Question about Dryers
Dryer will not throw heat - Dryers
  • kevin  foster
    kevin foster Oct 12, 2010
    there are va few things that it could be....I would first go and check to make sure you have not tripped the breaker on your home breaker box. Go to it and check to make sure both sides of the 220 volt breaker are not tripped. What I often do is just reset them both and it will make sure you have got it if that was t5he problem.If this is not the problem you will need to start checking some of the components in the dryer and you may or may not want to do this yourself. If you do the first thing I would do is check the element if it is an electric dryer. If it is a gas dryer you need to check to see if the pilot light is still lit.check these two things and see what happens. the make and model would be helpful to go any further..
  • kevin  foster
    We will need to know the make and model first?
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 17, 2010
Does my dryer have a fuse in it
Sounds like either the thermostat which will be close to the heating elements, if not that, then the heating element...I'd guess it's the thermostat. Cheap fix
Aug 17, 2014 | Amana Dryers
Samsung dryer will not heat
Sounds like the heating element might be bad. Make sure your settings are set correctly (which I'm sure you have already done). Check to make sure the power cord has been hooked up correctly on the back of the dryer (may want to get someone with an electrical background). Unplug first. Could be a thermostat problem as the elements on some models heat up when needed to maintain a certain temperature. Hope this helps. Good luck.
Feb 24, 2013 | Samsung DV337 Electric Dryer
It does not heat up, it just throws cold air, do i need to buy a new dryer?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Whirlpool 6.5 Cu. Ft. Super Capacity Gas...
I have linoleum tile adhesive in my dryer, how can I remove it so I can dry my clothes someone put the towels that I was using by mistake in the dryer with the ...
You are going to need a hair dryer or heat gun; a throw away towel and some paper towels. Start out heating the adhesive until liquidy and then use the paper towel to absorb it. That should take care of most of it.
Then slightly dampen the throw away towel, put heat on the remaining adhesive until tacky then put the dampened towel over the adhesive and continue to heat the towel until the water steams.
That is way that works best for me.
Jun 19, 2011 | Dryers
The dryer runs fine but has no heat. The exhaust and lint screen are clear of debris. It is a Maytag MD3000
The Heating Element may be gone, or you might be real lucky and have a loose or dirty connection.
You might want to throw the Breaker Switch or unplug the unit before you do anything (220!!!).
Jun 02, 2011 | Dryers
My dryer is not throwing heat just cold air,everything else is working properly
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 03, 2010 | Kenmore 63942 Dryer
No heat coming from the dryer
If no heat, its either a heating element, or if it is gas, the heat coils(need more info)
Oct 20, 2008 | Whirlpool LGR3624JQ Gas Dryer
Intermitant dryer heat
i have found that in some model of the kenmore the wire going to the plug on the motor is lose on the conection since the power for the heat runs throw the cintrafugl switch it happens
Mar 18, 2008 | Dryers
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
