Question about Garden
Jacuzzi J-31, 2002 model. We inherited it, used. It has been plugged in with water for five years with little maintenance. We think we have narrowed the issue to the threaded cover plates, connecting over the jets with the moveable knob for water pressure placement. The cover plates are not connecting with the jets to allow the emission of water. The jets on the right (sitting inside the tub) will emit water,but not at the fullest pressure. Only the upper jets (neck) & the feet jets on the left side emit water with minimal pressure. When the threaded cover plates are removed, water freely flows from the hole in the tubwall, but when the cover plate is screwed back on, no water comes out of the directional jet. We bought this hot tub new but sold it with our previous residence. We know the high performance of this tub & were ecstatic at the opportunity to own it again. Please help!
  • 62 Answers
SOURCE: Oil stick is stuck
Have you ever checked it before? Do you know if it's a screw on cap? It could be that the cap is slotted, and is only supposed to turn a 1/4 turn. Try not to force it, and use a light touch.
Hope this helps!
Posted on Oct 08, 2008
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
  • 67 Answers
SOURCE: Can't pull choke knob up on my riding lawn mower
take the cable off the mower and clean it in a pan with solvent or brake cleaner spray. you can coil it up to fit the pan while soaking. afterwards, let dry --- if you have an air compressor blow it dry to help clean and dry it --- then oil it up with a light oil or wd-40, wipe it off, stretch it out, and work the cable again before you remont it. the cable will stick if it gets too dirty and has no lubrication. may want to buy a new cable but they usually can be cleaned and lubricated.
Posted on Jun 25, 2009
  • 218 Answers
SOURCE: one blade on deck gives an uneven cut name is Keith..and most times..when your problem happens..either the deck is bent down from runing into something or stepping on it..or the deck hanger is bent, worn or out of adjustment..or the blade on that side is bent..and i hope this will help..if not..please write back
Posted on Jul 04, 2009
  • 112 Answers
SOURCE: Replacing a temp control valve on a true GDM 26 commercial refridgerator
Unplug the unit & remove the plate holding the thermostat. The capillary for the thermostat will go into a very small tube that runs into the evaporator coil. You will probably not be able to see the tube but will have to feel for it and get a good orientation for where it is located before you pull the capillary out. Try to measure the amount of capillary in the tube as you pull it out so you know how far you have to push the new one in and put some kind of tape or mark on the new capillary before you try to push it in. you might have to soap up the capillary to get it to slide easier.
Posted on Jul 07, 2009
Hair in a Jacuzzi Drain
take the drain plug out and remove the hair. Once you remove the hair from the drain your water will drain from the shower.
US Parts Center
Mar 09, 2014 | Jacuzzi - Bathtub - Alcove - Navona -...
Newly installed jacuzzi only has hot water for about 30 seconds, then water is tepid only.
This issue will have nothing to do with the jacuzzi tub. You will find the problem exists in the way your home was plumbed by the plumber.
Somewhere there is a clog in the water line going to the hot water faucet.
Find that and you will solve your problem.
US Parts Center
Mar 06, 2014 | Jacuzzi Home
My Jacuzzi J-N180F tankless water heater will not even light.
Access your product manual.
I cannot find a product manual.
Some major company, like Rheem, makes this computer that heats water.
Call service technician to repair the unit.
Copy following link for overview of type of problems found with tankless computers.
For example tankless computers require continual maintenance on yearly and monthly basis to prolong expected life of product.
If tankless computer is older than 5 years, then assume it is like your 5-year old laptop computer.
Save problems, and repair the unit yourself, same day, by installing tank-type water heater:
Aug 27, 2013 | Jacuzzi 7.5 GPM 180000 BTU Internal Gas...
I have a jacuzzi 1/2 hp submersible well pump. Does this need any regular maintainance to keep it happy.
No preventative maintenance is necessary. However, a happy pump always has water above it and should not pump sand. If the water level in the well is below the pump/motor they will overheat. If this is a problem your local pump company can install a module to protect your pump from this type of event.
Please rate this answer.
Jul 03, 2009 | Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire...
Jacuzzi Select model 10 years old. Motor
Sounds like the high speed relay is stuck or not working at all, It is in the main contol box, and can be manually tripped to see if this is indeed the problem. Unless you are a skilled repair tech, this job is better left to a pro.
Jun 19, 2009 | Home
Need User Manual
Go to and plug in model and serial no. you should be able to find an operation manual there.
Jun 09, 2009 | Whirlpool Caresse 2 Person Bathtub Seats...
Jacuzzi tub works.....sort of.
motor for tub does not run checked electric its ok.. is there a reset button and does there have to be water in the tub?
Apr 05, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Need a users manual
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Nov 11, 2008 | Balboa Instruments Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
