How can we remove the foul smell on mars? - Computers & Internet
    Master:
  • 503 Answers
Oxygenate it .
Posted on Oct 12, 2010
Does air cnditioner give any foul smell when running
Hello typically a air conditioner does not give off a foul smell, sometimes the condensate that drains out can have a moldy kind of smell or if mold is growing inside the unit it can give off a foul smell called " dirty sock syndrome". The last possibilty is that if the condensate line is drained to a floor drain and on the negative pressure side of the evaporator coil it could be pulling the sewer gas up thru the line, in this case the condensate line must be trapped to prevent this. Also, I would recommend pouring some bleach into the condensate line every few monthes.
Jul 16, 2012 | Amana Heating & Cooling
Hello i am having a foul smell coming from underneath the refrigerator. it doesn't have the drip pan on it..i removed it due to a previous foul smell..are these refrigerators known to have this type of...
the smell is bacteria caused by condensation from the drain pipe/drip pan,syringe with chlorine bleach, all fridges will smell if not looked after in the proper manner....but how many of us read the book......(if you removed the drip pan then you have the bacteria all over your floor.....will discolour/ruin any surface/carpet...
Jul 30, 2010 | Admiral Refrigerators
When running, smells rich, fouls plug, and smokes when running. when adding throddle, cuts out.need to know how many turns on carb screws for low and high mixture adjustments from factory. cleaned carb and...
Hello Derrick:
I would start with "H" and "L" at 1.5 CCW from lightly seated then adjust for performance as follows:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
There is a thread for your saw here:
http://www.arboristsite.com/showthread.php?t=117499&highlight=McCulloch
She is respected.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 29, 2010 | McCulloch Garden
Backup of foul smelling water into the dishwasher
Outlet pipe is partially or completely blocked.
Use a dishwasher cleaner in it, but before you even do that, remove outlet pipe from waste pipe - and clear all the gunk out you can.
I suggest a bucket with disinfectant and washing powder to dissolve the grease.
You may need a drain cleaner down the waste pipe too - & flush with hot water and washing powder.
Aug 04, 2009 | GE Profile PDW8400J Built-in Dishwasher
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Need to have a foul smell removed in kitchen
bleach spray in a squirt bottle
1part bleach
10 parts water
pull the pan out from under the fridge, clean it
lift stove top, clean underneath
if dishwasher present, spray it and cycle
if garbage disposal present, spray and cycle
if A/C ducts in floor, open and clean
also, replace air filter, turn on blower, and spray solution into return
use your nose and try to find the source
Jun 27, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
