Question about Cell Phones
Manual for samsung 2.0 mega red and white slider phone
Network lock
Hi. you can get the network unlock code for a Samsung E2550 from Mobile-Unlocker.com at affordable cost.
..........UNLOCKING INSTRUCTIONS..........
Method 1:
1 - Switch ON your Samsung E2550 Monte Slider with a NOT ACCEPTED SIM Card.
2 - Samsung E2550 Monte Slider will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung E2550 Monte Slider shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung E2550 Monte Slider.
3 - Compose : #0111*CODE#.
Jul 07, 2014 | Samsung GT-E2550 Cell Phone
How to splice samsung galaxy s cell phone car charger to wall charger
you should just do white to white and ref to red. just so you should know that ac chargers have a special crossover that the phone knows it is charging not usb' ing to a computer so you may get message on the phone to go into usb mode...just hot home and you well be fine
Apr 02, 2012 | Samsung Galaxy S 4G Cell Phone
How do i turn the phone on
1. Open the phone (slider)
2. Press and hold the right hand side button on the bit that moved.
Full user manual can be found at
http://www.retrevo.com/support/Samsung-SGH-G800-Cell-Phones-manual/id/14715ci272/t/2/
follow the on screen instructions to get the download (in PDF format)
I hope this helps...
Peter
Mar 08, 2012 | Samsung SGH-G800 Cellular Phone
Please advise how I remove my sim card from my Samsung Monte Slider (manual misplaced)
Here is a video from YouTube
http://www.youtube.com/watch?v=CU50J9_H2j0
Here is the manual (I think)
http://www.selflearning.co.uk/vodafone/faq-simulex-files/Samsung/E2550/Samsung-E2550-faq.swf
If that link does not work, try getting there from here...
http://blog.gadgethelpline.com/samsung-monte-slider-e2550-manual-%E2%80%93-an-interactive-guide-to-your-phone/
I hope this helps.... please vote "yes" if it did. Thank you!
Apr 06, 2011 | Cell Phones
How can i open frunt camera in samsung s5620
Type *#0*# and you will find a new menu.
Here are the functions of the menu
1 - LCD colour to Red
2 - LCD Colour to Green
3 - LCD Colour to Blue
4 - Melody RCV
5 - Vibration
6 - Dimming (dims urphone as its switchd offf)
7 - Mega Cam (the back mega pixel cam gets on)
8 - VGA Cam (this is the key wich activates front cam
9 - Touch test
* - Cam LEd (u can use ur phone as a torch with this fuction, ur led light gets activated)
0 - Sleepmode
# - Melody Spk
Feb 28, 2011 | Computers & Internet
Instructions to replace the samsung sgh-a877 lcd screen?
needs major work. Do it at your own risk. Did everything right but messed up and broke the tab on the touchscreen cable connector on my daughter's phone. Feel crappy. Will post with pictures later on.
1. remove battery/ Sim 2. remove all screws from the back on the black plastic cover. (6 of them) Leave the ones below the battery. 3. Use the pry tool to remove the back case. 4. remove the motherboard, three connectors, one on bottom left, antenna and top right below the board. board comes off. You also have to remove the power connector (transparent plastic) to what appears to be some hf component (cylinder). there are two wires (red, black), red goes to side marked +. remove with pry tool. 5. Remove all small screws you can see. 6. Remove the shiny plate, keyboard button layer. 6a. Remove the lcd connector screw and the connector. 7. Remove screws from the bottom of the lcd portion of the slider. You can access all screws from the back side. Use the slider to get the back of the phone. There are 5 screws. 8. Use the pry tool to take out the back slider. Be careful with the lcd connector. 9. pull up the black tab on the digitizer connection from the screen 10. remove the lcd 11. use a hair dryer to loosen the glue around the broken digitizer. 12. put the new one in 13. Put all the screws back.
Apr 10, 2010 | Samsung SGH-A877 Impression Cell Phone
The keys on the slider don't work properly. I press them but nothing happens. So the arrow keys and two side buttons (call and hangup) don't work. Also, when I slide the phone shut, the white lights on the...
it is the slider problem which is called ribben problem. u 600 phone is so thinn and samsung they putted so thinn ribben in that it goas damage so quickly. try to change slider or ribben.
Dec 30, 2009 | Samsung SGH-U600 Cellular Phone
User manual for samsung s3500 slider phone
http://downloadcenter.samsung.com/content/UM/200904/20090406191043562/Samsung_S3500_UM_EU_Eng_Rev[1][1].1.1_090203.pdf
Jul 25, 2009 | Samsung Cell Phones
My Samsung M520 slider screen goes white and freezes
yeah i also have a samsung m520, and its rececntly been turining white then back to normal. Its really annoying. I got it replaced last year with the warranty but now, about a year later, it turns white again. I went to the Sprint store and they said the cord that connects the screen and slider is either cut off or damaged. I like never drop my phone or in water, and its sucksss...
and i thought Samsung was reliable.
Feb 12, 2009 | Cell Phones
Samsung D840
Frnds, turning screen white and no sound from speaker are common problem of slider sets....these probs come bcoz of cuts in belt which connect two parts of slider sets....so u hav 2 replace that from service centre....
Apr 14, 2008 | Samsung D840 Cellular Phone
Cell Phones Logo
1,285 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
