Question about Outcast Super Fat Cat Float Tube
Tube leaks and I can not find the source to fix it.
  • ray gallant Apr 23, 2014
    make a spray bottle of soapy water and spray theboat especially around the bottom. this will make bubbles .
    Top Expert:
  • Outcast Master
  • 43,142 Answers
Spray it dwon with a soap water solution then inflate!! look for bubbles. sometimes a little seam sealer inside will fix . like used for tents
Posted on Oct 23, 2010
How can I stop leak?
Hi Charlotte:
You'll need to determine the exact source of the leak:
- Failed hose? Replace it.
- Hose not tight on coupling? If there is enough slack, cut 1/2 " off end of hose and re-install.
- Hole in tank or coupling tube. Repair or replace.
Hope this helps.
Cheers.
Apr 15, 2016 | Snapper Garden
Can oil pressure sender cause a major oil leak if sender is bad
Hi Jerell:
Short answer - YES
Fortunately, it is usually easy to find the source of oil leaks. clean it up, run it for a short time, look for the fresh oil leak.
Lots of older vehicles had a vinyl tube that went from the engine block to an oil pressure guage. A hole in the tube or a bad fitting connection would cause the loss of a large amount of oil.
Electronic senders could still be the source location for an oil leak if the internals had failed. Not common, but possible.
May 13, 2015 | Cars & Trucks
GE profile side by side refrigerator leaking water from the bottom on the back right side at refrigerator tubing pressure connection. Model# PS123NGMD 88
Try tightening the brass fitting first. If that doesn't fix it, look at the tubing for the source of the leak. If there is enough tubing left after you cut past the leak then you can reuse the brass fitting and the tubing insert on the tubing. If not, then you'll need to get some tubing and a brass splice connector from your home improvement store to fix the problem.
Jan 03, 2015 | GE Refrigerators
My Frigidaire Refrigerator (FFHT2126PS) has a leak, how do I fix it?
The fitting shown is a John Guest fitting - releases by compressing the white ring around the tube - and if the leak is from any part of the valve you will need to replace the entire valve as they are not serviceable. Carefully check for the source of the leak first as water runs downhill and could be leaking from higher up and just dripping at the valve/fitting. The plastic tubing can age and become brittle or the tube connection at the other (higher) end may be leaking. Both are relatively simple and inexpensive to repair/replace.
Sep 13, 2014 | Refrigerators
Leaking hose in front of engine
This means you have a leak on your cooling system.Be very careful with that as if you are not careful it will end up blowing the head gasket which will be costly to fix.My suggestion is to find the leak, drain the cooling system and fix the leak which will be less costly and easier than having a replacement head gasket.
Jun 25, 2009 | 1996 Chevrolet Cavalier
Water Pump leakes from steel tube.
when installing new o-ring on tube, lubricate o-ring and stick it in water pump. Then pull pressure back on tube and then tighten hold down clamp. problem solved
Apr 16, 2009 | Dodge Caravan Cars & Trucks
General Humidifier Model 1042-L leaking water
Check the bottom of drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray is clogged with hardwater minerals or other material.
If the unit has not been used in a while it's possible a spider has take up residence by spinning a web in the bottom tray or tube.
The last poissible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
Jan 16, 2009 | General Filters 1042-LH Humidifier
I have a General Humidifier Model 1042-L that is leaking water out of the bottom pan. How do I fix this?
Check the bottom of the drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the bottom end of the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray may be clogged with hardwater minerals or other material.
Also, if the humidifier has not been used in a long while it's possible a spider has take up residence by spinning a web in the bottom tray or tube. Tell the spider to find a new home.
Another possible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
And lastly, is the unit installed properly, parallel to the ground? If tilted, water flowing through the unit may catch the sides and flow out where it should not.
Leaking from my MaytagPAV2300AWW
Had this problem. In my case the leak was comming from the fill indicator tube. It is a small tube running from the side of the tub to the control panel. Air pressure built up in this tube activates a pressure sensor that will shut off the fill valve at different levels depending on the pressure. The tube had become dry and cracked at the joint where it met the tub. I didn't discover the source of the problem unitl the hose actually tore loose and the thing overflowed. Remove this tube and inspect it and I bet you will find a small crack or tear.
Jan 15, 2007 | Maytag PAV2300 Top Load Washer
Outcast Super Fat Cat Float Tube Logo
53 people viewed this question
Top Outcast Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Outcast Boating Expert? Answer questions, earn points and help others
