Question about Bunn Margarita Machine Ultra 2 Slush Granita Maker
I have a Ugolin slush maker. Model 220 TE. I need to get re-charged\r\nwith R12. Can you advise me what the charge rate is?
  • Bunn Master
  • 2,237 Answers
It's going to be more than you think. the gas will have to be changed to 404a and the dryer replaced. and if it needs recharging, then there is a leak somewhere. it's about 3-4 hours of work. as for the rate, that'll depend on who you take it to.
Posted on Feb 13, 2011
What kind of ac coolant does it have 134a or r 12 and where is the low pressure port for the ac located
Depends on the year. Cars in the early 90's used R12. Anything later uses R134a. The size of the charge ports will define the R134a port. An adapter is needed to fit on the charging hose. R12 requires no such adapter. Ther charging label under the hood will tell you what refrigerant is needed too. Since you failed to give enough information on what make and model car you have, a general answer for the location of the low pressure port will be given. On the compressor, the larger diameter hose connection is the low side. Connect there, or look for the drier/accumulator (Large diameter silver container near the firewall). Connect there. You will need to access the AC information label under the hood to determine how much freon to add to the system.
Mar 12, 2016 | AC Cars & Trucks
How many ounces of R12 to charge freeze
There should be a tag on the compressor, but how are you going to check the charge without gauges and a licence to use R12 refrigerant?
Dec 15, 2015 | Refrigerators
Manual for welbilt model 2900
I have the manual for the Welbilt model 2900 and the Welbilt 3500. I am not clear on which one you need, please advise. I charge $5.99 for downloadable copy of bread machine manuals.
Sep 07, 2011 | Welbilt ABM3500 Bread Maker
What type of refrigerant does a 1990 Ford Ranger use?
there are only two types of refrigerant (or normally called as freon): R12 and R134. R12 is designed for car model 2000 and below. though, some old car compressors can accomodate R134 provided that you change your auxillary fan (fan for your aircon condenser) since R134 is hotter than R12. Ask an aircon technician if your compressor can be charged with R134.
Most of the countries now ban the use of R12 since it is more harmful to our ozone.
Aug 05, 2011 | 1990 Ford F150
Air is not very cold on a rv roof top ac what tools are needed in recharge
You should have the manual for this unit handy and as far as recharging tools go. You only need a can of R134a *(if the unit is R12 you need to buy upgrade adapters since R12 is no longer sold) Run the unit and put the R134a filler line on the low pressure side of the compressor *(from manual...dont guess as trying to charge the high pressure side is VERY dangerous). Get the charge just into the Green zone on your charger and that is it! Try not to fill too high in the green zone....I know it sounds funny...but AC's usually work better when they have the low end of their optimum fill. R134a doesnt work as well as R12 so be sure you buy the R134a with cooling enhancers. Your local Autozone can guide you to the right filler/product combination.
Good luck and be careful!
Jun 30, 2010 | Dometic Rooftop RV Air Conditioner
Doe s anyone knows how to charge R12 Ge model
Keep looking for the access on the high and low side. Some of the valves look a little different but you should be able to find where to hook the gauges. R12, R22, and 134a all charge the same way and use the gauges and hoses. just make sure you have pressure temperature chart.
I hope this helps
Apr 20, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Can't reprogram bottom message on TE-220
I don't know too much about Cash Registers specifically. But do you have the guide? Look up if possibly there could be a specific button you have to press to "accept" changes.
Oct 14, 2009 | Casio Parts Cash Register PC Desktop
Where to charge your a/c
You should see lines comming out of the compressor. follow them around untill you see a black or blue plastic cap that will be the system service port's you need to find out what is in the system from the factory before putting any in.I belive the 1989 fords had R12 and you need to get the system evacuated before getting a R134 retrofit kit to put R134 in it. unless you are certified to work on R12 systems. than you can buy R12 reclaimed ref. but the avrage person can not.
Jul 29, 2009 | Heating & Cooling
Need instruction booklet/for slush ease machine
http://www.nostalgiaelectrics.com/manuals/HSM-250.pdf
this is for the nostalgia electrics slush ease drink maker...
May 20, 2009 | Bunn Margarita Machine Ultra 2 Slush...
Dont know were the port is to charge my air on 1999 for expiditio
there are two lines under the hood from the compressor, the one that is located in the larger of the two lines is the charging port, you say your charging nipple doesn't fit on either? are u using R134 refridgerant charging adapters? they are very large in comparison to the older R12 refridgerent system which was phased out in 1993.
Apr 08, 2009 | 1999 Ford Expedition
Open Questions:
See all Bunn Margarita Machine Ultra 2 Slush Granita Maker Questions
Kitchen Appliances - Others Logo
255 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Kelley Hopper
Jerry Greenberg
Jerry Greenberg
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
