Question about Canon PIXMA iP1600 Printer
On my canon pixma ip100 the orange light stay's on and computer say's that it is not connected to printer, cables are connected as normal
  • 56 Answers
SOURCE: Service manual Canon IP100 portable printer
http://software.canon-europe.com/products/0010626.asp
go to the above link and select your operating system.
Ian
Posted on Mar 09, 2009
SOURCE: Canon Pixma MP610 not connecting to scan
Had the same problem. Don't think it scans wireless; worked fine when I connected with USB cable.
Posted on Jun 12, 2009
  • 5160 Answers
SOURCE: Canon Pixma ip3600 message saying printer is not online
This could be a problem with the port. If you have the printer attached to a USB hub, directly connect to the computer. Try connecting to a different USB port and test the current port with a known working device. Consider trying a new USB cable (minor damage could be a factor in signal loss).
I hope this helps.
Posted on Feb 04, 2010
Testimonial: "Thank you,I did replace the USB cable and all is well."
pineworks
  • 4041 Answers
SOURCE: Canon Pixma MP140 freezes, only alarm lamp is on, no code error
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • Posted on Feb 16, 2010
    • 159 Answers
    SOURCE: I have a Canon PIXMA iP100 printer. I refilled
    Nope. The ink levels cannot be reset on refills for this type of cartridge. As long as your printer still prints you should be good. If it doesn't print you either need to go get another refill or a Canon brand cartridge.
    Posted on Mar 08, 2010
    Ip100
    Hello, Here is website for the download on the repair manual that you will need too help with taking apart. canon pixma ip100 service manual repair guide parts catalog
    May 19, 2014 | Canon iP100 Portable Printer
    Why won't the orange light turn off on my canon ip100 printer?
    possible soution
    check printercartridge and scan print alignment paper
    setting option have mentinanceoption use mentinance option
    May 19, 2012 | Canon iP100 Portable Inkjet Printer
    Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
    Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
    May 17, 2011 | Canon iP100 Portable Printer
    Waste tank to be cleared pixma ip 1000
    Reset waste ink tank counter CANON PIXMA iP 1000
    - Turn off the printer, and disconnect the printer cable
    - Press and hold the POWER button, turn on the printer
    - The Indicator (LED) should be green
    - Press and release the RESUME button, the Indicator (LED) should be orange
    - Press and release the RESUME button again, the Indicator (LED) should be green
    - Release both button
    Oct 03, 2010 | Canon iP100 Portable Printer
    Need an operating manual and a start-up disc for a Pixma iP100.
    Go to this page:
    Canon iP100 Support
    If the Drivers & Downloads tab is not selected, click on it.
    Under the Guides and Manuals you can download the Quick Start or Easy Setup guides. When you click on the link it will open (as long as you have Acrobat Reader) and then you can save them to your computer for future use.
    On that same page, if you select your operating system from the drop down menu near the top, you will get a list of available software.
    You will need the software under Drivers. It ends in exe. Click on the file name. You will then have to accept the EULA. When you do you will get another download window. The best thing to do is to select Save and direct it to your desktop. When the download is complete, close the window.
    To install the software:
    Make sure the printer has ink and paper. Turn the printer OFF and disconnect the USB cable from the computer.
    Run (double-click) the file on your desktop that you downloaded. This will begin the install. When prompted, connect the USB cable to the computer and turn the printer ON. This will continue the software install.
    NOTE: Should you get any "Found New Hardware" windows, simply Cancel them out.
    That should get you going. Refer to the Easy Setup guide mentioned above for additional info.
    Thanks for using Fixya.
    Dec 28, 2009 | Canon Office Equipment & Supplies
    Canon iP100 ink tank read error, put in new one and won't read
    I am having the same issue with the black cartridge error light is on. Three new cartridges create the same issue.
    Nov 30, 2009 | Canon iP100 Portable Printer
    Pixma mp 160
    Error 42 means scanner error. Just unplug the scanner cable and re-plug it. If thats just a connection problem then it should be back to normal. Otherwise there is a problem with the scanner itself(usually the scanner's motherboard is faulty)and you will have to send it for repairs.
    Jul 31, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Canon PIXMA iP1600 Printer Logo
    60 people viewed this question
    old marine
    old marine
