Question about HP PhotoSmart 7660 InkJet Printer
What is the cartridge cradle
It keeps saying the cartridge cradle is jammed!
  • 3,940 Answers
The cartridge cradle is where the ink cartridges are installed. It slided back and forth on a silver rail. If the rail gets dirty, the cradle can stick and not move freely. Try cleaning the rail with a soft clean dry cloth.
I've also see the cradle become disconnected from the belt that moves it back and forth. If that has occurred, and it is out of warranty, it will need replacement.
Posted on Jun 01, 2008
HP PSC 1500 series: printer says the "the cradle is jammed" tried tuning it on and off and adjusting the cradle. taking out the ink cartridges and putting them back in. nothing. Someone please help?
Did you check for a Paper jam? Even a little bit of paper can cause a jam and that is normally what your problem refers to.... using too thick of paper can cause this kind of error as well
Sep 07, 2013 | HP PSC 1500
My printer keeps saying print cartridge cradle is stuck clear jam then press ok, but there is no paper jam
Because it's NOT a paper jam, but a cartridge cradle jam, I suppose it's an ink jet printer??? if so, check for debrie arround the cradle shaft that could prevent the printing cradle to move from left to wright... you could also lubricate the shaft by rubbing a little bit of grease on it with the tip of your finger (verry thin layer), as ink sometimes gets on it and tends to become sticky with time...
Aug 10, 2011 | HP Office Equipment & Supplies
Screen says cartridge cradle is stuck but it moves freely
Ok there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | HP PhotoSmart 7760 InkJet Printer
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
Printer keep saying print cartridge cradel is stuck and clear jam, but there is no jam.
check the sensor , either there is somthing stucking on the sensor you cannot see it, either the sensor it self becomes bad.
Apr 17, 2009 | Office Equipment & Supplies
Printer mp130
take the ink cradle out and take the cartridges out. clean the print head on cradle with alcohol, and you might wanna try blowing the ink residue out of the head becuase the black ink cartridge leaks
Jul 10, 2008 | Canon PIXMA MP130 All-In-One InkJet...
HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Jun 26, 2008 | Office Equipment & Supplies
Having problem with cartridge cradle
Try lifting up the cover and taking the cartridge out. Put it back in and it should be fine.
Jun 01, 2008 | HP PhotoSmart 7660 InkJet Printer
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
HP PhotoSmart 7660 InkJet Printer Logo
284 people viewed this question
Seeker5211
Seeker5211
