Question about HP L1955 19" LCD Monitor
The power cord plug-in on the actual monitor is loose making it impossible to keep the monitor active. I was able to get it to work once in a while by moving the plug going into the monitor back and forth. It won't do it for me anymore. How can I fix this?
  • 386 Answers
Hi Good day!! try to change the power cord.
Posted on Oct 12, 2010
I have an hp compaq dx2400 micro tower desktop , but it doesn't work when I pluget it to the monitor,PLEASE HELP I HAVE A LOT OF DATA ON THAT PC
Make sure you are set up for correct monitor. If keyboard lights flash and HD beeps, but no picture, you may have an incorrect monitor setup. In BIOS, make sure you are set for proper internal/external video, and be sure to plug into right port.
Dec 05, 2014 | Computers & Internet
How do I fix my hp w17e monitor that reads "VGA no signal"? I've tried unplugging my power cord and holding the on button for 30 seconds to a minute and plugging the power cord back in it still...
VGA no signal means "no signal" from the computer on the VGA (blue plug) cable... ...if the computer works check the cord for loose connection or get a new cord...if the computer is hooked to the digital cable (DVI/white plug)...set the signal source on the monitor to digital...
Feb 14, 2011 | HP w17e Monitor
I tried turning on my monitor and it wouldn't turn on. I checked the power cord and everything was connected correctly. Any Idea;s?
The first step is to make sure the plug you have the power cord plugged into is supplying power to the monitor. [surge protector? Check the switch or the reset button]. Check for the powered on light, usually in the power on button on many computer monitors. Yellow usually means a bad connection with the computer. So the monitor is actually on, it just appears off because you have a black screen. Check the video cable linkage to the back of the monitor and the computer's graphics card or digital video out.
If when you "power on" the monitor's on light does not light it means that power is not getting to the unit and you could have a bad power cord. If it is of the universal type that unplugs from the unit you can swap out for a new cord to test this [some monitors have external power supplies as part of the cord and this could be the problem]. If swapping it for another works than that was your problem.
Many monitors though have their power cords mounted via chassis clamps to the unit and have internal power supplies and are not end user serviceable.
If power is making it to the unit there are a handful of possibilities. Unfortunately the majority of them, at that point, involve dis-assembly of the unit's outer casing and is not advisable to an untrained end user. A service call would be required at that point.
Feb 10, 2010 | Mag Innovision InnoVision LT765 17" Flat...
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
How to know if the monitor is totally dead?
Generally, if the power light (LED) doesn't come on and there is no screen display with or without input signal, it's dead. Probably a failed power supply.
Aug 29, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
No video
Check the actual VGA or other connection connecting to the monitor. Is it loose?
Then, check the actual cord out with another monitor. If you get video, then it's the monitor. If you don't and it worked on another system, then it's the cable.
Aug 08, 2009 | Computers & Internet
My monitor keeps on flickering and at times it just has lines on it. Eventualy it comes on but then it start all over again
Hi foomouse! Try the following solutions. If none of them work, it's time to get a new monitor unfortunately.
1. With everything turned off, including your power cords, make sure everything is securely plugged in. Many times people swivel their monitors to adjust them and the cord gets loose in the back.
2. Update your video drivers which can be found in many places on the web.
3. If this just happened recently, do a system restore back to the last time you remember the monitor was working properly. It should be under Programs>>Accessories>>System Tools>>System Restore.
Hope one of these works for you!
Aug 06, 2008 | Computers & Internet
LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Jun 02, 2008 | LG Flatron L1710S 17" LCD Monitor
Internet connections
Hello I am sorry you r having this problem, I need to know a little bit more info, Now when you plug in your computer to power cord you loose everything with you internet connection. Do you see the active monitor in the lower right hand side, it would look like a monitor blinking or it may not be blinking. Have you also tried to activate the antenna after you plug in your power cord. There should be a button with an antenna on it the upper part of the pc, You may also go into your control panel and turn it on there, It sounds like its set to shut down the wireless connection when plugged in, its just to opposite as what it should be, usually its when you unplug your computer that the internet connection is lost for power saving reasons, you can also right click the connection monitor in the lower right and properties and repair after the power is plugged in of course give that a try and see if that works for you, I hope it help you out with your problems
Jan 15, 2008 | Acer Aspire 5100 Notebook
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
HP L1955 19" LCD Monitor Logo
91 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
