Question about Kitchen Ranges
The GE wall oven Model # JKP13GOP2BG is not working. It is giving us fault code F-1. We want to replace the faulty control panel GE # WB27K5040. Where can we get the replacement control panel?
2 Suggested Answers
  • 114 Answers
SOURCE: GE model JKP13GOP2BG control panel faulty ( F1 code)
Often times when someone makes an attempt to "repair" a control, it does not hold up. Replace the entire control. Don't waste your time. You will also get a year warranty on a replacement control.
Posted on Dec 13, 2008
How to stop WB27K5040 from beeping F1 error code
Unfortunately, the F1 error means that either the touch pad has a short or the "clock" (electronic control unit) has failed. Sometimes the wire between the touch pad and the clock fails. To test for the exact problem, you would need to unplug the range and access the clock from the back of the range. Unplug the touch pad from the clock. Then plug in the range again. If the error does not recur, the touch pad is bad. If the F1 error and beeping repeat, the clock is bad.
GE sold the clock and touch pad as a single unit for the WB27K5040. Since this is an older model range, the replacement is not in stock. There are some places that offer to repair the clock. You'll need to remove the part (or get a service person to do it) and send it in. Your range will be unavailable for some weeks while this is attempted. Otherwise, you should replace the range when the issue becomes too frustrating.
I hope this helps.
Aug 28, 2014 | Ovens
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: elylimo@gmail.com I have the same model number. 9114658811 and plugged in the stove for the...
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Kenmore 46123 Stainless Steel Electric...
Ge glass cooktop range won't bake or broil. error fault codes f7 and g6
see the cause and fix it for F7:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 20, 2012 | GE Stove / Oven / RanMain Glass Top Assy....
Ge built in 1993 oven shows an F-1 sign and beeps
Hello there:
any time you recieve the f-1 and sometimes a f-o error with the beeping this is from the electronic range controle board or erc for short and this means that that part has fgailed and needs to be replaced if you go to repair clinic.com you can look up you oven model number and get parts from there or if you have a appliance repair center in your home town give them a call and tell them the ovens model number and tell them you need a erc or electronic range controle board ok?
Hope this helps
Best regards Michael
Aug 16, 2010 | GE Ovens
I have a GE built in oven Model JKS05B0WPBB and getting an F7 blinking light. Can you give me some guidance? Thanks.
Hi.
F7 on GE ovens means that there is a poor contact to keypad detected. When this happens the problem is either keypad or control panel.
Problem is fixed testing keypad and control assembly and replacing the faulty part.
Here the procedure to test the parts:
Hold down the CLEAR/OFF button on pad.
Disconnect the ribbon cable connecting control panel to pad and wait about one or two minutes to see if the code comes back.
If the code comes back, then you likely need to replace control assembly.
If the code does not re-appear on display, then the problem is with the key pad. In that case replace the key pad.
The procedure is only indicative. In case of faulty control assembly procedure may not be a definitive test. In that case replace the control pad first.
To find parts and diagrams for your appliance, enter the model number in the links listed below:
Where do I find parts and diagrams?
Aug 10, 2010 | GE Ovens
Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Aug 28, 2009 | GE Profile Advantium 30" Built-In Single...
GE ModelJTP14 oven, after 30 minutes at 350, the oven flashed a F2 code. Cooled and restarted the oven at 350, after 26 minutes it flashed F3. I have been remodeling and have taken the oven out of the...
check the codes for your particular model..they are included witht he wiring diagram that came with your oven. F2 likely means your control board (ERC) has an issue. I can't vouch for accuracy but here's another location with fault code listings http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes
You can try turning the circuit breaker off that feeds power to your oven ( in your house electrical panel) that might work. If it does not, unfortunately it might be indicating a need to replace the control board... good luck!
Jul 13, 2009 | GE JTP15 Electric Single Oven
Dec 13, 2008 | GE JSP69 Electric Kitchen Range
GE Wall Oven - error code F1
According to GE, the F1 fault code indicates a problem with the Electronic Range Control (ERC) Board. If the fault cannot be cleared, they recommend replacing the ERC and the touchpad. Has your repair guy tried any of these ideas? Post back with your comments, please.
Jan 17, 2008 | Kitchen Ranges
F3 Error
This is due to a Defective control board..You have to get it replaced..
Oct 15, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Kitchen Ranges Logo
223 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
