Question about Brother XL-5130 Mechanical Sewing Machine
What is the part that holds the sewing needle.
  • Brother Master
  • 7,365 Answers
The needle clamp & needle clamp screw
Posted on Oct 12, 2010
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
My needle holder in my Euro-pro ep550 will not tighten to hold the needle in the machine. how ill i buy another needle holder to fit my machine
if you take the serger to a sewing machine shop and show them the problem, they can check to see if the needle holder needs to be replaced or just some new screws
Sep 06, 2014 | Euro-Pro Sewing Machines
Why does the sewing needle come undone whilst sewing
Your Needlebar screw is not being tightened enough. This is dangerous and you can risk other damage to the machine.
Untighten screw that allows the needle to be removed, using the sharp end of the needle, insert it into the same hole the needle base fit into. Clean out, using needle tip and can air if you have any.
Dust and cloth fluff get repeatedly shoved into the needle bar until the needle isn't inserted enough and effects sewing.
Also the needlebar "head" may need to be replaced if the set screw that holds the needle in the needlebar is stripped and no longer working to hold needle properly.
Get it looked at by a repair shopASAP! you can lose an eye to a flying needle fragment if that needle is coming lose during sewing.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Jun 09, 2014 | Toyota Sewing Machines
Line needle plate
try a new needle first, then if the needle doesn't line up with the needle plate, then the machine needs a ajustment or has a timing problem and needs to be checked at a sewing machine shop
Oct 01, 2013 | Singer 4423 Sewing Machine
Thread gets stuck after second stitch
Let me guess,.... When you start to sew you do not grasp the loose thread ends. Grab them babies and hold on for about an inch or more of sewing.
Sep 23, 2013 | Janome Memory Craft 4900QC Mechanical...
Fixing a new needle on a sewing machine
Turn the hand-wheel counterclockwise until the needle is at the highest point. Lower the guide or presser foot. This will give the maximum room possible for working with the needle.
Turn the needle clamp screw counterclockwise until the needle comes loose. This screw is located on the side of the small
box, known as the needle clamp, that holds the needle in place.
Remove the old needle by pulling it straight down and then angling it outward. Place a new needle into the holding slot or needle clamp.
Tighten the new needle into place by turning the clamp screw clockwise until tight. Do not over-tighten the needle.
Here's a tip
Use a needle that is appropriate for the type of fabric you are sewing. Using the wrong needle may result in breakage and increase the number of needles to be changed
Over-tightening a needle can cause it to be crooked and break. Turn the clamp screw only until the needle feels stiff in place.
Aug 23, 2012 | Euro-Pro Shark 9110 Sewing Machine
I have a sew mini and cant change the needle. The screw keeps turning and turning but does not hold the needle in place. Tks.
you need a new needle clamp screw & probably new needle clamp
here are 2 websites to get parts
sewingpartsonline.com
sewingmachineparts.net
Dec 09, 2010 | Janome SEW MINI Mechanical Sewing Machine
My needle holder will not hold the needle in tightly what could be causing this problem?
The threads of the screw that holds the needle clamp could be stripped or worn.
The needle clamp can be replaced. You can get this from a sewing machine dealer who does the repairs or, order from the Internet.
Stretching a piece of Teflon tape (a plumbing product and not expensive) around the threads of the screw can provide a short-term fix.
May 02, 2010 | Brother XL-6562 Mechanical Sewing Machine
The needle hits the throat plate
if a new needle still wont align with the needle plate, your needle bar is out of whack
Mar 18, 2009 | Brother CS6000i Computerized Sewing...
Brother XL-5130 Mechanical Sewing Machine Logo
56 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
