Question about Insignia Televison & Video
How can I connect my vhs player to my insignia tv? It already has a built in DVD player? I've tried the tri color cords but they don't work.
    Scholar:
  • 143 Answers
I would need to know the model number of your TV to be sure. But the RCA plugs should work (tri-colored cords... Red, White, Yellow typically) But if it's a combo TV/DVD player... you probably need to change the input to AUX1 or whatever the tri-colored RCA jacks are plugged into... and not on DVD setting. Try that. and advise back!
Posted on Oct 12, 2010
Green tint on TV screen when playing DVD's or Videos 2nd problem and can't record anything
1: Hi i would recommend trying the recorder on a different tv to check if the problem continues. If the green tint is gone then its the tvs inputs. If it is still green then its the player or the cord. Try a different cord if the green tint is still there then the player has a problem.
2: Now for the VHS to DVD. There are general a lock out encoded on the VHS if it is a store bought movie. This is to protect the content on the VHS from piracy and that would case the DVD to be blank. The VHS to DVD are made for converting your home videos like family vacations and stuff you record your self and not for commercial movies like the ones you bye at the store. If you want to convert old VHS movies to DVD you would have to get another VHS player and another device in between the VHS player and the VHS to DVD recorder.
Mar 19, 2014 | Televison & Video
No sound when playing dvd, connection to vhs player
tried to record coming from other tape and replace the audio cord.
Sep 15, 2012 | Televison & Video
I have an old emerson TV/VCR (Digital Tracking VHSHQ) The TV works fine, but when I put a tape in it is ejected and part of the tape stays inside, but can be pulled out.
Try a VHS Cleaning Tape Cassette. Follow it's instructions. If no better result it's not worth throwing away money on having repairs done but better put toward, if you can afford to, buying:
Option 1. A VHS/DVD player (combo as these are known) and plug that into the Emerson AV input.
Option Two: A VHS/DVD twin recorder combo deck - and plug that in.
Then start on copying any VHS tapes you cherish to DVD on this device.
Option Three: Forget the Emerson except for just using as a TV and buy a new TV with DVD player built in - the latest type of combo.
(I'm having to guess whether you've just used tapes to watch or record and watch)
Sep 26, 2011 | Televison & Video
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
No color
Please set your TV on Auto Color system to get colors on VHS and DVD.
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
No sound when dvd is connected to Insignia tv
If you are trying to use the S video you wont get sound . try using a HDMI or the composit cables. If you don't have a HDMI and have to buy one ** don't buy the expensive one as the TV don't know the difference no matter what the sales man tells you** the cheap ones work just as well.. if your DVD don't have HDMI connection us the composit RCA cables. Make sure you are connected to the audio IN not the output on the back of the TV.. use the video 1 inputs on the set they are color coded to match the cables.
this should get things working for you
Jul 03, 2008 | Insignia 37" LCD Flat-Panel HDTV
Stand Alone VCRs do not play pictures on my Insignia 24" TV
Did you try using teh SV cables supplied or the RF cable?
Easier to use the AV Cables. 100% should work. Connect Video OUT of VCR ro VIDEO IN of TV and AUDIO OUT (L) and (R) of VCR to AUDIO IN (L) & (R) of TV. Select AV or VIDEO on TV using TVs remote. Play a Cassette. should work!!
Apr 04, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
