Question about Dell Dimension 4600 PC Desktop
Can't reboot windows cd on with cd drives
I can't reinstall windows xp by cd on my dimension 4600. I've tried several different discs, keyboards and even a external drive. The old windows xp has been wiped out but the new failed to completely install. Now I'm left with the F1 and F2 options leading me in circles. Anyone have a clue??????????
  • 3,940 Answers
If you have it available, boot to the Dell DImension Resource CD and run the diagnostics on the hard drive. From the description of you problem, you may have a failing hard drive.
Other things to check:
1. Ensure the system BIOS (F2 at boot) sees the hard drive and has the correct date and time. If the motherboard battery is failing, the time and date will not be retained when system is powered off.
2. If you are able to format the hard drive, but the windows XP installation process gives you file copy errors, then you may have a bad RAM module. If the system has 2 or more modules, take out all but 1, retry the install. If you get file copy errors again, try a different module.
3. If the Hard drive passes dieagnostics, but fails to complete a format, replace the hard drive.
Posted on Jun 01, 2008
How do I erase the hard drive?
Hi to erase the hard drive you will need a windows disc, on a dell you put the disc in the drive, reboot and press F12 to get a boot menu. boot from the CD/DVD drive and follow the install windows process and when you see the choices of drive space to install on select delete partition. You asked how to erase the drive it is now erased . to reinstall windows continue with the CDs instructions,exit if you just want to dispose of the PC with no personal info on it.
I hope this answers your question
Please click accept or thumbs up
Thanks
Roety
Aug 10, 2010 | Dell Dimension 4600 PC Desktop
I can't boot up normal, safe mode, or to the cd-rom on my dell dimension 4600 desktop, i've set to boot to cd rom in bios, but still nothing
If you are trying to boot off an Windows Installation disc then you might have a problem. On some computer the CD-ROM drive won't be able to read the operating system disc.
The solution to this issue would be to put in a DVD drive and try to boot from that.
More details on the normal and safe mode boot attempts would be nice too. Are you getting a blue screen or is it just hanging up?
Jun 06, 2010 | Dell Dimension 4600 PC Desktop
Having Trouble Reinstalling XP on my Dell Dimension 3000
Here's what I would do. Download and burn any Linux disk. Install Linux and delete all partitions while doing so. After that, initiate the Windows XP installation and see if that works.
This will take care of two things:
If you can install Linux, then the hard drive is good and the partition that was previously on there will be deleted (I suspect the partition is locked which can be caused by a virus or the software used to scrub hard drive).
Check your CDs for Windows (for scratches) or it could be your actual CD drive is out (laser) which would make the installation fail. If the CDrom cannot read the disk, it locks up like that during installation...even if it read before.
Sep 22, 2009 | Dell Dimension 3000 PC Desktop
Windows XP freezes up when trying to reinstall on my Dell
When you boot from the CD you will com to the point where it tell you that there is already a version of Windows XP installed. You will need ot follow the instuctions on the screen to delete the existing partion. Then and only then will it format the drive.
Let me know how this works out for you
My Dell Dimension 4600 needs to be reformatted. The Dell reinstallation OS disk boots up and gets as far as "Windows Setup....press Enter to continue". Then it freezes. I have tried using both the original...
Before you go ahead and try reformatting the system , Please disconnect everything from the system (Except Mouse, Keyboard and screen)
and then try to use the disc to reformat the system. and if it still hangs up or freezes up that clearly seems to be a hard drive failure.
Hope this help.
Cheers!!!!
Jul 16, 2009 | Dell Dimension 4600 PC Desktop
Starting whole system over
Use another PC (or a friend's PC) to download a program called "Malware Bytes" (Google it). Transfer the program to the infected PC by way of a USB drive or CDR and run the scan and clean program. Hopefully this will allow you to access the web afterwards so you can update Malware Bytes to the latest version and do a more thorough scan. Should you need to reinstall Windows you are going to need a OS CD which matches your system's OS (XP Home, XP Pro, etc.) before you will be able to perform the reinstall. You may want to contact the manufacturer to order a recovery disc for your specific machine.
Feb 19, 2009 | Dell Dimension 4600 PC Desktop
Dimension 4600 cd/dvd drives not responding
Try uninstalling them in devive manager then rebooting and see
if they are reinstalled automaticaly as drivers should be in xp already.
Just right click on them and select uninstall.
If that doesnt work then try update drivers and let xp search online for them.
Failing that then try changing the cable thats attatched to the motherboard.
Hope that helps? :)
Jan 04, 2008 | Dell Dimension 4600 PC Desktop
MONITOR GOES BLANK
Did you recently change or install a program that would affect the resolution and card output? Try booting into safe mode by holding the "shift" key during boot. From there right-click on the desktop and hit 'properties'-> 'display properties' -> 'settings' , check your resolution and drop it to 800x600 and then reboot. If everything goes back in normally make sure you have the right windows drivers for your video card. You can also check the driver version and settings while you're in safe mode. Sometimes the windows update drivers can act screwy and I would recommend getting them directly from your card manufacturer.
Aug 19, 2007 | Dell Dimension 4600 PC Desktop
Driver problems
JPWatson, This link will take you to the drivers for your Dimension 4600 with Windows XP: http://support.dell.com/support/downloads/devices.aspx?c=us&l=en&s=gen&SystemID=DIM_P4_4600&os=WW1&osl=EN As far as the PC showing you already have a connection I would ignore that for now. Just download the appropriate drivers from this Dell page including the network interface card drivers and install them first. After you have rebooted and verified that the hardware devices are working correctly then start troubleshooting your Internet connection if it is still necessary. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 21, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
153 people viewed this question
Alun Cox
