Kenmore Elite front loader HE3. When washer is switching rinse to drain cycle water is not shutting off??
    Genius:
  • 1,416 Answers
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks and good luck.
    Posted on Oct 12, 2010
    He3 elite kenmore- sUD and F21 error
    Hello there"
    Sud SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
    The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
    • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
    • Check the drain hose and make sure it is not plugged or kinked.
    • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
    • Check/Clean Drain Pump Filter of foreign objects
    • Check Drain Pump
    • Check Pressure Switch
    • Check CCU
    Dec 25, 2009 | Kenmore Elite 45986 Front Load Washer
    My Kenmore Elite front loader HE3 washer will not start.
    The door lock is not telling the control the door is locked. Faulty door switch or failed control or loose wire.Try pushing in on the door while it tries to start. Advanced trouble shooting may be required.
    Eric
    Jun 20, 2009 | Kenmore Elite 45986 Front Load Washer
    Check Pump on front loader kenmore HE3 elite
    Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
    May 26, 2009 | Kenmore Elite 45986 Front Load Washer
    Machine will not switch to drain and spin cycle
    If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
    Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
    Takes almost 2 hours to complete a wash cycle
    Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
    http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
    -Todd
    Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Water softener goes in at wash cycle rather than rinse cycle
    if it has to go in the rinse,,this means you have to put it in the fabric softner compartment of the dispencer,,,also do not fill pass mark fill line in dispencer or it will sphion down by itself before time..onthejob
    Jan 25, 2009 | Kenmore Elite 45986 Front Load Washer
    "suds" error in kenmore elite HE3 front loader washer
    Try a vinegar rinse or there are also defoaming products available.
    Jan 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Kenmore elite washer problem
    sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
    Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite HE3 washer keeps filling with water
    The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
    Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    18 people viewed this question
    Top Washing Machines Experts
