Question about GE 28111EE2 Cordless Phone
How do you set up 2nd handset??
I used your instructions to set up handset 1 and it worked BUT how do you set up the 2nd handset? It doesn't even light up. I have new batteries in both.
I can not answer my call waiting on handset 2. And I can't find how to program it.
Posted on Oct 14, 2008
How to register additional handset for AT&T EL52300
Easy to do, even if the new handset is used & orphaned from
its original base...simply de-register it from the old base and
re-register it to your base.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from:
but does not fully describe these procedures.
Good luck !
Mar 04, 2015 | AT&T El52300 Cordless Phone
I have a Panasonic KX-TGA652 dual handset no answering machine. The problem I have is the 1st handset "the base set", doesn't seem to work properly, the 2nd handset works 100% fine. The problem is this,...
Id try the following in this order:
  1. Try swapping batteries with another set and see if the problem follows the battery
  2. Try re-registering the handset, they could of missed one at the factory. that is done by selecting menu->initial settings->register handset
If this doesn't work, then return for warranty/exchange. Mine seem to work great right out of the box.
the poodle guy!
Sep 29, 2010 | Panasonic Lands Phones
I have a SKPE Phillips phone VO1P8411B/37. In an effort to fix the phone I de-registered it. When I select REGISTER, it comes back with 'Registration failed'. I tried to put in the default code of 0000...
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Aug 05, 2010 | Philips Lands Phones
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Jul 22, 2010 | Doro DECT 540 Cordless Phone
The 2nd handset worked only week now it
just got the phone as a gift and it worked for one week and is now searching for the base and displaiyng out of range. Followed all tect instructions and still not working. please help
Mar 25, 2009 | General Electric 28821FE2 Phone
Ge 27831 Cordless dual phone 2nd handset doesn't work
Another user (thank yoiu but I'm sorry I forgot his/her name) had the answer. It was ihe instructions but I missed it. Needed to set the 2nd handset into the main base for 20 seconds so that it could align itself.
Mar 21, 2009 | GE 27831 Cordless Phone
Philips CD240 2nd phone wont connect - keeps saying searching
Hi, I solved this issue this morning. What you cannot confuse here is that handset and base. To do the registration successfully, the both must be in "Registering" mode. First, to get the base in the registration mode, you have to press <page> (a paging function for handset in case you cannot find where they are - usually button that says <page>or speaker with sound symbol on the base) more than 5 seconds, then the base is in the "Register Mode"(though you will hear no beep). You can then go through the procedure you describe on the handset and the handset should beep with assigned number no more than 10 seconds after it flashed "Waiting". The above, however, works only if the Base is still functioning. In my case, sadly, the base was more likely dead (if I press any button on the base, i.e. answer phone etc., there is no response). Hence I went and bought a new cheap GAP compatible BINATONE 1800 Single at Comet (14.99). I then set up the base, put it in the registration mode as per the BINATONE instruction. Then on the Phillips CD240 handset and gone through the above registration procedure... and Voila! It worked. Now I have a brand new base that came with 1 handset of its own, and 3 additional CD245 handsets which are all registered with this base. So far, the sound quality is good and they retained all the telephone numbers registered with the handset. The BINATONE base came with 12 months manufacturer's guarantee so I am sorted with the base problem for at least a year, which is nice. I hope this is helpful. Best, Ken
Feb 03, 2009 | Philips Lands Phones
Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Jan 26, 2009 | GE 27958GE1 Cordless Phone
De-registering my 2nd handset
I unplugged the battery and plugged it back in and it fixed the problem
Nov 04, 2008 | GE 28111EE2 Cordless Phone
Use 2 phones for one line??
take the 2nd handset to the working base unit and go to the menu, registration mode, and access handset registration. it must have the same password number as the first handset.Thank you. JER.
Feb 18, 2008 | Lands Phones
GE 28111EE2 Cordless Phone Logo
85 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
