Question about Fender Rumble Series 100/210 100watt 2x10 Bass Combo Amplifier
Will the rumble 210 bass amp be enough power to be heard over acoustic drumset without damaging speaker due to higher volumes? What would you suggest for additions to maximize sound and/or volume?
  • Fender Master
  • 5,603 Answers
It should be adequate... If necessary put shields around the drumset and tell the drummer to take it easy and don't showboat.
Posted on Oct 12, 2010
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
Takamine eg523sc... the bass string (6th) is about 30% less in volume as the other strings what could i do to correct this problem?
You should take this to a guitar shop for setup. If you have correct strings on there the other thing is to check any EQ of whatever you run this into... If the amp can't handle the real low bass, it MAY appear to be a guitar problem but in fact is an inadequate frequency response at the low end in the amp and speaker.
ALSO some people believe it or not get deaf in the low range if they have damaged their ears when young. Procure a sound meter to VERIFY the sound intensity level... You may find the level is the same for the different strings.
The weak spot for bass is the SPEAKER in the amp.
Feb 14, 2011 | Takamine EG523SC Jumbo Acoustic Electric...
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
Amplifier Screech at High Volume
What you're hearing is FEEDBACK caused by the nearness of the guitar to the amplifier speaker. Always mute it when not in use, or don't move it close to the guitar amplifier speaker when unmuted.
Usually, even though you hear a high-pitched screech, the problem is actually caused by low frequencies, sometimes below the human hearing threshhold (i.e., subsonic) because they are more omnidirectional and thus more easily easily can loop between input (the guitar pickup, especially on a hollow-body guitar) and output (the speaker). The screech frequency is determined by the distance between input and output, determining how quickly the output reaches the input (then loops around through the amplifier). Therefore, reducing the BASS a bit will often alleviate some of the problem.
This is basically the same type of feedback heard when a microphone is turned up too loudly or the mic is pointed at the PA speaker. Avoid those actions and your feedback will be minimized.
Only time and experience will allow you to automatically take actions to avoid feedback. I worked in the San Francisco Bay Area as a manager and sound man for rock bands and several nightclubs for 22 years. My college major was Physics (which includes acoustics).
Keep on rockin'!
Feb 10, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
I think I blew out the woofer...low frequency rumbling...is that something that can be easily switched out?
The woofer would only blow if it was overloaded with too much signal. The common cause of this connecting a speaker of lower power than the amp or ohms than it. The simple way to cut out rumble is at the amp by reducing the bass, however most amps will cut all the bass and not what you want. Another way is a filter designed to cutt bass or low sounds. However your best bet is to use a Graphic Equalizer to control the tone, most have a 31khz control which will cutt the rumble you describe, but keep the wanted bass sound.
Oct 19, 2009 | Mackie MR5 MR5 Reference Monitor
I have a rumble 100 bass amp which used to work fine until now! I've had it about 2 months and have only played it about a dozen times. Today, while practicing with a new band, 90% of volume got lost. Now...
It unfortunately sounds like a blown speaker. Try getting at the speaker and gently moving the cone with your fingers. If you feel a rubbing sensation you will most likely have to consider a new speaker. Make sure you get one with the same impedance (ohms) and the same or better power handling.
Jul 07, 2009 | Nomad Factory Fender Rumble 100 Bass Combo...
Fender Rumble 100 210 pop noise then hum after strong low e note
I just fixed my bass amp with a similar problem last week: the problem is related to a loose connection on the PCB board (likely).
A bass amp is a rough place for circuitry: the low rumble and power shake a bass amp more than a guitar amp.
In my case, the power transistors needed to be re-soldered and then the grounding bolts and screws needed to be removed and cleaned because the connection was bad. Remember that when two different metals needed for an electric connection are toughing, there is the likelyhood that corrosion WILL happen.
My bass amp did basically the same thing yours did: sounded good at low volumes, but at higher volumes it would act up.
In short, there is nothing you can do (unless you are a repair person): you need to take it to a local music shop and have a tech fix the intermittant contact problem: someone who knows what they are doing should only take an hour at most.
Hope that helps!
-mike
Feb 22, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Replace C21 (10uF/50V) and C38 (2.2uF/50V) and it will work great.
Feb 22, 2009 | Fender Rumble Series 100/210 100watt 2x10...
Fender Rumble Series 100/210 100watt 2x10 Bass Combo Amplifier Logo
139 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
