Question about Philips Magnavox 51MP392H Rear Projection Television
Hi again!!!
Is it located on the same board as the rca jacks ??? if not how do i get to it!!!
  • Philips Master
  • 8,617 Answers
The RCA jacks should be near the signal board. The vertical will be on the same board as the Flyback which Is a large transformer with the large red wires coming out of it. You shold be able to remove the screws in the chassis and slide the chassis out and tip it up so you can see the under side of the boards.
Posted on Jun 01, 2008
I have a mitshibushi 1800 tv. which will not power up blue light then red nothing happens
I repaired one these. The convergence board is bad. You will have to change the two STK Ics. These will have, I believe thirteen pins, mounted on large heat sinks.. And that is not the only problem. You will need to resolder this board as there are as many as 15 bad grounds. This board is very thin and you need to exercise care pulling it out,desolder, install and solder in the new ICs. Once again this board is very fragile. Another name for this board, is the signal board, look for all the RCA jacks and RF connections on it. Thanks for asking
May 15, 2014 | Mitsubishi WS-55809 55" Rear Projection...
Hi my rca p52937 won't turn on and is making a
The ticking sound is almost always caused by the Flyback and Hot transistor. It could be other items also located on the deflection board but flyback is most likliest. You can get a replacement flyback and Hot tarnsistor from www.tvrepairworld.com
Jul 07, 2011 | RCA Televison & Video
Have a philips 9p6034c103 that powers up, but the lights go off after a few seconds. the power led remains lit.
If you can remove the back cover off the TV, do so. Be sure your TV is unplugged of course. You will see two large boards on the floor of the TV. If you can look between the two boards, you will find three or four jumper connections that connect these two boards. Remove jumper jack (location # 1516). Now plug your TV, power your TV up. The TV will come on. You may notice your convergence is off considerably. To correct this, there are two different ways to repair this. Contact www.TvRepairKitscom. This website is very helpful, and will lead you to a repair. The second idea is to contact Union Electronics at 1 800 648 6657. You will be purchasing or sending your board in for repair. You will tell them, you are need of a signal board module (has all the RCA jacks and RF connections). In both cases, you will need the model number and chassis number. Try this advice, I think we are on the right track. Thanks for asking and show all hands of support!
Jun 07, 2011 | Philips Magnavox 9P6034C 60" Rear...
Rca d52w20 52in. rearprojection tv monitor
Remove the back panel from the tv where the input jacks are located. You will see a red power wire. Just above that and to the right approx. 7" or so you will notice a [_] shaped metal shield surrounding a cgreen/gold capacitor. You may need to remove the plastic cover that is located directly above it about 6-7" in length to gain easy access. Run your finger over the top of the capacitor. If it is beveled rather than smooth you have found a definite solution to your problem. The part number located on the board is CP150 16v 2200uF capacitor. It will look like a tall cylinder. Good luck!!
Oct 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV
your SSB board is the problem its either your audio output ic or the board its self use external jacks red& white use your stereo for sound. cost of SSB board is 292.00
Sep 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 inch TV (turn on problems and channels rolling) HELP!
Your set uses the 195 series chasis. The only thing I can think of which would make the channels scroll by themselves is a contaminated PC board and pushbuttons behind the buttons on the front of the set. This is usually the case when spray cleaner or some other fluid is sprayed or spilled on the screen, and it drips down onto that board. To prove this, remove the back cover and on the top of the main chassis, where the top of the picture tubes are, is a small PC board with the remote reciever and a couple of jacks. The smaller jack is for the speakers and the larger jack is for the front panel PC board. Unplug the larger connector which goes up to the front PC board and then turn the set on with the remote. If the set works normally, the front PC board will have to be removed and cleaned or repaired (or just leave the jack unplugged and work the TV from the remote only). If you do not have any experience working inside projection sets then allow a qualified tech to handle it for you.
Aug 30, 2007 | RCA P52926 52" Rear Projection Television
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
