How do I reset network connection on laptop so it reads my router.
    Scholar:
  • 135 Answers
Try Start Run CMD
ipconfig /flushdns ipconfig /release ipconfig /renew
if this dosent work go to Device manager and delete the network card and reboot this will cause it to reinstall the NIC card and it should pick up the router upon internet discovery phase
Posted on Oct 12, 2010
Wireless connection
Turn off the laptop, unplug, remove battery, plug in. Push and hold the reset button for 30 seconds or so on the Netgear to reset to default settings. Boot laptop, when boot is complete, Open Network and Sharing Center, click on Manage Wireless networks, remove your OLD wireless network. Close Network and Sharing Center. In your Tray Notification Area , left click on the network icon, select unsecured Netgear Wireless Network. When connected, reconfigure SSID and Security Password.
Dec 16, 2012 | Acer Aspire 5742Z-4200 Notebook
I have d-link router ,works fine ,my new laptop hp don't connect to interent ,see the network ,but unable to connect
Hi amany91,
There might be an issue on your wireless connection security settings. I would advice resetting your router to remove the password and to restore to factory settings. To do that, look at the back of your router and look for the RESET BUTTON. Then using a pin, press and hold the reset button for about 10 seconds. After resetting it, restart your laptop and then try connecting to your router again.
You can rate my answer if you appreciate it.
Thanks!
-damneddle
ternet again.
Oct 09, 2011 | D-Link DIR-615 Wireless Router
From I read online need to reset my belkin router. How doi reset my belkin router so I can use my laptop. The model number is F5D7234-4-BC v1
In the back of every router there is a little hole that is used to reset it. Sometimes is just colored different and some times it says reset next to it. It would be the only one. Just use a pen or paper clip and push in gently so the little rubber depressor does not break and hold it in for 30 seconds(make sure you do 30 sec on a watch nut quick counting). Router needs to be ON when doing reset. Once reset is done you might have to disconnect power to it for another 30 seconds but only if your internet is not working. Hope this helps.
Mar 13, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
XP laptop will not acquire network address after restarting. It works right after running the setup disk but will not work after a restart. Motorola-6FF0D modem/router connected to Windows 7 desktop. Have...
Pls try this following below and just cool down and read through,
Physical causes and What to Do...
  • Network card could be faulty or malfunctioning, or the port on the card itself. Make sure lights show on the card and if they don't, replace with another one that works.
  • Check that your router or the server is turned on so that the laptop can acquire a valid IP address.
  • Double check to make sure the wireless card on the laptop is turned on. Do not assume it is on by default, do it yourself.
Logical or Software causes and solutions
Many of us are online buyers. Items sold on the internet, especially used items, are not in their default settings. Previous owners do not always reset them before sale, and this causes a lot of issues and unwanted beheaviours. Below are some of the common settings found on Routers:
  • ISP user name and password. If you want to connect to the internet check with your ISP to get your own User name and password, if not ignore this step.
  • Looking at the security options, make sure:
    • MAC address Filtering is not enable. If it is, remove all the MAC addresses on the MAC address table, and enter your Laptop's network card MAC address. With MAC Filtering On, do not forget to enter the MAC addresses of all you wireless devices on to its table.
    • Wireless key settings. Disable the wireless key settings and configure it to meet your requirements.
  • A Laptop to Laptop connection, please make sure the wireless settings on both laptops are the same.
  • Inconsistent wireless Keys. The key on the laptop has to match the one configured on the router.
  • Drivers out of date, update your wireless adapter drivers or your router firmware by checking the manufacturer web site.
  • Wireless not enable on the router. If wireless is not enable on the router, there is no Wi-Fi signal at all. some Router would have wireless turned off by default, and it is the administrator decision to use it or not.
  • DHCP Server misconfiguration. Make sure the DHCP (Dynamic Hosts Configuration) server is properly configured:
    • Enough IP address lease for your network devices
    • The server itself is not down
  • Some simple troubleshooting methods are:
    • Repair the connection. On Windows, click start - Control panel and then Network connections; chose the right connection icon, right then select repair. Windows will, temporarily, disable and re-enable your network adapter to attempt a connection.
    • Reset the IP stack. Click start then Run. At the command prompt type "command" or cmd for short, you are then presented with the command prompt window. Type "netsh int ip reset resetlog", and then restart your Laptop. This applies to desktop computers as well.
    • Reset the router to its factory default. Most routers we use at home are fitted with a reset button, by pressing and hold it for few seconds will bring the router to its factory default. This method solves a lot of the issues mentioned earlier, in one go.
    Nov 10, 2010 | Arris SURFboard SBG900 Wireless Router...
    I bought the new sylvania 7" laptop. I am having problems.. We have connected to our wireless router however, we not get on the internet...
    from another computer, go to the routers configuration screen and make sure the status shows that it is connected to the internet. Also the routers internal LanIP address must be 192.168.1.1 for the netbook to work.
    Sep 19, 2010 | Sylvania G-Netbook
    LImited or no connectivity on wireless router after reset
    hi
    go to the router wireless settings and check to see if the wireless connectivity has been disabled as a part of default settings
    cheers
    Pls rate if this was any help
    Jul 04, 2009 | Microsoft Wireless Network Adapter Xbox...
    Need network key for wireless network connection
    This is your password on the router. Do you know it? Are other computers on this router? If not you can hold the reset button on the back of the router for 30 seconds and it will reset to factory default. No network key needed, then log in to your router and set a new network key.
    Dec 26, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Home router won't exchange IP to set up wireless on laptop??
    try resetting the router to factory settings, it may have been set to allow only 2 or 3 wireless connections, just take a pen and hold it in the reset hole on the back of the router till all the lights blink and it restarts
    Dec 10, 2008 | IBM ThinkPad T40 2373 Notebook
    Desktop works (direct to router), laptops cannot connect
    first of all make sure that the wireless settings of the router match the settings of your wireless computer.
    make sure also that there are no friewall or security programs running in your computer because they can interfere with the wireless connection as well.
    Aug 17, 2008 | NetGear RangeMax WPN824 Wireless Router...
    Changed router settings and now unable to access the network and internet
    Just reset the router (there should be a reset button somewhere on it) it will default to open system. Then go back in and select WEP with 64 or 128 bit security. Generate your KEY and next time it connects enter the KEY. You should be set to go!
    Jul 28, 2008 | ASUS Computers & Internet
    Computers & Internet Logo
    David Payne
    David Payne
