Question about Xerox DocuColor 5750 Printer
The UV paper Im using to print labels is slightly peeling off the corners of the bottles after approx 24hrs. Please help, where can I find strong adhesive UV paper for my labels?
  • dietplan Oct 12, 2010
    Thanks but Im sorry I dont understand exactly what you mean. What is "green stuff"?
    Also we already have the bottles in our office so sending them to a label factory is not an option for us, which is why I posted the above request for help.
    Please advise....someone?
  • Anonymous Mar 26, 2014
    Uv outage for the lamps is only at 50 should sit at 80
  • 734 Answers
Job out your system to someone who prints directly to the bottle while you solve the other issue, which will not be solved to your satisfaction because "green" stuff doesn't stick, at least not yet, but green technologies exist for directly to the surface, so, get ahead.
Kind regards,
selk
Posted on Oct 12, 2010
Can I print cd/dvd labels please ? Cannon MP510 I have a pack
Use this simple little free app
http://www.medea.co.uk/buy/expressit-cd-labels-cd-covers-design-software-by-pressit-free-p-2014.html
Jul 26, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Zebra LP 2844 doesn't feed label all the way out for tearing off. When I print a label everything prints fine, however the last 1/4" or so is still left in the printer. Technically, it's like the printer...
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
May 06, 2010 | Zebra LP 2844 Thermal Printer
I have Samsung CLP/610 laser printer and need to
"MP tray" refers to the manual paper tray. This is the common setting for most word processors whenever printing media other than paper. This message will come not only for labels, but for transparencies, card stock, envelopes, etc. The reason for this is that the manual paper tray is designed to provide a straighter paper path that helps preventing your labels from peeling inside the unit. Therefore, I do not recommend placing them in the regular paper tray. Take note that you should also check that the labels purchased specify they are meant for laser printer or copier. Regular labels, or labels designed for inkjet printers will surely come off inside your printer and cause damage that the warranty will not cover.
Be blessed.
Apr 15, 2010 | Samsung CLP-500N Laser Printer
Paper jam
You have a piece of paper stuck in one of the switches that tells the machine you have a paper jam. One of the worst things to cause these are printing peel off labels as they sometimes peel off while printing and get caught in the mechanim. You have a jam it's just not a full size piece.
Jun 01, 2009 | HP LaserJet 3030 All-In-One Printer
How do i print labels using epson r2400 photo printer?
If you are using the Avery template, make sure you change the page setup settings from Manual Front (default) to Default Tray (sheet). Then when it tries to fix the layout, select ignore (on Wrd 2007 anyway). Then select Photo / Glossy paper and hopefully away you go.
Mar 31, 2009 | Epson Stylus Photo R2400 InkJet Printer
Polyester labels from tray 1 4 labels per sheet right side color
It says on the website the labels are 56lb (I guess cover weight). The only way the stock will run right (ie) fuse correctly is in the mp tray using one of the thicker settings. Also if you run labels out of the tray you run the risk of them peeling off making the turn out of the tray and into the machine. All non standard paper is better off using the mp tray.
Mar 29, 2009 | OKI C5150n Led Printer
Zebra S600 printer
  1. Try just storing your labels in a cool dry place before using them. Peeling labels are usually a sign the glue is poor or weak.
  2. When tearing you labels off, feed them out before tearing them off, then hit the auto-align. See if that helps it.
  3. Try pushing a normal playing card under the metal cutter that tears the labels and pull it up and through the front to bend the blade slightly outward. This will hopefully allow the labels to pass underneath.
Jul 30, 2008 | Zebra Stripe S600 Thermal Label Printer
Which types of filters can be used?
Please use thin type filters to prevent vignetting on the corners. The following filters are vignetting-free. Konica Minolta 49mm AC L37 (UV filter) (Thickness is approx. 5.5mm in total, and approx. 3.4mm excluding the screw part.) Konica Minolta 49mm ND 4x filter 49mm type causes vignetting. Please use Konica Minolta filter adapter (49mm > 62mm) and 62mm Polarizing filter II (Circular) in combination.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
