbspro.com/vista-10031-motion-sensor-twin-light-control-kit-white.html
Nov 10, 2013 | Dishwashers
Hi Ive got a Lutron Grafik Eye 3000 controlling
I need more information. Are the fixtures pot lights? What kind of bulbs are you using? Floodlights, spotlights, incondescent (normal tungsten filaments) or fluorescent, compact fluorescent, led etc. Since most dimmers say in their instructions that they are designed for incondescent lighting only the bulb you use can either blow up the switch or cause troubles like you are specifying. Also inside pot lights are thermal cutoffs that trip and reset when the light is cool again. Can you remove the switchplates and see where it says incondescent only embossed into the aluminum heatsink? If it says something else, what does it say?
Aug 01, 2013 | Lutron Electrical Supplies
What kind of lighting should I use for a boa constrictor?
I recommend using either a low wattage bulb or a fluorescent tube. Any bulbs exerting over 15 watts must be covered to prevent burning your snake. Ensure that the lighting is turned off at night - you may want to invest in a timer for this.
Sep 04, 2012 | Aqueon Reptile
How to change the light
There are three different models... two wall models (the WL24 and the WL36) and an island model (the IS24). The instructions for changing the lights on all three models are the same.
Light bulb:
  • Make sure your hood is disconnected from the main power supply.
  • You may see a screw at the edge of the light cover. Unscrew it and remove the light cover.
  • Replace the light bulb with the same model as the original. There may be a decal near the bulb that indicates its rating. Don't exceed 25 watts! It's best to bring the old bulb to your store to have it replaced exactly.
Spotlight:
  • If you don't see a screw, then - using a screwdriver - lever the support ring, then grasp it & pull it straight down and off. This ring supports the glass cover - remove it as well (don't drop it!).
  • Replace the lamp with the same type (12V, 20W, G4 fitting).
  • Replace the glass cover and the support ring - it should snap back in.
Fluorescent light:
  • This needs to be changed by a qualified installer. Don't attempt it yourself.
Mar 02, 2011 | Futuro Altair Kitchen Hood
A 40 W fluorescent lamp gives out more light than a 4o W filament bulb.explain whether the fluorescent lamp is actually using electrical energy at the same rate as the filament bulb??
The lamps are both using 40 watts of energy, but the fluorescent lamp gives more lumens (visible light measurement) than the incandescent.
Fluorescent gives at least 5000 lumens for 100 watts.
Incandescent gives 1750 lumens for 100 watts.
You can see that if you had a 100 watt incandescent, it would be 1750 and you would only need 35 watts of flourescent.
Gary
Feb 19, 2011 | Vacuums
Have 3- 13 watt mini spiral bulbs on fixture. When switch in auto mode, lights hum, flicker and not maximum brightness. When switched to on position, lights stop flickering and humming. Full brightness as...
-Replace the compact florescent bulbs with regular incandescent bulbs and see if problem continues.
-Lighting controls are made for different kinds of bulbs.
-Your package should say what the watt rating and type of bulb.
According to the PR180 manual:
-I am looking at the Leviton PR180 occupancy sensor manual, and the PR180 sell-sheet, and these documents say for incandescent and fluorescent (rapid-start magnetic ballast only).
-Compact fluorescent are supposed to have a magnetic ballast.
-The manual does not specifically say it works with 'compact fluorescent'
-The manual does not say there is a minimum amount of wattage either. Some controls will not work correctly if the overall wattage is low. Your overall wattage is 39watts.
Read the product package (if this is a new installation and you have the package)
Try the incandescent bulbs.
If the PR180 is not your product, add a comment with product number and I'll look for information
Nov 06, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
3-light LED spotlight kit with remote solar panel #555-208
The Spotlight kit should still be under warranty for at least a year through the manufacturer. Check your manual and contact the manufacturer. The problem might be the seal which is allowing water in and therefore it needs to be replaced
Sep 10, 2008 | Spotlight Aquascape Water Proof LED 2-Watt...
Canon EOS Rebel K2 35mm SLR Camera Logo
55 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
