Question about Asko T721 Electric Dryer
Asko T721 dryer. Support rollers started to fall to bits (dryer making bumping sound as it rotated) so I bought a new set and replaced them. Not a single electrical connection was removed bar the door switch wires .... and now it won't run? The power light comes on but no action at all when start button pressed? I have checked the thermal reset at back (wasn't popped) and also looked for fuses but my model has solenoid type circuit breakers and these look fine. Dryer was functioning perfectly (bar noisy rollers) prior to disassembly, no wires removed, have checked all connections pushed on securely etc... Any idea's on what could be wrong?
  • 171 Answers
  • If you took the drum out and took the belt off you may have put the belt on wrong as there is a switch under the drive or idler pulley that must be pushed on from the pressure of the belt on the pulley. Also go and make sure both breakers are ok in the breaker box as it runs on a 220 volt sys. and if one is tripped this type of thing can occur.
  • Good luck and please rate me if this helped! thanks again for choosing fixya
Posted on Oct 12, 2010
ASko dryer T761 goes bump bump bump when starting. sometimes we can wiggle drum around and get it to stop. Help!
I believe asko says this is normal at start up and should stop after the drum has been spinning for a bit.
Jun 21, 2011 | Asko T761 Electric Dryer
My Asko dryer is thumping loudly. I am finding bits of rubber when the lower panel is removed.
You need to have your drum rollers replaced, they are making the noise because they are falling apart.
Also it could be or include the drum belt breaking down and falling apart...which means its about to break.
Normally pretty cheap parts can be found on the net...look around.
Its a pretty easy fix.
Jan 15, 2011 | Asko Dryers
My asko T721 dryer won't start. If I hold the start button down it will work, but the second I let go of it the dryer stops. It was running fine yesterday and then it stopped and now I can't get it...
the start button is bad. you will have to get it replaced take the model and serial# and go to your local appliance part store and they should have one.
Dec 17, 2010 | Asko T721 Electric Dryer
Overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Jul 24, 2009 | Asko T721 Electric Dryer
Hi, The dryer drum does not start when the start button is pushed unless I rotate the drum to a specific position.
When we had this problem the solution was to replace the motor, the electric coil in the motor had a flat spot which would not make contact and let the motor start. By moving the drum you are advancing the motor away from the flat spot. Hope this helps.
Jul 12, 2009 | Asko T721 Electric Dryer
ASKO T721 dryer - Squeaking
the dryer needs a service you need to replace the front rollers,jockey pulley and grease the jockey pin,check or replace the belt.remove the lint build up from the front frame and element assy.also check that the felt and rubber seal arond the front frame hasnt come out.you can replace it but its hard to get in and you may have to replace the front frame.i find its any easy repair but i see a lot of asko dryers (not because there bad they just need a service about every 5-7 years).hope this helps.
Mar 17, 2008 | Asko T721 Electric Dryer
ASKO t700 dryer thumping sound
usually whin you get one thump (or a quick double thump) you have a dent in the roller surface of the drum itself. Easiest way to check this is to unplug the unit and take the top off by removing the 3 torx screws in the rear, then lifting the top off. Once the top is off look at the very front edge of the drum as you rotate the whole thing by hand. If you see any irregularities on the surface, thats your problem. If you see nothing it could be a bad motor or roller, but its unlikely if its happening in the same place on the rotation evry time. What has usually happened with dents in the surface of the drum is that the unit was set down too hard (or dropped) and the wheels it rests on dented the metal they ride on. If thats the case the only solution is to replace the drum or live with it .Good Luck!
Feb 10, 2007 | Asko T700 Electric Commercial Dryer
Asko T721 Electric Dryer Logo
124 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
