Question about LG DLG3788W Gas Dryer
Gas dryer LG DLG3788W
Need to know how to remove top panel, it has dent that I would like push out
  • Anonymous Mar 19, 2014
    my dryer does not heat. I need to know how to get to the igniter to replace it
  • 489 Answers
Take a 2 inch putty knife and slide in the separation gap just above the door.  There are 2 catches on each of the panel about 3 inches from each side.  Push in to release the catch and the top panel will pop open.
Posted on Jun 11, 2008
Newer LG front load gas clothes dryer. power hooked up dryer controls light and operate. gas hooked up and flowing. i hear the igniter light but gas doesnt stay lit. no heat. do i need a special gas dryer...
if you hear the flame light but it doesn't stay on for a long time most likely you have lint blocked up in the dryer or in the vent linepull out the lint screen filter and look down into the duct that the filter slides into,if that's blocked you can try to stick a brush down in there and pull out as much lint as you can and then get a shop vac and set it up to blow and try to blow the rest of the lint out,if this doesn't work you have to pull the front of the dryer off and clean out the duct,also vac and blow out the gas tube and the motor and vac up any lint that's in the cabinet,unplug the dryer,remove the top,then the control panel and then the front panel.put it back together and then go out side and make sure the duct is clear no cage or screen,go back inside,remove the vent line off of the back of dryer,if it's a long run to the outside stick a leaf blower into the vent line and blow it to the outside,put it back together and you should be fine.this should be done once a year with a gas dryer so you don't have any problems with parts or how it's running and most important you won't have a fire.if you need anymore help let me know.
Oct 07, 2013 | LG DLG3788W Gas Dryer
How can i tell is thermostat on exhaust pipe on my LG gas dryer, model DLG3788W, has blown? Button is sticking up...
Hello & Welcome to FixYa
You can test the thermostat with the voltmeter...if it tests open then replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Jan 24, 2011 | LG DLG3788W Gas Dryer
How do I get to the motor of this dryer? Do I need to get to it from the front of the dryer or the back?
On a rear control LG, from the front. Open door, remove two phillips screws at 4 and 7 O'clock positions, use putty knife to push in clips (2) holding top at front, swing top back, remove two phillips head screws holding front panel cabinet. Disconnect door switch and light plugs, tilt front panel forward and off bottom tabs, allowing sensor at bottom to be un-plugged, thus front panel now completely free of machine. 4 phillips screws hold front bulk head / front drum roller supports to cabinet. Lift up and off. Reach in and remove belt from tension pulley. Drum comes right out, allowing access to motor.
Jun 13, 2010 | LG DLG3788W Gas Dryer
Can't get heat from our gas dryer. LG dlg3788w
my model number is lgr4634eq1. my gas dryer just spins but does not heat. The dryer came w/the house 3/13/98..
Feb 01, 2010 | LG DLG3788W Gas Dryer
My lg tromm DLG3788W gas dryer is not heating, it says check filter. other wise it works fine. where is the filter at, i know the one where i open the door and clean the vent everytime i use it. thanks
I just cleaned those sensors at the bottom of the filter, it worked like a charm. The dryer is now drying perfectly, I did not know you were not supposed to use fabric sheets with this dryer. Now I know, Thank you for the good information.
Jul 30, 2009 | LG DLG5932W Gas Dryer
LG dryer making unbelievable noise!!! Loud thumping noise. Took top off and drum is cracked seam where it is welded. This may be the cause of the noise.
Same problem here. Half of my LG appliances have failed within 2 years. Stay away from LG!!! They look pretty, though.
Feb 28, 2009 | LG DLG3788W Gas Dryer
Start switch not working
You will have to remove the back panel on the control console, to give you a better visual on the unit go to sears.com/parts and in the model # put your info in then click on control/top panel view. Good luck
Jan 09, 2009 | LG DLG3788W Gas Dryer
Make and Model Clarification
Here is the customer contact page. I could not find the model number listed on their website. It may be too old? I have also lost track of your original question, sorry.
http://us.lgservice.com/index_b2c.jsp
Dec 26, 2008 | LG DLG3788W Gas Dryer
Conversion back to natural gas
4948EL4001B back to natural part number LG will only sell it qualified techs..but here's a start.
Jul 09, 2008 | LG DLG3788W Gas Dryer
LG DLG3788W Gas Dryer Logo
168 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
