Question about Electrolux Epic 6500 Vacuum
I have an Elux Epic power nozzle that has a whine in it. Operation seems fine, there is no hair or material wrapped around the agitator bar. Any suggestions?
  • 694 Answers
Does the brush spin during operation? Or rotate freely if you attempt to spin by hand when the machine is off?
Although uncommon in this age of vacuum, my first thought is a broken belt, which would result in no resistance to the motor shaft, thus causing a whine.
Posted on Oct 15, 2010
My dog hair collects on my DC44 Animal. After using it on the rug it just wraps around the bar in excess. Please help.
Try turning off beater bar.but if theres so much hair its wrapping around bar u may need to use just the hose to remove the bulk first
Apr 09, 2017 | Dyson DC44 Animal Cordless Vacuum
The beater bar is making a loud noise, and the dog hair is wrapping around the bar. Why would that be happening?
You probably have dirt or garbage wrapped around your beater bar. Loose carpet strings as well as pet hair will do this. If you see dog hair on the carpet its best to pick it up with your fingers as it will make a mess of a vac. Check your drive belt as it could be on its last legs as well causing the loud noise. Probably should be taken apart and belt replaced and a good cleaning as well. You should give a good cleaning once a year.
Nov 07, 2016 | Vacuums
Power head does not work canister does . There is voltage at the power head.
Although it could be a multitude of things that keep the power nozzle from operating properly, the most likely is, since it's an Epic series, Is that the power nozzle elbow assembly needs replaced as the fine wires and top of the elbow tend to break/short after 5-10 yrs. of use.
It's also very well possible that the power nozzle reset switch or hose switch at top of handle is defective. Try plugging the power nozzle directly into the hose handle assembly and turn machine on. If the power nozzle still doesn't work, it's definitely a problem directly with the power nozzle.
Hope that helps!
Mick
Mar 14, 2015 | Electrolux Epic 6500 Vacuum
The beater bar of my Electrolux T8 vacuum doesn't work. No hairs show wrapped around the bar. How do I open the bottom to check it out? It seems to be in two sections, but removing the screws doesn
You probably need a new belt,or maybe a hose.To take the nozzle apart there a screws at the bottom of the head.Take them out then just wiggle and gently pry to top off. Chris
Oct 11, 2014 | Electrolux Access T8 Hepa Bagless Canister...
Dyson DC25 Agitator rattling
Hi Adnan, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC25's brush bar. I would encourage you to follow the steps shown in the video attached to ensure there is nothing in the cleaner head jamming the brush bar, and no threads or hair wrapped around the brush bar itself. Make sure the endcap is also fitted correctly and locked into position - a coin can be used to lock the catch.
For any further advice after you've given this a try, please contact our experts directly by calling the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA). If a repair or replacement part is needed, we'll be able to confirm if this is covered under your machine's 5-year guarantee.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Nov 08, 2013 | Dyson DC25 All Floors Bagless Upright...
Roller bar is moving slowly,making sounds while turning and motor seems to be getting hot.
Sounds like you have something wrapped around the roller than should not be there.
Sep 26, 2013 | Electrolux Epic 6500 Vacuum
My Ultra Lux 2000 beater bar still does not operate even after following manufacturer's instructions, per owner's manual. The vacuum shut off automatically when I accidentally caught it on plastic bag.
Make sure all threads, hair, and similar stuff is removed from brush, then try again.
Did you try switching the power nozzle switch off then on?
Does the power nozzle motor run? If not, and you've pressed the reset button, there's another problem. It could be a bad reset switch, or loose wires. There could also be threads or hair wrapped around the ends of the roller. This would prevent the brush from turning and shut the motor off.
If the motor runs, but the roller isn't turning, it's most likely a broken belt.
There is the possibility of the motor having burned out, but not likely.
A definite diagnosis would need to be made by a trained service tech at an authorized Aerus Electrolux store. The one nearest you can be found using the below link.
http://www.aerushome.com/storelocator/
Jan 21, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Power nozzle model #n137b of the electrolux lux5000 just stops working periodically when vacumming, now barely works at all
Make sure the brush is clear of all thread, string, hair, and similar material that has gotten wrapped around it.
There could be a problem with one of the electrical connections from vacuum to power nozzle, including broken wire in the hose. Check all connections for cracks, discoloration, and looseness.
You may need to take the vacuum to the shop. If so, make sure you take it to an authorized Aerus Electrolux store. Service tech should be able to determine the problem quickly.
Just remember, it just needs fixed, you don't need a new vacuum, and tell them that.
Oct 23, 2010 | Electrolux Lux 5500 Canister Vacuum
Agitator unit on Kenmore Progressive 116.25915503 won't spin. I have cleaned out all hair and string wrapped around it. Belt is good. It seems to spin on one side but stuck on the other. Could string be...
Pry the end caps off the brush bar, you will find hair and string wrapped up tight in the end. the bearing may also be shot, you can try and oil it up a bit to keep it spinning. <!-- from fixya rte -->
Oct 21, 2009 | Kenmore Vacuums
Vacuums Logo
126 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
