Question about Cadco OV-250 Electric Single Oven
I need to replace the rubber seal (gasket) that goes around the entry base area where the door opens and closes. The rubber gasket is attached on the outside of the oven entry base area when you open the oven door. Need to find a replacement seal. oven specs -- Cadco electric convection oven -- model OV-250 thanks
    Sergeant:
    Novelist:
  • 193 Answers
Cadco sells parts to the end use through a parts distributer. The phone number is 800 458 5593. Have your model and serial number ready when you call.
Posted on Oct 12, 2010
The door on my Nobel model: Nr.: NF 60 SS/1 will not seal when closed.
Oven doors can warp over time. Also, if the door has a heat shield that covers the window and locks the door during self-cleaning it can become misaligned and prevent the door from closing properly. Minor alignment and adjustment can be done by loosening the screws on the hinges and taking advantage of the slots provided for positioning the door before re-tightening the screws however if the door is warped too much you may not have enough adjustment travel available to properly re-align the door. The metal gasket around the door may also have become damaged and is preventing a proper seal and you might be able to locate replacement gaskets at an appliance parts house.
Nov 19, 2014 | Ovens
Kebs208dss11 model double oven. When upper oven is on with door closed, steam can be seen escaping from top of door. Door is closed all the way. Even when putting pressure on door to make sure it is...
The first thing I'd suspect is a poorly fitting door seal / gasket. This will permit the heat inside the oven to escape. Check to be sure the the one installed is defective (cut, split, frayed, dislodged, etc.) Replacement parts:
http://www.appliancepartspros.com/whirlpool-gasket-door-w10074200-ap3892420.html
Make sure this is the part you need before ordering.
Feb 25, 2014 | KitchenAid Ovens
Trying to find piece of heat resistant fabric (don't know name - something like old asbestos) to replace degenerating fabric on light fixture gasket on otherwise perfectly working caloric electric wall...
If it would help you to find the model number, I would look for a way to remove the oven door. Usually there will be a release near the hinge bracket that you push in or push to the side to allow the bracket to release and you can remove the door to see the ID plate. Otherwise, I would suggest going to a wood stove dealer and looking at the door gasket material they have in stock. They usually have rolls of heat resistant gaskets for sealing doors and glass panels in wood stoves. Last idea would be exhaust gasket material available at Napa Auto parts. Good luck!!
Nov 04, 2013 | Ovens
Hi my oven gasket need replacing, I have bought the new gasket, and have no idea how to replace the new one, my cooker is a F and P model no. 610 EWS,the gasket is fitted around the entrance of the o
pull the old one off clean the area with a solvent,let it dry,it should have little plastic guides on the new open,put a little adhesive down push it in the guide hole,close the door,let it set for recomended drying time of the adhesive.
Dec 20, 2012 | Ovens
I want to change the door seal on the pyrolitic section of my double oven. its 15 years old and I believe I need to take off the door to achieve this. I also need to clean the glass inside. There is n
Should. Find few screws on the top and the sides of the door. Just unscrew them and see how the old one is that will give you a clue on how to replace it.
Jul 25, 2012 | Stoves Ovens
Door will not close completly
When you say "oven door will not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 08, 2011 | Ovens
ECD230 dacor oven, th bottom door isn't sealing all the way, you can feel heat escaping. Is there an adjustment to make?
jenn air had some issues with there hinges wearing fast in prior years on there ovens and then you have the ones the kids use as a trampoline sometimes or the heavy turkeys laying on the door while it is opened... there really isn't any adjustment for the door the hinges bolt inside and are held in one place by a few screws ...they are replaceable as welll as the door gasket on the unit... hope this helps you out some... alot of the appliance sites out there will be able to assist you with parts such as www.sears.com then click the parts direct link up top have your model number usually inside unit either on door or inside where door closes... some units between door and cabinet area... good luck to you
Jan 13, 2011 | Dacor ECD230 Epicure Electric Double Oven
Hello we have a fisher and paykel classic stove and top with four elements model no RA610MAW as we are in the bush we need to know how to change the seal in the oven which the door closes on we have the...
c55aadb.jpg Isolate power from device, remove screws to free back panel.
769e143.jpg Loosen strainer for oven liner on left and right sides and remove clip to allow oven liner to slip forward.
e87a68d.jpg Remove screw on front central upper clip.
42f6dbf.jpg From front, move oven liner forward a few millimetres to release gasket. Here you see the strainer at the rear has moved forwards a few millimeters.
e8ea79b.jpg Remove the old perished seal.
f86ae37.jpg The new seal/gasket part number 573263 is installed. Reverse dismantling procedure to complete reassembly.
Mar 19, 2010 | Fisher Ovens
Our oven is about six years old. It works well except that (1) the oven door seems to not close well so as to leave the light on inside, and (2) the digital display is totally out and does not display the...
Your oven door may have a defective hinge or simply is not aligned correctly. I am assuming the door, when shut, is NOT totally sealed around all four sides??? If the door is sealed around all four sides, than you have a switch that activates the light that is possibly defective. As for the electronic display, this display unit will have to be replaced.
Thank You,
Please accept
Jan 28, 2010 | Ovens
Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Nov 06, 2008 | Ovens
Cadco OV-250 Electric Single Oven Logo
642 people viewed this question
Top Cadco Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Cadco Oven Expert? Answer questions, earn points and help others
