Question about Maytag MEP5770 Electric Kitchen Range
The "dual choice" element turns on for a few seconds, gets hot, then shuts off. This happens on either small or large setting. Also the hot surface indicator light for that element always stays on.
  • vartanv Feb 07, 2011
  • 29 Answers
SOURCE: Hot surface indicator
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
Posted on Nov 14, 2007
  • 146 Answers
SOURCE: Large Dual Element Is Not Working
Check the center ring. If it is open replace it.
Posted on Dec 21, 2007
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
  • 22 Answers
SOURCE: Small burner of dual surface(right front) stopped working.
Does yours have the (small large burner switch)? If so, try switching it back and forth. It could be defective or your small burner element is bad.
Posted on Mar 14, 2009
Maytag317
  • 1136 Answers
SOURCE: Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
Posted on May 30, 2009
The Dryer is running too hot (red hot) and not turning off or running it's cycle.
You want to do a few things to correct this. First make sure your air flow is good. then replace the cycling thermostat. That stat is mounted on the blower housing right next to the fuse:
I recently worked on a dryer that was doing this exact thing and I replaced the control thermostat.
My friend Larry brought it by because it was overheating and he had already changed the fuse once.
I always see the tough or the strange. LOL. Anyway I took the dryer completely apart and cleaned it up real good. Replaced the fuse and observed the dryer with the back off. I watched the heating element and it just stayed on way too long. Normally you can hear the control clicking and observ the element coming on and off. The cycling thermostat has 4 wires. 2 small wires and 2 large wires. The large wires carry the current to the heater element. The 2 small wires are use to warm up the klixon so that it will shut down even faster for knits and perma press items. So what goes wrong? The bimetal inside the control simply gets fatigued and don't shut down no more. The dryer overheats and the fuse blows.
Oct 21, 2011 | Whirlpool Inglis IP8200 Dryer
Tip
Electric Oven Problem Oven will not shut off
If you have ever experienced your electric oven not shutting off, then you know what it is like to have the oven overheat. It can be a very scary experience. If this happens to you the only thing that will turn it off is unplugging it from the wall outlet or turning off the circuit breaker. Either one of these actions will totally turn off the power to the oven. This will make sure that the oven will no longer heat.
Now, the question is. What happened inside your oven to cause this problem? The problem is with a device called a contactor. This is just a very heavy duty switch that turns the current on and off to the heating element in your oven. Every time this switch opens and closes a small spark or arc happens. Every time this spark happens a small piece of the surface area is melted. After this happens thousands of times the surface of the contactor becomes very rough and the two surfaces do not connect very well. When this happens the surface becomes hot enough to melt a large area of the surface. This melted surface then “welds” together. Now the contacts cannot pull back apart and your oven is on continuously.
The only fix for this problem is to replace the contactor. This is not a hard task and can be done by most handy persons. Just make sure that you have the correct replacement part and that all the power is removed from the stove/range/oven before you attempt to replace it.
If this problem does happen to your oven and you did not realize it for a long time, you should also expect to have other problems after you fix this problem. The excessive heat will cause other problems such as burnt wires, terminals, burnt fuses, and a number of other problems that would be heat related.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Mar 24, 2010 | Ovens
I have a GSW Series 5 water heater (electric). I think the heating elements are bad or going bad. The heater is about 12 years old. Its a 40 gallon heater, and I've noticed the amount of hot water is less...
It may be one of 2 elements not working, a thermostat problem, scale build up in tank, to name a few possibilities. You'll need to shut off power to water heater before doing anything to it, and perform a few tests, and check a few things to determine which one is the cause. After power is off, you remove cover(s) on side of tank and peel back the insulation to get access to element(s). Keep in mind that should you need to change one of the elements, or both (assuming it has 2 otherwise you wouldn't have any hot water at all if only 1 element and not working.) This is where it would be good to have a voltage meter ( or multimeter ) and know how to use it. Is that possible? Before you reply, please shut off power and remove cover(s) to be sure whether single or dual element. If it's single, it may just be thermostat adjustment, or faulty, or scale build up around element. Keep in mind that water to tank will need to be shut off and tank drained down below element before removing/replacing. Get back to me with info on single or dual element. Thanks
Jan 10, 2011 | Fasco GSW Hot Water Heater Exhaust Draft...
Viking model vdsc4874gss small oven works fine large oven element on bottom only gets hot in cleaniong mode, fan comes on when dial is turned to convection but no heat power is on light works
One thing that you can check is make sure that you have 220 volts at the plug. Leave the unit unplugged and check continuity on the burners. You should have continuity on the burners.
Oct 18, 2010 | Viking 48" 6 Burner, Grill Professional...
Large burner elements ignite, and igniter spark fails to stop, then the burner shuts off as if ignition failed. Tiny central burner element does NOT light at any time. Apparently the safety cutoff...
There is a thermistor that must be in the flame area that needs to get hot. When hot it will turn the igniter off and keep the flame on. Check it's location and if it is in the flame then it needs to be replaced. not sure about the central flame problem. could be the switch.
Sep 20, 2010 | Gaggenau 36 in. KG 291 Dual (Electric &...
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
May 17, 2009 | Kitchen Ranges
Mar 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
Dual Element
check underneath the element, you may have something preventing the element from gihting up. if you didn't find anything, then it is time to get a new element.
Oct 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Dec 21, 2007 | Maytag MER5765RAS Stainless Steel Electric...
Maytag MEP5770 Electric Kitchen Range Logo
24 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
