Question about Dryers
No Heat: The dryer has been taking more than one cycle to dry the clothes for several months, but today there was a very small load in the dryer and it took 4 cycles to just get dry enough to take out of the dryer. We made sure the vent was well attached and that there was air coming out of the vent and that the drum was tossing the clothes around. The dial keeps moving to run through the cycle, but the clothes are not drying because there is no heat in the dryer at all. We don't know if it is the thermostat or the heater that needs replacing. Please advise.
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 17, 2010
It's a whirlpool awz 7466. It runs fine, but I do not know which settings it needs to be on to dry my clothes normally. A small load will take at least 2 hours and makes laundry take forever. Any help
Hi Jennifer,
Two hours to dry a small load of laundry (even a large load for that matter) is way too long. You're wasting electricity too. The first thing you should do is consult the manual for the dryer to be sure you've selected the proper setting. The literature for this can be found here.
Consult this literature page 63 for the location and cleaning instructions for the (e) lint filter after each drying cycle and (h) heat exchanger at least monthly. Failure to clean both will result in long drying times. If you have the "Gentle" cycle selected, drying time will be prolonged, too.
Hopefully, these suggestions will help you solve the problem. Good luck!
Jan 07, 2013 | Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
May 12, 2009 | Maytag Dryers
Dryer takes MUCH longer to dry clothes than it should
Is the hose crunched down at all in the back
(vent hose)
Feb 09, 2009 | Fisher and Paykel Dryers
Dryer runs but with little heat
Generally whilpool dryers heat of dont heat.. output should be around 150 .. i would check hose to make sure not clogged or just run without hose and see if that makes a difference... post if need more help
Oct 29, 2007 | Whirlpool LER4634J Electric Dryer
Dryers Logo
153 people viewed this question
Top Dryers Experts
