Question about Stanley Bostitch N75c1 Coil Sheathing Siding Nailer
My Bostitch N75C coil nailer jams regularly with 2.5" galvanized casing nails, occasionally with 3" casing, rarely with 2.25" ring siding nails and 2.5" common, never with 3" common. I have to drive the pin back with a drift to unjam the nail. Running 100 psi. It also sometimes throws a nail out of the feed mechanism. Only 2 months old, no heavy use. A few drops of oil daily when in use.
  • 1383 Answers
SOURCE: nail would not shoot out
The problem that you describe is caused when the driver is not returning all the way back up to the top of the cylinder not allowing the nails to enter into position . You may have one of several problems including worn piston oring, bent driver, worn check valve, worn lower bumper, or low air pressure. Simple test is to manually push the driver blade back to top using a thin piece of metal that fits into bottom of gun. Be sure to disconnect from air supply when doing this. Good Luck
Posted on Jan 08, 2009
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Posted on Feb 20, 2009
comax
  • 154 Answers
SOURCE: Leak inside Bostitch N80 Nailer, won't drive nails
If the unit is leaking it most likley need a rebuild kit. Go to a Bostitch service center and ask for an ORK-11 kit. That is all the o-rings needed to do an over haul. Or just have them do it.
Posted on May 28, 2009
smjdragonfly
  • 79 Answers
SOURCE: Stanley Bostitch Coil Framing nailer blows head off of nail?
Make sure that when you run with one gun that your psi is between 90-110. You may need a kit. Is it an RN45 or 46? Go to Stanley Bostitch online and look up parts and schematics. Kits should only be about 15-20 dollars, easy to put in, and come with instructions. Lemme know. Please rate me
Posted on Jun 18, 2009
  • 87 Answers
SOURCE: instruction sheet or manual for Bostitch RN46-1 nailing gun
instructables. com
Posted on Jul 28, 2009
How can I stop a RN46-1 from jamming
We often see jamming with stainless wire collation - the problem is almost never the gun, it is because the stainless wire is much harder to shear off than regular steel. I would suggest trying another brand of nail and see if that helps.
Also, yes, the trigger is all that is required to change it to sequential, it is a very easy swap.
Jun 15, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
New nailer double firing and jaming
Some trigger valves (tva6) are sensitive (defective?) however there are some things you can try to change how the gun acts. I have noticed that the brand of oil has an effect on the orings. Some brands will swell the orings, I like Paslode nail gun oil. Do not wash the gun with gasoline or wd40. Use diesel. Change the nail depth setting one position. Lowering the air pressure will make a difference. I find that most operators use too much pressure. A stronger safety spring under the trigger will separate the trigger and firing pin quicker. Finally you could use single fire trigger. Good luck
Jan 16, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
I Have a N80 Coil Nailer. It was given to me without the manual. I down loaded a manual, however it is not clear how to set the nail depth. Can you advise?
Bostitch nailers used three methods to adjust how deep the nail will set. On stick nailer, there are one or two screws on the lower contact arm allows you to shift up or down. On coil nailers and others , there is thumb screw on side or under the trigger. Finally on some coil nailers, there was a series of spacers that snapped onto nose of the gun. Good luck
Nov 21, 2012 | Stanley Bostitch N80s Nailer -rebuild...
Hi i have a problem with my stanly bostitch nail gun .i was using it ok for a little while then the nail stop coming out ,now all i hear is a putting sound only ,sounds like no air ,but my compressor and...
Your nailer model number is N75C-1 shares design features with many other bostitch coil nail guns. Usually, when you only hear a puff of air coming from the trigger area or within gun, the driver or headvalve is stuck. Usually easy to fix. First check the driver by removing air supply and inserting metal rod into nose of gun pushing the driver all the way up to top of cylinder (open latch and note position of driver, should not be visible). If driver is stuck due to debris, clear and retest gun. If driver is all the way up then remove head and see if the driver moves down (should move with light pressure). Headvalve should move inward with strong thumb pressure and move back out. Repair as needed and lube with silicone paste lube (sold at Lowes in plumbing department and swimming pool supplies). If both driver and headvalve look ok, then suspect trigger valve under the trigger. Good luck
Sep 19, 2011 | Stanley Bostitch N75c1 Coil Sheathing...
I bought a used Bostitch nail gun. Model/serial # N6408406208021. What parts do I change to go from a 1 1/2 inch nail (approx. #6) to a 3 inch nail (approx. #16)? Where do I get the parts?
I do not think that the n64 will take a 3" nail. N64 will most likely fit a 2 or 2 1/2 inch. To verify the length of nail open latch door and measure the width of the slot into the barrel. Take a look at the bostitch n80 series of nailers for more power and longer nail.
Dec 18, 2010 | Stanley Bostitch Coil Framing Nailer
I just bought a used Bostitch Coil Nailer. 3 1/4" nails work fine but the 2" nails will not keep feeding.
Check the spacing of the nail collation between the two nail sizes and also the spacing of the copper wires. Some nailers have a different setting for the check paws on the latch door to compensate for the thinner nails (too much clearance between the latch door and body of gun). Check manual at www.bostich.com for proper setting of check paws between nail types. Good luck
Oct 12, 2010 | Stanley Bostitch Coil Framing Nailer
Do I need to lubricate my Bostitch F21PL nailer from time to time? The reason I asked is, I got this new nailer. Installed Galvanized 2.5 inches nails from Bostitch and with the metal connector installed....
This is a fantastic nailer, very powerfull. Information about your nailer can be found below.
http://www.bostitch.com/default.asp?CATEGORY=BOS_FRAM_NAILER&TYPE=PRODUCT&PARTNUMBER=F21PL&SDesc=21%26%23176%3B+Industrial+Framing+Nailer+System
You should not need to lube the rails for the nails to feed. Your nailer uses plastic collated nails and should travel very easily inside the rails. I would remove all the nails and check for broken pieces of plastic from nail strips. Feeder should feel snug within rails and not wobble and spring should pull tight. When you install the nails do not release feeder against the nails with force as this could break the plastic strips and cause jam. Nail not feeding is usually caused by wrong nails, weak pusher spring or pusher guides broken /missing. Simple test for proper nails.
Place a strip of nails on the outside of the rails aligned with the edge of the rails and see if the first nail is perfectly aligned with the path of the driver. If the head of the first nail is angled back slightly from the path of the driver, the nails will not feed properly. Good luck.
Jul 17, 2010 | Stanley Bostitch F21PL Nailer
I bought a rn 46 and the plunger is out blocking
neither one, could be a jammed nail or an o ring issue, check for the jammed nail first and if not let me know and I will try and help.
Feb 19, 2010 | Stanley Factory Reconditioned Bostitch...
Can i use any brand coil nailes in my nv 45ab2 coil nailer
Yes. Roofing nailers all use about the same size and spacing on coil nails. You will find that Harbor Freight is about 1/2 the price of Home Depot or Lowes for those nails.
-Jim
Oct 17, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
May 31, 2009 | Stanley Bostitch F21PL Nailer
Stanley Bostitch N75c1 Coil Sheathing Siding Nailer Logo
101 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
