Configuration of the16 pin accessory connector at the back of Motorola Max638 trunked radio
SOURCE: Installing a cd changer into a 2002 Jaguar S-Type
SOUNDS LIKE YOU HAVE A VERY EARLY MODEL CD CHANGER ALPINE UNIT THE S TYPE
USED A AUDIOVOX CD CHANGER HOPE THIS IS USEFUL
Posted on Oct 19, 2008
  • 6 Answers
SOURCE: I need a nissan Quest 97 wiring diagram for radio
go 2 autozone.com 4 free diagram online
Posted on Sep 21, 2009
eradiostore
  • 1654 Answers
SOURCE: Where can I find a plug adapter for a 2 pin
Try your local radio shack first. Then if they don't have one, there are several online headset/earpiece companies which might including Cobalt http://www.cobaltav.com/accessories.html; Klein Electronics http://www.headsetusa.com/adaptors/; David Clark http://www.davidclark.com/store/
You might also consider getting the correct audio device for the radio at the Motorola store http://www.store.motorola.com/mot/en/US/adirect/motorola;jsessionid=95A27CFFFEDE858D74CC8BB6B82C79C8.mot1?cmd=catDisplayStyle&entryPoint=adirect&catKey=601560&messageType=catDisplayStyle
Last ditch effort, if you don't care about your two-pin audio device ever having two-pins again, simply cut the one you don't need off. One should be a 3.5mm and the other 2.5mm. You'd have to gauge which one to keep.
Best regards.
Posted on Oct 29, 2009
  • 733 Answers
SOURCE: I cannot find the
use your handy dandy test light. it's the easyest way. pretty cheap at autozone. remember, you will have one at 12volts constant, if you can't find one on the connector, tap your cigarette lighter. next turn on the key and find the switched 12volts and make sure it's the right one by turning power on and off. turn the lights on and off just to make sure you didn't get the illumination wire.
Posted on Apr 01, 2010
eradiostore
  • 1654 Answers
SOURCE: I have an older model
You might try contacting the people at http://www.wirelesspro.com/. They seem to have a variety of accessories for the Motorola Spirit and TalkAbout line of radios. The Sport 10X was a predecessor to the TalkAbout Distance DPS.
Otherwise, you might check with your local Radio Shack. It is possible they might have a 1-pin device which might work with the Sport 10X. On some audio devices the second pin is only for stability. The main thing which would make a difference is size, length and placement of rings.
Best regards.
Posted on Jan 07, 2011
On the back of the radio on a 1994 dodge what pin in the back is the hot wire goes on`looking at the back if it lift to right
The connectors are slightly different depending on which radio system you have. The wiring schematics only say connector 1 and connector 2, so I can't tell you which is left and which is right. All the systems use the same pins for the hot wires, however. They are pin #6 and pin #7 in connector #1 They are (as you may have guessed by the numbers) right next to each other. Pin #6 is RED/WHITE and is hot only with the ignition switch in the ACCESSORY or RUN positions. It is protected by fuse # 12 in the Fuse and Relay Box (Under the left side of the dash). It is a 10 Amp fuse. Pin #7 is PINK and is hot at all times. It is protected by fuse #F2 in the Power Distribution Center. (In the engine compartment, left side) It is a 5 Amp fuse.
Mar 12, 2011 | 1994 Dodge Dakota Club Cab
I have an older model Motorola sport 10X radio that has two pin connection. I tried several of the Motorola two pin accessories but the pins are too far apart. Are there any adapters available?
Best regards.
Jan 04, 2011 | Motorola 2 Pin Adapter 2-Way Radio
Need to know what the pins are on the connector blocks on a Clarion PU-2358A (peugeot RD3) carv cd/radio
Is this site of any use as it shows many pin arrangements
www.tehnomagazin.com/Auto-radio-car-connector/CLARION-Car-Radio-Wiring-Connector.htm
Jan 01, 2011 | Car Audio & Video
How to create my own layouts?
Both the MTX8000 B5 & B7 models are Type II Trunking. If you are (un)lucky enough you might find an F3 modem that does Type II.
