How do I erase errors from my computer? - Computers & Internet
    Master:
  • 503 Answers
Depends upon what computer you have an what errors need more information.
Posted on Oct 12, 2010
  • 7,733 Answers
Search for CC Cleaner or rite more about your problem!
Hec41 paswered
This is kind of tricky error, but depending on your board configuration, it can be erased, just neet to access your board and look for jumper CMOS erase, or push botton that lead to Clear Cmos.
its on the board, usually near the battery. or RTC.
Carl
Jan 09, 2016 | Computers & Internet
I took it to the mechanic and diagnosis done revealed 0xygen sensor!i replaced and after a month i traveled and the problem is there!what could be the problem?
HI, are u sure mechanic replaced the O2 sensor with a new one?
or he just erased the code fromt he computer.
1. we can erase the error codes using the OBD meter. this will remove the check sign from the dashboard, after some time when the error is generated by computer the check sign lits up again,
2. if an oem o2 sensor is used, it wont last for very long.
3. replace it with orignal o2 sensor.
Aug 12, 2013 | 2003 Honda Stream
Error code P1605 and P1775 on 2004 Land Rover Freelander
P1605....Serial data communication problem with HVAC modul
P1775 Transmission system MIL fault
Go to the repair shop , for scanner and computer test.
The best (safest)way to erase trouble codes is to use a scan tool. The tool communicates with the vehicle computer and tells it to erase the codes. It does not alter any other learned settings that should be retained for normal vehicle operation.
The worst way to clear codes is to disconnect the battery. In most older vehicles (those made before 1996), disconnecting the battery even for a few seconds, or removing the power fuse for the engine computer (PCM) will erase the codes, along with all of the other learned settings the computer has stored over time.
Sep 18, 2012 | 2004 Land Rover FreeLander
Error displayed "device 3 service
Computer unplugged from power, computer on a table, computer case open.
Observe Anti-Static Precautions.
Remove the Ram Memory. Clean the gold plated contact pins with a pencil eraser.
Both sides.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can click on the photo to enlarge. You can enlarge twice)
If you do not use a solid eraser, and the eraser on the end of a pencil, refrain from letting the metal band touch the contact pins.
Use air to remove the eraser dust.
You can use a can of compressed air for computers, or air pressure from your mouth will be sufficient.
Reinstall the Ram Memory module/s.
Plug the computer into power, WAIT 1 minute, turn the computer on.
Regards,
joecoolvette
Oct 29, 2010 | ASUS K8V-MX Motherboard
World of war craft errors
Go to the World of Warcraft folder.
Delete the Interface, WDB, and WTF folders.
Restart WoW.
This WILL erase all your settings and addons.
If you prefer not to erase all your settings and addons:
Rename the Interface, WDB, and WTF folders.
Restart WoW.
What this does is resets your game to the original install and will remove any potential corrupted files causing the error messages.
Hope this helps!
Oct 11, 2009 | Blizzard Entertainment World of Warcraft...
Cam position sensor error.
Needs to be reset with a scan tool.
Sep 17, 2009 | 2004 Audi A4
Error code yamaha r6 2007 51 how can i erase it?
could be a safety shutdown by computer, only your dealer can erase the code....and then you'll find out whats wrong...and why the computer doesn't want you starting and damaging the bike.......Good Luck to you friend....Tim
Apr 25, 2009 | 2007 Yamaha YZF-R6
Dos error
Reformat your player. Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
If you still get the same error: Reformatting through your computer usually involves plugging the player into the computer, double-clicking on My Computer, right-clicking on either the icon of the mp3 player or the generic drive letter that your computer has assigned to the player, and selecting “Format.” FAT32 is usually the correct option, but I would always consult the manufacturer/user manual first to be sure.
-Tha Mp3 Doctor
Dec 21, 2008 | SanDisk Sansa e250 MP3 Player
How???
Just connect an MP3 cable fron your player to to your computer, and go to MY COMPUTER and click on the drive that represent the MP3 player, you can delete the music files from your player.
Dec 13, 2008 | PQI Joytone U820 Digital Media Player
Write error
The camera should be the one to format the removable-memory, if you use a computer, well that is what you get. The best thing to do borrow a memory the same as yours and copy it to your memory. Then erase contents of folders only, leave the folders empty... This is causes an error if folders are erased from the memory.
Dec 15, 2007 | Fuji FinePix A330 Digital Camera
Computers & Internet Logo
David Payne
David Payne
