Question about Apple iPhone 3G
My home button won't work on my iPhone - Apple iPhone 3G
IPhone 4S won't turn on
Try holding down your Home Button and your Lock Button at the same time for about 10 seconds or until you see the apple logo. This will restart your phone and should resolve your problem!
May 01, 2013 | Apple iPhone Cell Phones
My iPhone 3GS won't boot (Endless Reboot). Can't enter into DFU to restore.
You almost had it. First have it pluged in like u did. Then while its trying to start hold the home and power button untill it turns off like u did at the end. Last release the power button but hold the home button down. Do not let go of the home button untill it works. If it wont it will reboot like it had but it will work.
Apr 11, 2013 | Cell Phones
IPhone 4 shut off and won't come back on
hold the power button and the home button till you see the apple
Aug 23, 2012 | Apple For iPhone 4/8GB LCD Screen...
Is there a way I can charge my iphone when my home button and charger won't work?
Try taking it in to an apple store. Given the age of the phone, there may not be anything they can do to assist. Unfortunately, unless you try your luck with a third-party phone repair company, you will need to find a new phone.
Dec 08, 2017 | Apple iPhone Cell Phones
Iphone shuts off and won't turn back on what do i do?
You might try holding down the power and home buttons at the same time. Wait until you see the silver apple. Thats what I did when mine wouldn't turn back on.there is an easier way instead of just guessing....
when you plug it into any form of charging source...just completely shut down your iphone...and leave it there for how ever long it takes to charge...(to be able to use it again is about 30 minutes)depends on your energy sourceFirst open iTunes and Conect your iPhone cord to your computer, but do not plug it into your iPhone. Then press and hold the home button on your phone while conecting the iPhone cord into your iPhone continue to hold down the home button. Then click restore in iTunes
Feb 15, 2012 | Apple iPhone 4 Black Smartphone
My iphone won't turn on. It is not charging nor is it being recognised by my computer. I did not drop it. Last thing I did was end a call. Please help
My iphone 4 was also dead a few minutes and the solution was to connect the fone to computer and then press home button and on/off button for about 10-12 secs and the apple logo appeared and it came back to life, you can try that and I hope it will also work for you. Enjoy!!
Sep 16, 2011 | Apple iPhone Smartphone
I dropped my iphone and it said no sim, i put it back in but now the home button doesn't work and it won't charge a and my computer is not registering it when I plug it into the usb port, is there...
Hi
its seems like you have loose connection inside of phone. because home button and charger port have same pin connection.
My advice is you have to take your phone to technician.
thank you.
Sep 07, 2011 | Apple iPhone Smartphone
I dropped my iphone 3g and cracked the screen....I replaced the screen and now the bottom half won't work...it says slide to unlock...and it won't slide...but the top that says slide to turn off...
Check the 2 pins connected on the home button if touch the interface of the board,might not hitting that is why the slide unlock not working.
Jul 21, 2011 | Apple iPhone Smartphone
My iphone won't search without the screen getting dark and un readable then freezes
iPhone into DFU mode so you can do an iTunes firmware restore follow these steps:
Open iTunes and connect the iPhone to your Mac.
Press and hold the Home button and the Sleep/Wake button at the same time.
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone screen will remain black
: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long!
May 08, 2011 | Apple iPhone Smartphone
My iphone won"t turn on
you should be able to reset it by keeping pressed the top button and the home button for more than 10 seconds when it si connected to you computer. let me know if it works!
Apr 08, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Logo
590 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