If it is an MTX8000 and has a front mounted display with either a 6 button or full keypad, you have a radio that will do Type II.
There were a few B3's that were Type II produced by Motorola. However, you can clone a Type II code plug into a B3 radio and it will work just fine.
You can run system watch using a MTS2000 handheld. Firmware version has to be above 5.44 (which has a 512k controller in it). Most MTS2000/MTX8000's only have a 256k controller, which will not work. You can put the radio into RF modem mode from the F4-F4-F4 (Trunking Config).
NOTE: When the radio is in the RF MODEM mode, it will do a self test and then the screen will go blank. The radio DOES NOT have to be programed to the system you want to watch. You set SYSTEMWATCH to the Spectra with RIB mode (works best). Even watches Type I systems.
If you have the accessory adapter for the side connector on the radio, the typical schematic of the speaker mic looks like this.
If you are using a Public Safety speaker mic with the radio, you might want to order part number 3205514W01 to cover the antenna connector on the radio.
If you are trying to program a MTX-838, from what we've heard, you need to use the MTSX software. The RVN4097F ver R02.10.01 RSS package specifically shows it programs the following radios: MT/MTS2000 MTX838/8000/9000. Now, the update for this software is RVN4097M R06.00.00 05 Sept 97, which should mean that it should program the radio as well. The cable you need is the standard MTSX programming cable.
Do you want to build your own programming cable? If you don't want to use an old speaker mic cable, see the individual part numbers of the parts for the Service Cable, below.
You may want to look at the schematic for the RKN4035D Service Cable. This is the actual Motorola cable used for programming and servicing these radios.
The individual part numbers for the components of this cable are listed below.
jedisvcpt.gif Reference Part Number Description C1 21-84008H06 Capacitor, 33nF 1 09-84538E03 Receptacle, 25pos 2 15-80349B36 Housing, Connector 3 30-05118W01 Cable, 13 Conductor 4 01-80754A26 Plug Assembly 5 42-10217A24 Strap, Tie 6 38-80373B24 Protective Cap 7 04-10058B12 Washer, Nylon 8 42-05184R05 Strain Relief 9 22-05541V01 Pin, Latch 10 41-05538V01 Spring, Latch 11 55-05536V01 Latch 12 15-05691W08 Housing, Connector 13 32-05533V01 Seal, Baseplate 14 32-05472P11 Gasket, "o" Ring 15 64-05241X01 Baseplate 16 39-05895V04 Contact, (13)
Mar 02, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
Rick to maxtrac, is it the same a radius
Yes, if you have the 16 pin connector. (The 5-pin connector is not a compatible version.)
Feb 02, 2010 | Motorola Radio Communications
I need the pin (plug) wire diagram so I know where each wire goes in the plug that plugs in the back of the Pioneer FH-P6200
http://www.tehnomagazin.com/Auto-radio-car-connector/PIONEER-Car-Radio-Wiring-Connector.htm
Jan 08, 2010 | Car Audio & Video
Where can I find a plug adapter for a 2 pin accessory going into a 1 pin radio? I have 1 pin talkabout type radio, but the accessory is a the two pin type. I found an adapter in the UK, but need something...
Best regards.
Oct 28, 2009 | Motorola Talkabout T5600R (7 Channels)...
How do I wire up a external speaker to a Uniden SMG1525DT Radio?
pins 2 and 3 on the accessory connector are for an external speaker and pins 1 and 2 are for the internal speaker.
Nov 16, 2008 | Uniden SMH1525DT 2-Way Radio
HT1000
Hi bonkuman,
To my knowledge the Motorola HT1000 is not a trunk system radio, it is as a "conventional" 16 channels two-way radio. Motorola classifies this radio as intended for Government & Enterprise. In my country, we call them "Commercial" radios as oppose to "Amateur" radios. In a way, yes they may be termed "professional" as their claimed performance and durability exceeds those of other radios. Incidentally, the Motorola HT1000 has been discontinued and was replaced with the PR1500.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 27, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
