Question about Sony KDF-E60A20 60 in. LCD HDTV
Low light I have had my unit for 4 or 5 years. As long as it has been out. The brightness is turned all the way up and it is still low. Do I need a new bulb or service? Thanks, Bob
  • Bob Burt Jun 06, 2008
    Thanks,
    Bob
  • 84 Answers
Change the lamp
Posted on Jun 22, 2008
Low beams wont turn on brights will
check that you have power from the light switch to the relays to trigger the relay to turn the lights on. IT may be a faulty light switch--- fuse --light module control unit.
Jan 28, 2014 | 2009 Saturn VUE
Mercury Grand Marquis voltage reads low, but car still runs and dash went out
Worn out Battery or one that won't take or hold a charge
as well as an Alternator not working correctly
All the symptoms point to low computer module voltage
as a result of what I said above
Could be a worn ignition switch, only if that has something
to do with alternator regulator being turned on
Mar 29, 2013 | 1997 Mercury Grand Marquis
I just installed HID lamps in my 2005 Silverado. One set for the low beam and one set for the high beam. They are very bright and cansee 3 times bettter . The only problem is that they come on as soon as I...
Retrofitting HIDs into halogen headlight assemblies is ******* and my look bright to you, but they actually cast less light on the road because the reflector isn't designed to focus an HID tube. Their designed to focus a filament.
Are HID kits legal Ricks Free Auto Repair Advice
Aug 21, 2017 | 2005 Chevrolet Silverado
My light problem is i have low beam on right side no low on left side i turn highs on and right side goes out and high on left turns on then when back to lows beams and i pull turn signal to flash high...
If you have separate bulbs for the low and high beams(4 light system), if you pull the turn signal and hold it, all 4 lights will stay on until you release the turn signal. You need to replace the bright bulb on the right side and the low bulb on the left side. If your headlights only have one bulb on each side, then you will have to replace both of them to get everything to work.
Jan 04, 2011 | 2000 Ford Mustang
Does this model use a 4 headlight bright system? I have 2 low beam lights but when I put on the bright lights the 2 low beam lights go out and only the 2 bright lights stay on.
I think that many 1990s and even some 1980s GM vehicles with seemingly 4 headlight systems actually use only 2 at a time.
My 1990 Oldsmobile Cutlass Calais, for instance, had 2 high beams that went on independently of the 2 low beam lights when switched with the turn signal lever.
In the 1970s the GM vehicles had 4 headlight systems where all 4 headlights would go on, but they used sealed beams rather than the capsule lights that are used nowadays.
For instance, our 1976 Cadillac Seville has a 4 headlight system that lights up 4 headlights on the high beam mode.
Good luck on seeing at night with the current set up.
Dec 09, 2010 | 1992 GMC Sierra
2000 impala-low beams don't work but high does
sounds like the problem is the dimmer switch, get a price on the dimmer switch. If you have to, get one at a junk yard . It's cheaper.
Dec 31, 2009 | 2000 Chevrolet Impala
Bright indicator on dash on when lights are on. Dim or Bright.
could be light from a separate source. Try turning off the instrument lights and try hi/low again. If you still see the light on both hi/low, it could be in your control arm(turn signal indicator).
Nov 16, 2009 | 1999 Plymouth Grand Voyager
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Sony KDF-E60A20 60 in. LCD HDTV Logo
44 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
